weedloco21
07:53:34: Open Broadcaster Software v0.613b - 32bit (´・ω・`)
07:53:34: -------------------------------
07:53:34: CPU Name: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
07:53:34: CPU Speed: 3093MHz
07:53:34: Physical Memory: 4095MB Total, 4095MB Free
07:53:34: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
07:53:34: monitor 1: pos={0, 0}, size={1920, 1080}
07:53:34: Windows Version: 6.1 Build 7601 S
07:53:34: Aero is Enabled
07:53:34: OBS Modules:
07:53:34: Base Address Module
07:53:34: 012F0000 OBS.exe
07:53:34: 67FB0000 OBSApi.dll
07:53:34: 6B1E0000 DShowPlugin.dll
07:53:34: 6B2B0000 GraphicsCapture.dll
07:53:34: 68410000 NoiseGate.dll
07:53:34: 683F0000 PSVPlugin.dll
07:53:34: ------------------------------------------
07:53:34: Adapter 1
07:53:34: Video Adapter: NVIDIA GeForce GTX 760
07:53:34: Video Adapter Dedicated Video Memory: 2087387136
07:53:34: Video Adapter Shared System Memory: 2147807232
07:53:34: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
07:53:34: =====Stream Start: 2014-03-10, 07:53:34===============================================
07:53:34: Multithreaded optimizations: On
07:53:34: Base resolution: 1920x1080
07:53:34: Output resolution: 1920x1080
07:53:34: Loading up D3D10 on NVIDIA GeForce GTX 760 (Adapter 1)...
07:53:34: Audio Format: 44100 Hz
07:53:34: Audio Channels: 2 Ch
07:53:34: Playback device {0.0.0.00000000}.{252ba932-7c47-40cd-b7f9-1c4852b541b9}
07:53:34: Using desktop audio input: Speakers (Realtek High Definition Audio)
07:53:34: Using auxilary audio input: Mic in at rear panel (Pink) (Realtek High Definition Audio)
07:53:34: Audio Encoding: AAC
07:53:34: bitrate: 128
07:53:34: Using Window Capture
07:53:34: Using graphics capture
07:53:34: Scene buffering time set to 60
07:53:34: Video Encoding: x264
07:53:34: fps: 30
07:53:34: width: 1920, height: 1080
07:53:34: preset: veryfast
07:53:34: profile: main
07:53:34: keyint: 30
07:53:34: CBR: yes
07:53:34: CFR: yes
07:53:34: max bitrate: 3500
07:53:34: buffer size: 3500
07:53:35: Total frames encoded: 36, total frames duplicated: 0 (0.00%)
07:53:35: Total frames rendered: 40, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
07:53:37: Number of times waited to send: 0, Waited for a total of 0 bytes
07:53:37: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
07:53:37: Number of bytes sent: 0
07:53:37:
07:53:37: Profiler time results:
07:53:37:
07:53:37: ==============================================================
07:53:37: video thread frame - [100%] [avg time: 1.162 ms] [children: 46%] [unaccounted: 54%]
07:53:37: | scene->Preprocess - [39%] [avg time: 0.453 ms]
07:53:37: | GPU download and conversion - [6.97%] [avg time: 0.081 ms] [children: 4.56%] [unaccounted: 2.41%]
07:53:37: | | flush - [3.79%] [avg time: 0.044 ms]
07:53:37: | | CopyResource - [0.602%] [avg time: 0.007 ms]
07:53:37: | | conversion to 4:2:0 - [0.172%] [avg time: 0.002 ms]
07:53:37: Convert444Threads - [100%] [avg time: 1.226 ms] [children: 99.3%] [unaccounted: 0.734%]
07:53:37: | Convert444toNV12 - [99.3%] [avg time: 1.217 ms]
07:53:37: encoder thread frame - [100%] [avg time: 1.116 ms] [children: 0.358%] [unaccounted: 99.6%]
07:53:37: | sending stuff out - [0.358%] [avg time: 0.004 ms]
07:53:37:
07:53:37:
07:53:37: Profiler CPU results:
07:53:37:
07:53:37: video thread frame - [cpu time: avg 0.39 ms, total 15.6 ms] [avg calls per frame: 1]
07:53:37: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:53:37: | GPU download and conversion - [cpu time: avg 0.39 ms, total 15.6 ms] [avg calls per frame: 1]
07:53:37: | | flush - [cpu time: avg 0.39 ms, total 15.6 ms] [avg calls per frame: 1]
07:53:37: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:53:37: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:53:37: Convert444Threads - [cpu time: avg 0.891 ms, total 62.4 ms] [avg calls per frame: 2]
07:53:37: | Convert444toNV12 - [cpu time: avg 0.891 ms, total 62.4 ms] [avg calls per frame: 2]
07:53:37: encoder thread frame - [cpu time: avg 0.458 ms, total 15.6 ms] [avg calls per frame: 1]
07:53:37: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:53:37:
07:53:37: =====Stream End: 2014-03-10, 07:53:37=================================================
07:54:40: =====Stream Start: 2014-03-10, 07:54:40===============================================
07:54:40: Multithreaded optimizations: On
07:54:40: Base resolution: 1920x1080
07:54:40: Output resolution: 1920x1080
07:54:40: ------------------------------------------
07:54:40: Loading up D3D10 on NVIDIA GeForce GTX 760 (Adapter 1)...
