Help we can't find the problem
MadEck
My friend and I are looking at this and have like beginner level experience in obs and would just like the answer to the problem. Thanks friends
21:57:06.366: CPU Name: Intel(R) Core(TM) i3-9100F CPU @ 3.60GHz
21:57:06.366: CPU Speed: 3600MHz
21:57:06.366: Physical Cores: 4, Logical Cores: 4
21:57:06.366: Physical Memory: 16317MB Total, 10625MB Free
21:57:06.366: Windows Version: 10.0 Build 19043 (release: 2009; revision: 1348; 64-bit)
21:57:06.366: Running as administrator: false
21:57:06.366: Aero is Enabled (Aero is always on for windows 8 and above)
21:57:06.366: Windows 10 Gaming Features:
21:57:06.366: Game DVR: On
21:57:06.369: Sec. Software Status:
21:57:06.370: Norton Security: enabled (AV)
21:57:06.372: Microsoft Defender Antivirus: disabled (AV)
21:57:06.372: Norton Security: enabled (FW)
21:57:06.372: Windows Firewall: disabled (FW)
21:57:06.373: Current Date/Time: 2021-11-25, 21:57:06
21:57:06.373: Browser Hardware Acceleration: true
21:57:06.373: Portable mode: false
21:57:06.610: OBS 27.1.1 (64-bit, windows)
21:57:06.610: ---------------------------------
21:57:06.659: ---------------------------------
21:57:06.659: audio settings reset:
21:57:06.659: samples per sec: 48000
21:57:06.659: speakers: 2
21:57:06.684: ---------------------------------
21:57:06.684: Initializing D3D11...
21:57:06.685: Available Video Adapters:
21:57:06.687: Adapter 0: NVIDIA GeForce GT 1030
21:57:06.687: Dedicated VRAM: 2078531584
21:57:06.687: Shared VRAM: 4259995648
21:57:06.687: PCI ID: 10de:1d01
21:57:06.687: Driver Version: 30.0.14.7212
21:57:06.687: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=60, name=2436
21:57:06.691: Loading up D3D11 on adapter NVIDIA GeForce GT 1030 (0)
21:57:06.772: D3D11 loaded successfully, feature level used: b000
21:57:06.772: DXGI increase maximum frame latency success
21:57:06.772: D3D11 GPU priority setup failed (not admin?)
21:57:07.203: ---------------------------------
21:57:07.203: video settings reset:
21:57:07.203: base resolution: 1920x1080
21:57:07.203: output resolution: 1920x1080
21:57:07.203: downscale filter: Bicubic
21:57:07.203: fps: 60/1
21:57:07.203: format: NV12
21:57:07.203: YUV mode: 709/Partial
21:57:07.203: NV12 texture support enabled
21:57:07.204: Audio monitoring device:
21:57:07.204: name: Default
21:57:07.204: id: default
21:57:07.205: ---------------------------------
21:57:07.205: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
21:57:07.322: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
21:57:07.340: Failed to load 'en-US' text for module: 'decklink-captions.dll'
21:57:07.368: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
21:57:07.477: [AMF] Unable to load 'amfrt64.dll', error code 126.
21:57:07.480: [AMF] AMF Test failed due to one or more errors.
21:57:07.480: Failed to initialize module 'enc-amf.dll'
21:57:07.617: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
21:57:15.919: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
21:57:15.966: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
21:57:16.472: [obs-browser]: Version 2.16.2
21:57:16.472: [obs-browser]: CEF Version 75.1.16+g16a67c4+chromium-75.0.3770.100
21:57:16.817: [noise suppress]: NVIDIA RTX denoiser disabled, redistributable not found
21:57:17.234: Couldn't find VLC installation, VLC video source disabled
21:57:17.284: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
21:57:17.285: No blackmagic support
21:57:17.347: ---------------------------------
21:57:17.347: Loaded Modules:
21:57:17.347: win-wasapi.dll
21:57:17.347: win-mf.dll
21:57:17.347: win-dshow.dll
21:57:17.347: win-decklink.dll
21:57:17.347: win-capture.dll
21:57:17.347: vlc-video.dll
21:57:17.347: text-freetype2.dll
21:57:17.347: rtmp-services.dll
21:57:17.347: obs-x264.dll
21:57:17.347: obs-vst.dll
21:57:17.347: obs-transitions.dll
21:57:17.347: obs-text.dll
21:57:17.347: obs-qsv11.dll
21:57:17.347: obs-outputs.dll
21:57:17.347: obs-filters.dll
21:57:17.347: obs-ffmpeg.dll
21:57:17.347: obs-browser.dll
21:57:17.347: image-source.dll
21:57:17.347: frontend-tools.dll
