Question / Help Help With Application Taking Over Sound
Hikari1100
I am trying to stream my music making process, but it seems as though while Fruity Loops 10 is open, OBS cannot pickup any sound from my Default Device. As soon as I close FL10, if i try to record, the desktop sound suddenly works.
Halp me.
Lain
Forum Admin
Lain
Forum Moderator
Developer
I believe this has something to do with the way I record desktop sound and ASIO. Could you try this special version for me? http://obsproject.com/temp/OBS_0473b_audio_redirect.zip -- What it does is it allows you to choose a "what you hear" or "stereo mix" capture from your sound card as your primary desktop sound input. You need to go into audio settings and select it as your "Desktop audio device" though. Let me know if that helps or not, I'm curious to know. This is just a test that I was able to whip up real quick.
djcyphers
Hi, Jim. I'm also experiencing a related issue while trying to stream Ableton Live (ASIO drivers). After using your audio redirect tester, the option to choose "What U hear" in the audio settings appeared and works, but now the microphone doesn't work and gives this error below. I'm using a SoundBlaster X-Fi card.
Open Broadcaster Software v0.473b (audio redirect test) - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM)2 Quad CPU           @ 2.40GHz
CPU Speed: 2700MHz
Physical Memory:  8191MB Total, 5530MB Free
stepping id: 7, model 15, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 4, total cores 4
monitor 1: pos={0, 0}, size={1360, 768}
Aero is Enabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 650 Ti
  Video Adapter Dedicated Video Memory: 1020985344
  Video Adapter Shared System Memory: 3221221376
  Base resolution: 1360x768
  Output resolution: 1360x768
Loading up D3D10...
Playback device {0.0.1.00000000}.{05428d63-b70d-46ce-a6f9-075f0d30cc97}
Using desktop audio input: "What U Hear" (Creative SB X-Fi)
Using auxilary audio input: Microphone (Creative SB X-Fi)
Warning -- MMDeviceAudioSource::Initialize(1): Could not initialize audio client, result = 8889000A
Audio Encoding: AAC
    bitrate: 256
Using bitmap image
Using Window Capture
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
x264: profile High, level 3.2
Video Encoding: x264
    fps: 30
    width: 1360, height: 768
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 114, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:24.58  size: 46418
x264: frame P:20    Avg QP:26.88  size:   523
x264: frame B:55    Avg QP:22.02  size:    76
x264: consecutive B-frames:  2.6%  0.0%  0.0% 97.4%
x264: mb I  I16..4: 67.7%  4.1% 28.2%
x264: mb P  I16..4:  0.3%  0.0%  0.0%  P16..4:  0.5%  0.3%  0.1%  0.0%  0.0%    skip:98.9%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.4%  0.1%  0.0%  direct: 0.0%  skip:99.5%  L0:51.1% L1:48.2% BI: 0.7%
x264: 8x8 transform intra:3.8% inter:11.9%
x264: coded y,uvDC,uvAC intra: 29.8% 26.1% 21.3% inter: 0.1% 0.1% 0.0%
x264: i16 v,h,dc,p: 54% 43%  3%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 77% 10%  2%  0%  0%  0%  0%  1%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 33% 48%  8%  1%  2%  2%  3%  2%  2%
x264: i8c dc,h,v,p: 46% 40% 13%  1%
x264: Weighted P-Frames: Y:0.0% UV:0.0%
x264: kb/s:192.84
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 256
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 79, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:24.67  size: 47322
x264: frame P:11    Avg QP:25.71  size:   477
x264: frame B:29    Avg QP:22.14  size:    87
x264: consecutive B-frames:  4.8%  0.0%  0.0% 95.2%
x264: mb I  I16..4: 68.3%  3.3% 28.4%
x264: mb P  I16..4:  0.5%  0.0%  0.0%  P16..4:  0.5%  0.3%  0.0%  0.0%  0.0%    skip:98.7%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  0.4%  0.0%  0.0%  direct: 0.1%  skip:99.4%  L0:46.1% L1:50.6% BI: 3.3%
x264: 8x8 transform intra:3.1% inter:10.5%
x264: coded y,uvDC,uvAC intra: 29.5% 26.6% 20.8% inter: 0.1% 0.1% 0.0%
x264: i16 v,h,dc,p: 53% 44%  3%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 76% 10%  0%  0%  0%  0%  0%  0%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 32% 48%  8%  1%  2%  2%  3%  2%  2%
x264: i8c dc,h,v,p: 43% 42% 14%  1%
x264: kb/s:322.34
Loading up D3D10...
