Question / Help Help with audio OBS
Hey, I'm definitely going to need to see a log file first. viewtopic.php?f=5&t=97
Are you using a capture device to capture a console? If you're using an LGP or elgato, you need to ensure that "use buffering" in the source properties for that device is on (and set to 0).
Jim said:
Hey, I'm definitely going to need to see a log file first. http://obsproject.com/forum/viewtopic.php?f=5&t=97
16:52:40: Open Broadcaster Software v0.592b - 64bit ( ^ω^)
16:52:40: -------------------------------
16:52:40: CPU Name: Intel(R) Core(TM) i3-2370M CPU @ 2.40GHz
16:52:40: CPU Speed: 2395MHz
16:52:40: Physical Memory:  4066MB Total, 1726MB Free
16:52:40: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
16:52:40: monitor 1: pos={-1280, 0}, size={1280, 720}
16:52:40: monitor 2: pos={0, 0}, size={1360, 768}
16:52:40: Windows Version: 6.2 Build 9200
16:52:40: Aero is Enabled
16:52:40: OBS Modules:
16:52:40: Base Address     Module
16:52:40: 000000008F860000 OBS.exe
16:52:40: 00000000C5B90000 OBSApi.dll
16:52:40: 00000000DACA0000 DShowPlugin.dll
16:52:40: 00000000DC6E0000 GraphicsCapture.dll
16:52:40: 00000000EB160000 NoiseGate.dll
16:52:40: 00000000E0330000 PSVPlugin.dll
16:52:40: 00000000DCE20000 scenesw.dll
16:52:40: ------------------------------------------
16:52:40: Adapter 1
16:52:40:   Video Adapter: AMD Radeon HD 7500M/7600M Series
16:52:40:   Video Adapter Dedicated Video Memory: 1060126720
16:52:40:   Video Adapter Shared System Memory: 1879048192
16:52:40:   Video Adapter Output 1: pos={0, 0}, size={1360, 768}, attached=true
16:52:40:   Video Adapter Output 2: pos={-1280, 0}, size={1280, 720}, attached=true
16:52:40: =====Stream Start: 2014-01-10, 16:52:40===============================================
16:52:40:   Multithreaded optimizations: On
16:52:40:   Base resolution: 1360x768
16:52:40:   Output resolution: 1360x768
16:52:40: Loading up D3D10 on AMD Radeon HD 7500M/7600M Series (Adapter 1)...
16:52:40: Audio Format: 48000hz
16:52:40: Playback device {0.0.0.00000000}.{3c0ee0e3-240d-4991-b9ac-c94b96bdc4dc}
16:52:40: Using desktop audio input: Altavoces (2- Corsair Vengeance 1500 Headset)
16:52:40: Using auxilary audio input: Micrófono (2- Corsair Vengeance 1500 Headset)
16:52:40: Audio Encoding: AAC
16:52:40:     bitrate: 128
16:52:40: Scene buffering time set to 700
16:52:40: Video Encoding: x264
16:52:40:     fps: 30
16:52:40:     width: 1360, height: 768
16:52:40:     preset: ultrafast
16:52:40:     profile: high
16:52:40:     keyint: 60
16:52:40:     CBR: yes
16:52:40:     CFR: yes
16:52:40:     max bitrate: 1000
16:52:40:     buffer size: 1000
16:52:40: MMDeviceAudioSource: Frequency for device 'Altavoces (2- Corsair Vengeance 1500 Headset)' is 352800, samples per sec is 44100
16:52:40: MMDeviceAudioSource: Frequency for device 'Micrófono (2- Corsair Vengeance 1500 Headset)' is 352800, samples per sec is 44100
16:52:42: Total frames encoded: 28, total frames duplicated: 0 (0.00%)
16:52:42: Total frames rendered: 42, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
16:52:42:
16:52:42: Profiler time results:
16:52:42:
16:52:42: ==============================================================
16:52:42: video thread frame - [100%] [avg time: 1.054 ms] [children: 28.7%] [unaccounted: 71.3%]
16:52:42: | scene->Preprocess - [0.0949%] [avg time: 0.001 ms]
16:52:42: | GPU download and conversion - [28.6%] [avg time: 0.301 ms] [children: 28.5%] [unaccounted: 0.0949%]
16:52:42: | | flush - [26.5%] [avg time: 0.279 ms]
16:52:42: | | CopyResource - [1.71%] [avg time: 0.018 ms]
16:52:42: | | conversion to 4:2:0 - [0.285%] [avg time: 0.003 ms]
16:52:42: Convert444Thread - [100%] [avg time: 2.422 ms] [children: 99.7%] [unaccounted: 0.33%]
16:52:42: | Convert444toNV12 - [99.7%] [avg time: 2.414 ms]
16:52:42: encoder thread frame - [100%] [avg time: 2.579 ms]
16:52:42:
16:52:42:
16:52:42: Profiler CPU results:
16:52:42:
