Hi all,
I've been streaming Dota 2 on a fairly consistent basis and OBS has been an invaluable asset to me. OBS creator(s) and maintainers, there can't be enough gratitude sent your way for making a great, responsive and easy-to-use freeware streaming software.
I've had a few issues with my stream that I'm not totally happy with, which are most likely not the fault of the program but still something I could use input on:
I have put a number of OBS log files from the last week or so on http://www.vykromond.com/dota/OBS_logs/ . From a cursory examination and eyeballing the VODs of the streams from the same day and time, it seems to me that the larger filesize logs correspond to days with greater instances of issue 1 (artifacting). Maybe this is meaningful or maybe it's not.
The main things I'm wondering are:
Thanks in advance for anyone's input.
- Periodic strong "artifacting" effects on the stream output only where the stream gets highly pixelated, more frequently in motion scenes, but only occurring sometimes with no clarity on my end as to why. The locally stored MP4 files have no issues. (Example: http://www.twitch.tv/netolictv/b/387561176 , scroll to somewhere in the middle) This is a high priority issue for me.
- Choppy performance overall both on my end and the stream output. This is a medium priority issue for me as I suspect it's somewhat less tractable without bigger changes.
- What is the cause of issue 1?
How can I avoid recurrences of issue 1?
Are there things I can change about my OBS streaming settings to address issue 1?
Are there things I can change about my OBS streaming settings to address issue 2?
If issue 2 persists with optimal OBS settings, where can I best apply money to the problem? (I.E. what parts of my system are limiting OBS's performance?)