Using auxilary audio input: Line-In 2/Mic 2 (Creative SB X-Fi)
Audio Encoding: AAC
    bitrate: 256
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 671, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:3     Avg QP:22.60  size: 54209
x264: frame P:163   Avg QP:27.07  size:   481
x264: frame B:467   Avg QP:23.24  size:    82
x264: consecutive B-frames:  1.4%  0.3%  0.0% 98.3%
x264: mb I  I16..4: 68.0%  1.6% 30.5%
x264: mb P  I16..4:  0.2%  0.0%  0.0%  P16..4:  0.3%  0.3%  0.1%  0.0%  0.0%    skip:99.1%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.5%  0.0%  0.0%  direct: 0.0%  skip:99.5%  L0:52.5% L1:46.6% BI: 0.9%
x264: 8x8 transform intra:1.4% inter:10.7%
x264: coded y,uvDC,uvAC intra: 28.6% 28.7% 23.0% inter: 0.1% 0.1% 0.0%
x264: i16 v,h,dc,p: 57% 40%  3%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 56% 18%  3%  0%  0%  1%  0%  2%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 33% 48%  7%  1%  2%  2%  3%  1%  2%
x264: i8c dc,h,v,p: 37% 41% 21%  1%
x264: kb/s:105.91
Loading up D3D10...
Playback device {0.0.1.00000000}.{ebd93a3f-1281-44e8-bbd7-df9ae85ea697}
Using desktop audio input: Microphone (Creative SB X-Fi)
Using auxilary audio input: "What U Hear" (Creative SB X-Fi)
Audio Encoding: AAC
    bitrate: 256
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 207, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:24.58  size: 46224
x264: frame P:42    Avg QP:26.48  size:   478
x264: frame B:126   Avg QP:22.17  size:    85
x264: consecutive B-frames:  0.6%  0.0%  0.0% 99.4%
x264: mb I  I16..4: 70.1%  1.9% 28.1%
x264: mb P  I16..4:  0.2%  0.0%  0.0%  P16..4:  0.4%  0.2%  0.1%  0.0%  0.0%    skip:99.0%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.4%  0.0%  0.0%  direct: 0.0%  skip:99.5%  L0:43.0% L1:56.0% BI: 1.0%
x264: 8x8 transform intra:1.7% inter:8.9%
x264: coded y,uvDC,uvAC intra: 27.6% 26.3% 21.1% inter: 0.1% 0.1% 0.0%
x264: i16 v,h,dc,p: 57% 41%  3%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 53% 20%  4%  0%  0%  1%  0%  2%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 32% 49%  8%  1%  2%  2%  3%  2%  2%
x264: i8c dc,h,v,p: 41% 38% 20%  1%
x264: kb/s:109.32
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 256
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 101, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:24.60  size: 45581
x264: frame P:16    Avg QP:26.64  size:   543
x264: frame B:46    Avg QP:22.41  size:    87
x264: consecutive B-frames:  1.5%  0.0%  0.0% 98.5%
x264: mb I  I16..4: 69.6%  2.5% 27.9%
x264: mb P  I16..4:  0.4%  0.0%  0.0%  P16..4:  0.4%  0.3%  0.1%  0.0%  0.0%    skip:98.8%
x264: mb B  I16..4:  0.1%  0.0%  0.0%  B16..8:  0.4%  0.0%  0.0%  direct: 0.0%  skip:99.4%  L0:57.4% L1:41.9% BI: 0.7%
x264: 8x8 transform intra:2.3% inter:10.5%
x264: coded y,uvDC,uvAC intra: 28.1% 25.7% 20.7% inter: 0.1% 0.1% 0.0%