16:52:42: video thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:42: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:42: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:42: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:42: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
16:52:42: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
16:52:42: Convert444Thread - [cpu time: avg 1.736 ms, total 31.25 ms] [avg calls per frame: 1]
16:52:42: | Convert444toNV12 - [cpu time: avg 1.736 ms, total 31.25 ms] [avg calls per frame: 1]
16:52:42: encoder thread frame - [cpu time: avg 2.757 ms, total 46.875 ms] [avg calls per frame: 1]
16:52:42:
16:52:42: =====Stream End: 2014-01-10, 16:52:42=================================================
16:52:42: =====Stream Start: 2014-01-10, 16:52:42===============================================
16:52:42:   Multithreaded optimizations: On
16:52:42:   Base resolution: 1360x768
16:52:42:   Output resolution: 1360x768
16:52:42: ------------------------------------------
16:52:42: Loading up D3D10 on AMD Radeon HD 7500M/7600M Series (Adapter 1)...
16:52:42: Audio Format: 48000hz
16:52:42: Playback device {0.0.0.00000000}.{3c0ee0e3-240d-4991-b9ac-c94b96bdc4dc}
16:52:42: Using desktop audio input: Altavoces (2- Corsair Vengeance 1500 Headset)
16:52:42: Using auxilary audio input: Micrófono (2- Corsair Vengeance 1500 Headset)
16:52:42: Audio Encoding: AAC
16:52:42:     bitrate: 128
16:52:42: Scene buffering time set to 700
16:52:42: Video Encoding: x264
16:52:42:     fps: 30
16:52:42:     width: 1360, height: 768
16:52:42:     preset: ultrafast
16:52:42:     profile: high
16:52:42:     keyint: 60
16:52:42:     CBR: yes
16:52:42:     CFR: yes
16:52:42:     max bitrate: 1000
16:52:42:     buffer size: 1000
16:52:42: MMDeviceAudioSource: Frequency for device 'Altavoces (2- Corsair Vengeance 1500 Headset)' is 352800, samples per sec is 44100
16:52:42: MMDeviceAudioSource: Frequency for device 'Micrófono (2- Corsair Vengeance 1500 Headset)' is 352800, samples per sec is 44100
16:52:43: Total frames encoded: 12, total frames duplicated: 0 (0.00%)
16:52:43: Total frames rendered: 35, number of late frames: 1 (2.86%) (it's okay for some frames to be late)
16:52:43:
16:52:43: Profiler time results:
16:52:43:
16:52:43: ==============================================================
16:52:43: video thread frame - [100%] [avg time: 0.947 ms] [children: 23.9%] [unaccounted: 76.1%]
16:52:43: | scene->Preprocess - [0.106%] [avg time: 0.001 ms]
16:52:43: | GPU download and conversion - [23.8%] [avg time: 0.225 ms] [children: 24.3%] [unaccounted: -0.528%]
16:52:43: | | flush - [22.3%] [avg time: 0.211 ms]
16:52:43: | | CopyResource - [1.69%] [avg time: 0.016 ms]
16:52:43: | | conversion to 4:2:0 - [0.317%] [avg time: 0.003 ms]
16:52:43: Convert444Thread - [100%] [avg time: 2.037 ms] [children: 99.6%] [unaccounted: 0.442%]
16:52:43: | Convert444toNV12 - [99.6%] [avg time: 2.028 ms]
16:52:43: encoder thread frame - [100%] [avg time: 2.581 ms]
16:52:43:
16:52:43:
16:52:43: Profiler CPU results:
16:52:43:
16:52:43: video thread frame - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:43: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:43: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:43: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:43: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
16:52:43: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 0]
16:52:43: Convert444Thread - [cpu time: avg 3.125 ms, total 31.25 ms] [avg calls per frame: 1]
16:52:43: | Convert444toNV12 - [cpu time: avg 3.125 ms, total 31.25 ms] [avg calls per frame: 1]
16:52:43: encoder thread frame - [cpu time: avg 1.736 ms, total 15.625 ms] [avg calls per frame: 1]
16:52:43:
16:52:43: =====Stream End: 2014-01-10, 16:52:43=================================================
16:52:46: =====Stream Start: 2014-01-10, 16:52:46===============================================
16:52:46:   Multithreaded optimizations: On
16:52:46:   Base resolution: 1360x768
16:52:46:   Output resolution: 1360x768
16:52:46: ------------------------------------------
16:52:46: Loading up D3D10 on AMD Radeon HD 7500M/7600M Series (Adapter 1)...