07:54:40: Audio Format: 44100 Hz
07:54:40: Audio Channels: 2 Ch
07:54:40: Playback device {0.0.0.00000000}.{252ba932-7c47-40cd-b7f9-1c4852b541b9}
07:54:40: Using desktop audio input: Speakers (Realtek High Definition Audio)
07:54:40: Using auxilary audio input: Mic in at rear panel (Pink) (Realtek High Definition Audio)
07:54:40: Audio Encoding: AAC
07:54:40: bitrate: 128
07:54:40: Using Window Capture
07:54:40: Using graphics capture
07:54:40: Scene buffering time set to 60
07:54:40: Video Encoding: x264
07:54:40: fps: 30
07:54:40: width: 1920, height: 1080
07:54:40: preset: veryfast
07:54:40: profile: main
07:54:40: keyint: 30
07:54:40: CBR: yes
07:54:40: CFR: yes
07:54:40: max bitrate: 3500
07:54:40: buffer size: 3500
07:54:40: Audio timestamp for device 'Mic in at rear panel (Pink) (Realtek High Definition Audio)' was behind target timestamp by 632488
07:54:41: SharedTexCapture hooked
07:54:58: Total frames encoded: 536, total frames duplicated: 5 (0.93%)
07:54:58: Total frames rendered: 541, number of late frames: 1 (0.18%) (it's okay for some frames to be late)
07:55:02: Number of times waited to send: 0, Waited for a total of 0 bytes
07:55:02: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
07:55:02: Number of bytes sent: 0
07:55:02:
07:55:02: Profiler time results:
07:55:02:
07:55:02: ==============================================================
07:55:02: video thread frame - [100%] [avg time: 1.509 ms] [children: 43.7%] [unaccounted: 56.3%]
07:55:02: | scene->Preprocess - [21.6%] [avg time: 0.326 ms]
07:55:02: | GPU download and conversion - [22.1%] [avg time: 0.333 ms] [children: 10.9%] [unaccounted: 11.2%]
07:55:02: | | flush - [6.49%] [avg time: 0.098 ms]
07:55:02: | | CopyResource - [4.24%] [avg time: 0.064 ms]
07:55:02: | | conversion to 4:2:0 - [0.133%] [avg time: 0.002 ms]
07:55:02: Convert444Threads - [100%] [avg time: 1.03 ms] [children: 95.6%] [unaccounted: 4.37%]
07:55:02: | Convert444toNV12 - [95.6%] [avg time: 0.985 ms]
07:55:02: encoder thread frame - [100%] [avg time: 2.674 ms] [children: 0.449%] [unaccounted: 99.6%]
07:55:02: | sending stuff out - [0.449%] [avg time: 0.012 ms]
07:55:02:
07:55:02:
07:55:02: Profiler CPU results:
07:55:02:
07:55:02: video thread frame - [cpu time: avg 0.374 ms, total 202.801 ms] [avg calls per frame: 1]
07:55:02: | scene->Preprocess - [cpu time: avg 0.028 ms, total 15.6 ms] [avg calls per frame: 1]
07:55:02: | GPU download and conversion - [cpu time: avg 0.028 ms, total 15.6 ms] [avg calls per frame: 1]
07:55:02: | | flush - [cpu time: avg 0.028 ms, total 15.6 ms] [avg calls per frame: 1]
07:55:02: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:55:02: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:55:02: Convert444Threads - [cpu time: avg 0.947 ms, total 1014.01 ms] [avg calls per frame: 2]
07:55:02: | Convert444toNV12 - [cpu time: avg 0.947 ms, total 1014.01 ms] [avg calls per frame: 2]
07:55:02: encoder thread frame - [cpu time: avg 1.665 ms, total 889.205 ms] [avg calls per frame: 1]
07:55:02: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
07:55:02:
07:55:02: =====Stream End: 2014-03-10, 07:55:02=================================================
07:55:04: =====Stream Start: 2014-03-10, 07:55:04===============================================
07:55:04: Multithreaded optimizations: On
07:55:04: Base resolution: 1920x1080
07:55:04: Output resolution: 1920x1080
07:55:04: ------------------------------------------
07:55:04: Loading up D3D10 on NVIDIA GeForce GTX 760 (Adapter 1)...
07:55:04: Audio Format: 44100 Hz
07:55:04: Audio Channels: 2 Ch
07:55:04: Playback device {0.0.0.00000000}.{252ba932-7c47-40cd-b7f9-1c4852b541b9}
07:55:04: Using desktop audio input: Speakers (Realtek High Definition Audio)
07:55:04: Using auxilary audio input: Mic in at rear panel (Pink) (Realtek High Definition Audio)
07:55:04: Audio Encoding: AAC
07:55:04: bitrate: 128
07:55:04: Using Window Capture
07:55:04: Using graphics capture
07:55:04: Scene buffering time set to 60
07:55:04: Video Encoding: x264
07:55:04: fps: 30
07:55:04: width: 1920, height: 1080
07:55:04: preset: veryfast
07:55:04: profile: main
07:55:04: keyint: 30
07:55:04: CBR: yes
07:55:04: CFR: yes
07:55:04: max bitrate: 3500
07:55:04: buffer size: 3500
07:55:04: SharedTexCapture hooked
08:00:05: Using RTMP service: Twitch / Justin.tv
08:00:05: Server selection: rtmp://live-sin-backup.justin.tv/app
08:00:05: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
08:00:05: Completed handshake with rtmp://live-sin-backup.justin.tv/app in 436 ms.
08:00:06: SO_SNDBUF was at 8192
08:00:06: SO_SNDBUF is now 65536
my upload capability is 45000 kbps to singapore sever on twitch from my location hong kong
