so i used to not have issues but over time its gotten worse for some reason potentially due to random settings changes ive tried without really knowing what im doing.
anyway so pretty often i will have the text on the bottom of my obs telling me my encoding is overloaded.....actually pretty much anytime i look over on my other monitor i see this and ive noticed when skimming through vods times where the stream will freeze for a split second then sorta teleport forward in time or just in general seem alot choppier then 60fps should be. the most obvious culprit should be me running on unlimited fps however the game i play is really lightweight and when looking at task manager my gpu and cpu utilization with both the game running and stream up pretty much never goes past even 50% and is often lower then that. if one of the two of these was absolutely maxed then it would be obvious which one is choking everything.
plus my system is a little bit jank where most of the computer is my cousins 2015 build he gave me when he upgraded in 2020 then a 3070 i got gifted a year or two after that is....alot better then the rest of the system so i would of expected and also just assumed the entire time it was something with the cpu the entire time untill i finally just today used the analyzer and saw it thinks my gpu is overloaded which has genuinely baffled me. log included. ive just always stream at 720p 60 cause i just assumed my old internet wouldnt of been able to do 1080 and even though we got fibre optic internet now i just never updated this.
