Help with OBS Studio
Cutieme248
Hello,
I wanted to play a game with me and my friends. I have my capture card and my switch set up. We are using discord to talk. We also want to record our game. I managed to do something to capture their voice into the recording but, the game audio is too loud. In OBS it is fine but when the recording comes back, one can barely hear what we are saying. The in-game audio is louder than our voices. Another thing is that you cannot hear my voice through the discord connection causing me to have to use OBS. For some reason, the audio comes in doubles almost. Like I am hearing two of the same audio. Asking for help on how to get the in-game audio in the recording down so one can hear what I and my friends are saying as well as hearing my voice through the discord connection instead of having to use OBS.
try to use vpoicemeter with the right config its the best solution you mix all your audio over it and you can play it on your headset so you have live monitoring and you can change whats to loud and so one ! you only must set the Input from the capture card to the fader near the mic
and disable the recording direct in OBS so you can fully control the yound over voicemeter !View attachment 68042
Yeah, this helped to some extent. Do I record with the voicemeeter. Or with OBS? OBS can't pick my voice. Will this just pick up my mic, my friend's call, and the gameplay audio from OBS?
