Question / Help Help with Settings/Problem Streamin
Dirtman
Hey Guys,
I just got myself a new System and wanted to go back to streming ! I thought finally i could go ham on this and
after i set up everything, i had issues.
Pixelated CSGO/For Honor Stream or Ping Problems which refer to the Bitrate /Upload Speed i am sure.
Still with my old System i never had any. I could Stream CSGO/Dota 2/Witcher 3 without any Problems considering Ping/Picture.
So i am pretty clueless what to do and would love to have some Help from you Guys, since i am sure you have a better understanding than me.
This is my Speedtest :
This is the last LOG from OBS (I tried to use my GPU as Encoder, not sure what's better)
https://gist.github.com/anonymous/7cf37282ad99e55dd74547c9c6f17422#file-2017-02-12-1742-13-log-L1
Dirtman
Forgot to put in my new Pc Specs, sry Guys !
intel core i5-7600 3,5GHz kaby lake
KFA2 Geforce 1070 8GB
16GB DDR4 RAM
Gigabyte H270-HD3-CF
Dirtman
Hi Fenrir !
Thanks for your Tip. But I went back from OBS Studio to OBS Classic, since i had the Pixel Issues there and they were new, so i thought i just go back to what i had, but still. All the same
Fenrir
Forum Admin
Hi Fenrir !
Can you grab a log from OBS Studio then? Unfortunately, we're not really spending much time troubleshooting issues on Classic these days, as it's so old and maintained.
Dirtman
The Link in the 1st Post is the one to the LOG, at least it should be.
I probably will install OBS Studio then, if the Classic one will not be Updated anymore.
I will try some Settings i can find and post a new LOG.
Fenrir
Forum Admin
Yes, that log is from Classic.
Classic is no longer updated or maintained, and never will be again.
Dirtman
This is the OBS Studio LOG :
https://gist.github.com/b41d75835f4e7b3415fbcf3cb88810d5
Edit :
So i streamed 2 Games yesterday, Paragon and CSGO.
Paragon was totally fine, some lag for Viewers at the start but after changing some Settings, they said it's okay.
I had no issues Ingame at all. Settings are all on MAX and my Ping was totally fine.
CSGO though was not that satisfieing. I had pretty much Ping Issues all over. I mean it was playable since the Ping was going from 70-115 ~ , still i dont understand why. Paragon had no issues at all and CSGO is dieing!?!?!??! I am lost :(
Here is another LOG
https://gist.github.com/f0cabed28283e2e1af9f31413926146c