x264: i16 v,h,dc,p: 54% 44%  3%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 58% 18%  2%  0%  0%  1%  0%  2%
x264: i8c dc,h,v,p: 44% 41% 15%  1%
x264: kb/s:221.83
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 256
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 157, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:24.66  size: 45648
x264: frame P:30    Avg QP:26.33  size:   534
x264: frame B:88    Avg QP:23.27  size:    98
x264: consecutive B-frames:  0.8%  0.0%  0.0% 99.2%
x264: mb I  I16..4: 69.9%  2.2% 27.9%
x264: mb P  I16..4:  0.3%  0.0%  0.0%  P16..4:  0.4%  0.2%  0.1%  0.0%  0.0%    skip:98.9%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.5%  0.0%  0.0%  direct: 0.0%  skip:99.4%  L0:50.6% L1:47.3% BI: 2.1%
x264: 8x8 transform intra:2.0% inter:10.1%
x264: coded y,uvDC,uvAC intra: 28.5% 26.9% 21.2% inter: 0.1% 0.1% 0.0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 21% 53% 21%  3%  0%  0%  1%  0%  2%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 32% 48%  9%  1%  2%  2%  2%  2%  2%
x264: i8c dc,h,v,p: 45% 39% 15%  1%
x264: kb/s:141.69
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 256
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 32, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 256
Using bitmap image
    fps: 30
    preset: veryfast
    CBR: no
    CFR: no
    max bitrate: 1000
    buffer size: 1000
    quality: 8
Total frames rendered: 88, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
x264: frame I:1     Avg QP:24.67  size: 46207
x264: frame P:13    Avg QP:26.34  size:   669
x264: frame B:36    Avg QP:25.02  size:   129
x264: consecutive B-frames:  4.0%  0.0%  0.0% 96.0%
x264: mb I  I16..4: 68.7%  3.3% 28.0%
x264: mb P  I16..4:  0.3%  0.0%  0.0%  P16..4:  0.6%  0.2%  0.1%  0.0%  0.0%    skip:98.7%
x264: mb B  I16..4:  0.0%  0.0%  0.0%  B16..8:  0.4%  0.1%  0.0%  direct: 0.0%  skip:99.4%  L0:52.3% L1:44.9% BI: 2.8%
x264: 8x8 transform intra:3.1% inter:5.7%
x264: coded y,uvDC,uvAC intra: 30.2% 26.9% 21.4% inter: 0.1% 0.1% 0.0%
x264: i16 v,h,dc,p: 52% 45%  3%  0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 10% 74% 12%  1%  0%  0%  1%  0%  1%
x264: i8c dc,h,v,p: 46% 41% 13%  1%
x264: kb/s:285.72
Profiler results:
frame - [100%] [avg time: 16.476 ms] [avg calls per frame: 1] [children: 94%] [unaccounted: 5.98%]
| scene->Preprocess - [39.4%] [avg time: 6.493 ms] [avg calls per frame: 1]
| video encoding and uploading - [54.6%] [avg time: 8.997 ms] [avg calls per frame: 1] [children: 34.4%] [unaccounted: 20.2%]
| | CopyResource - [0.121%] [avg time: 0.02 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.146%] [avg time: 0.024 ms] [avg calls per frame: 0]
| | call to encoder - [34.1%] [avg time: 5.625 ms] [avg calls per frame: 0]
| | sending stuff out - [0.0182%] [avg time: 0.003 ms] [avg calls per frame: 0]
Thanks for your time and patience. Have a great day!
