Question / Help Help with live gamer portable? Flashing blue light
RyanKJJ
So, I just got mine in the mail yesterday from Amazon. It took a bit to get it totally figured out, but eventually I got it, and everything looked great. Streamed on twitch, all was fine.
Woke up this morning, and turned on my 360, ready to stream some more, and..the LGP's blue light is just flashing, and it just refused to work. Xsplit and OBS would no longer recognize it as a device as it did before, and the provided program does not recognize it. The light just keeps flashing.
I've had it for less than 24 hours, this thing can't seriously be broken already can it...? I've tried everything. I've even totally uninstalled the drivers, restarted PC, and re-installed everything, including the program..It just won't work anymore. It worked fine last night.
flavored
Hello, no offense meant at all, but this is OBS forum, not avermedia.
Quick search on google reveals several causes: overheating, poor power, connectivity issues. There is an advice to completely remove the drivers install while device is unplugged, then reconnect it and allow it to reinstall the drivers.
General consensus on the net though is that live gamer portable sucks and should be fed to the dinosaurs.