16:52:46: Audio Format: 48000hz
16:52:46: Playback device {0.0.0.00000000}.{3c0ee0e3-240d-4991-b9ac-c94b96bdc4dc}
16:52:46: Using desktop audio input: Altavoces (2- Corsair Vengeance 1500 Headset)
16:52:46: Using auxilary audio input: Micrófono (2- Corsair Vengeance 1500 Headset)
16:52:46: Audio Encoding: AAC
16:52:46:     bitrate: 128
16:52:46: Scene buffering time set to 700
16:52:46: Video Encoding: x264
16:52:46:     fps: 30
16:52:46:     width: 1360, height: 768
16:52:46:     preset: ultrafast
16:52:46:     profile: high
16:52:46:     keyint: 60
16:52:46:     CBR: yes
16:52:46:     CFR: yes
16:52:46:     max bitrate: 1000
16:52:46:     buffer size: 1000
16:52:46: MMDeviceAudioSource: Frequency for device 'Altavoces (2- Corsair Vengeance 1500 Headset)' is 352800, samples per sec is 44100
16:52:46: MMDeviceAudioSource: Frequency for device 'Micrófono (2- Corsair Vengeance 1500 Headset)' is 352800, samples per sec is 44100
16:52:49: Total frames encoded: 54, total frames duplicated: 0 (0.00%)
16:52:49: Total frames rendered: 59, number of late frames: 1 (1.69%) (it's okay for some frames to be late)
16:52:49:
16:52:49: Profiler time results:
16:52:49:
16:52:49: ==============================================================
16:52:49: video thread frame - [100%] [avg time: 0.816 ms] [children: 19%] [unaccounted: 81%]
16:52:49: | scene->Preprocess - [0.123%] [avg time: 0.001 ms]
16:52:49: | GPU download and conversion - [18.9%] [avg time: 0.154 ms] [children: 18.3%] [unaccounted: 0.613%]
16:52:49: | | flush - [15.8%] [avg time: 0.129 ms]
16:52:49: | | CopyResource - [1.96%] [avg time: 0.016 ms]
16:52:49: | | conversion to 4:2:0 - [0.49%] [avg time: 0.004 ms]
16:52:49: Convert444Thread - [100%] [avg time: 1.806 ms] [children: 99.6%] [unaccounted: 0.443%]
16:52:49: | Convert444toNV12 - [99.6%] [avg time: 1.798 ms]
16:52:49: encoder thread frame - [100%] [avg time: 1.249 ms]
16:52:49:
16:52:49:
16:52:49: Profiler CPU results:
16:52:49:
16:52:49: video thread frame - [cpu time: avg 0.264 ms, total 15.625 ms] [avg calls per frame: 1]
16:52:49: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:49: | GPU download and conversion - [cpu time: avg 0.264 ms, total 15.625 ms] [avg calls per frame: 1]
16:52:49: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:49: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:52:49: | | conversion to 4:2:0 - [cpu time: avg 0.459 ms, total 15.625 ms] [avg calls per frame: 1]
16:52:49: Convert444Thread - [cpu time: avg 1.378 ms, total 46.875 ms] [avg calls per frame: 1]
16:52:49: | Convert444toNV12 - [cpu time: avg 1.378 ms, total 46.875 ms] [avg calls per frame: 1]
16:52:49: encoder thread frame - [cpu time: avg 0.946 ms, total 31.25 ms] [avg calls per frame: 1]
16:52:49:
16:52:49: =====Stream End: 2014-01-10, 16:52:49=================================================
16:52:50: =====Stream Start: 2014-01-10, 16:52:50===============================================
16:52:50:   Multithreaded optimizations: On
16:52:50:   Base resolution: 1360x768
16:52:50:   Output resolution: 1360x768
16:52:50: ------------------------------------------
16:52:50: Loading up D3D10 on AMD Radeon HD 7500M/7600M Series (Adapter 1)...
16:52:50: Audio Format: 48000hz
16:52:50: Playback device {0.0.0.00000000}.{3c0ee0e3-240d-4991-b9ac-c94b96bdc4dc}
16:52:50: Using desktop audio input: Altavoces (2- Corsair Vengeance 1500 Headset)
16:52:50: Using auxilary audio input: Micrófono (2- Corsair Vengeance 1500 Headset)
16:52:50: Audio Encoding: AAC
16:52:50:     bitrate: 128
16:52:50: Using graphics capture
16:52:50: Scene buffering time set to 700
16:52:50: Video Encoding: x264
16:52:50:     fps: 30
16:52:50:     width: 1360, height: 768
16:52:50:     preset: ultrafast
16:52:50:     profile: high
16:52:50:     keyint: 60
16:52:50:     CBR: yes
16:52:50:     CFR: yes
16:52:50:     max bitrate: 1000
16:52:50:     buffer size: 1000
16:52:50: MMDeviceAudioSource: Frequency for device 'Altavoces (2- Corsair Vengeance 1500 Headset)' is 352800, samples per sec is 44100
16:52:50: MMDeviceAudioSource: Frequency for device 'Micrófono (2- Corsair Vengeance 1500 Headset)' is 352800, samples per sec is 44100
16:52:50: SharedTexCapture hooked
17:00:50: GraphicsCaptureSource::NewCapture:  eliminating old capture
17:00:50: SharedTexCapture hooked
17:05:10: Total frames encoded: 22156, total frames duplicated: 1798 (8.12%)
17:05:10: Number of frames skipped due to encoder lag: 1281 (5.78%)
17:05:10: Total frames rendered: 20691, number of late frames: 115 (0.56%) (it's okay for some frames to be late)
17:05:10:
17:05:10: Profiler time results:
17:05:10:
17:05:10: ==============================================================
17:05:10: video thread frame - [100%] [avg time: 2.34 ms] [children: 48.4%] [unaccounted: 51.6%]
17:05:10: | scene->Preprocess - [0.171%] [avg time: 0.004 ms]
17:05:10: | GPU download and conversion - [48.2%] [avg time: 1.128 ms] [children: 45.4%] [unaccounted: 2.78%]
17:05:10: | | flush - [42.6%] [avg time: 0.998 ms]
17:05:10: | | CopyResource - [2.52%] [avg time: 0.059 ms]
17:05:10: | | conversion to 4:2:0 - [0.256%] [avg time: 0.006 ms]
17:05:10: Convert444Thread - [100%] [avg time: 3.496 ms] [children: 99.6%] [unaccounted: 0.429%]
17:05:10: | Convert444toNV12 - [99.6%] [avg time: 3.481 ms]
17:05:10: encoder thread frame - [100%] [avg time: 5.765 ms]
17:05:10:
17:05:10:
17:05:10: Profiler CPU results:
17:05:10:
17:05:10: video thread frame - [cpu time: avg 0.675 ms, total 13968.8 ms] [avg calls per frame: 1]
17:05:10: | scene->Preprocess - [cpu time: avg 0 ms, total 15.625 ms] [avg calls per frame: 1]
17:05:10: | GPU download and conversion - [cpu time: avg 0.268 ms, total 5562.5 ms] [avg calls per frame: 1]
17:05:10: | | flush - [cpu time: avg 0.221 ms, total 4578.13 ms] [avg calls per frame: 1]
17:05:10: | | CopyResource - [cpu time: avg 0.024 ms, total 500 ms] [avg calls per frame: 1]
17:05:10: | | conversion to 4:2:0 - [cpu time: avg 0.004 ms, total 93.75 ms] [avg calls per frame: 1]
17:05:10: Convert444Thread - [cpu time: avg 2.994 ms, total 61875 ms] [avg calls per frame: 1]
17:05:10: | Convert444toNV12 - [cpu time: avg 2.985 ms, total 61703.1 ms] [avg calls per frame: 1]
17:05:10: encoder thread frame - [cpu time: avg 1.502 ms, total 33250 ms] [avg calls per frame: 1]
17:05:10:
17:05:10: =====Stream End: 2014-01-10, 17:05:10=================================================
Okay, is the mic out of sync, or game video/audio as well?
If it's just the mic, you might want to try the latest test build (remember, it does not auto-update so check back later for the full version)
If it's the entire thing, then try "sync audio to video time" in advanced settings