21:57:17.347: enc-amf.dll
21:57:17.347: decklink-ouput-ui.dll
21:57:17.347: decklink-captions.dll
21:57:17.347: coreaudio-encoder.dll
21:57:17.348: ==== Startup complete ===============================================
21:57:17.353: All scene data cleared
21:57:17.354: ------------------------------------------------
21:57:17.376: [WASAPISource::TryInitialize]:[Speakers (HECATE G2 GAMING HEADSET)] Failed to activate client context: 88890004
21:57:17.377: [WASAPISource::WASAPISource] Device '{0.0.0.00000000}.{742bfb72-eeca-4b45-a880-2fce8242c691}' not found. Waiting for device
21:57:17.377: [Loaded global audio device]: 'Desktop Audio'
21:57:17.378: [WASAPISource::TryInitialize]:[Microphone (HECATE G2 GAMING HEADSET)] Failed to activate client context: 88890004
21:57:17.378: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{f4913210-31f4-4a25-b59c-c6465846f60f}' not found. Waiting for device
21:57:17.378: [Loaded global audio device]: 'Mic/Aux'
21:57:18.076: [duplicator-monitor-capture: 'miNECRAFT'] update settings:
21:57:18.076: display: 1 (1920x1080)
21:57:18.076: cursor: true
21:57:18.076: method: DXGI
21:57:18.107: WASAPI: Device 'Microphone (EDIFIER G2 II GAMING HEADSET)' [48000 Hz] initialized
21:57:18.136: WASAPI: Device 'Speakers (EDIFIER G2 II GAMING HEADSET)' [48000 Hz] initialized
21:57:18.137: [window-capture: 'Chrome'] update settings:
21:57:18.137: executable: chrome.exe
21:57:18.137: method selected: Automatic
21:57:18.137: method chosen: WGC
21:57:18.137:
21:57:18.138: Switched to scene 'Scene'
21:57:18.139: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Audio Input Capture)
21:57:18.139:
21:57:18.146: ------------------------------------------------
21:57:18.146: Loaded scenes:
21:57:18.146: - scene 'Scene':
21:57:18.146: - source: 'Chrome' (window_capture)
21:57:18.146: - source: 'Overwatch w/Jasah & 50%' (game_capture)
21:57:18.146: - source: 'Raft' (game_capture)
21:57:18.146: - source: 'Valorant' (game_capture)
21:57:18.146: - source: 'Game' (wasapi_output_capture)
21:57:18.146: - source: 'Audio Input Capture' (wasapi_input_capture)
21:57:18.146: - source: 'miNECRAFT' (monitor_capture)
21:57:18.146: - source: 'Phasma' (game_capture)
21:57:18.146: - source: 'Rocket' (game_capture)
21:58:20.095: ==== Shutting down ==================================================
21:58:20.100: WASAPI: Device 'Speakers (EDIFIER G2 II GAMING HEADSET)' Terminated
21:58:20.103: WASAPI: Device 'Microphone (EDIFIER G2 II GAMING HEADSET)' Terminated
21:58:20.107: All scene data cleared
21:58:20.107: ------------------------------------------------
21:58:20.164: [Scripting] Total detached callbacks: 0
21:58:20.164: Freeing OBS context data
21:58:20.184: == Profiler Results =============================
21:58:20.184: run_program_init: 12104.8 ms
21:58:20.185: ┣OBSApp::AppInit: 20.602 ms
21:58:20.185: ┃ ┗OBSApp::InitLocale: 1.959 ms
21:58:20.185: ┗OBSApp::OBSInit: 11893.2 ms
21:58:20.185: ┣obs_startup: 7.083 ms
21:58:20.185: ┗OBSBasic::OBSInit: 11600 ms
21:58:20.185: ┣OBSBasic::InitBasicConfig: 0.498 ms
21:58:20.185: ┣OBSBasic::ResetAudio: 0.143 ms
21:58:20.185: ┣OBSBasic::ResetVideo: 544.766 ms
21:58:20.185: ┣OBSBasic::InitOBSCallbacks: 0.006 ms
21:58:20.185: ┣OBSBasic::InitHotkeys: 0.042 ms
21:58:20.185: ┣obs_load_all_modules: 10142.4 ms
21:58:20.185: ┃ ┣obs_init_module(coreaudio-encoder.dll): 1.349 ms
21:58:20.185: ┃ ┣obs_init_module(decklink-captions.dll): 0.022 ms
21:58:20.185: ┃ ┣obs_init_module(decklink-ouput-ui.dll): 0.558 ms
21:58:20.185: ┃ ┣obs_init_module(enc-amf.dll): 71.76 ms
21:58:20.185: ┃ ┣obs_init_module(frontend-tools.dll): 4.673 ms
21:58:20.185: ┃ ┣obs_init_module(image-source.dll): 0.006 ms
21:58:20.185: ┃ ┣obs_init_module(obs-browser.dll): 0.352 ms
21:58:20.185: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.407 ms
21:58:20.185: ┃ ┃ ┗nvenc_check: 0.387 ms
21:58:20.185: ┃ ┣obs_init_module(obs-filters.dll): 0.079 ms
21:58:20.185: ┃ ┣obs_init_module(obs-outputs.dll): 0.014 ms
21:58:20.185: ┃ ┣obs_init_module(obs-qsv11.dll): 104.06 ms
21:58:20.185: ┃ ┣obs_init_module(obs-text.dll): 0.297 ms
21:58:20.185: ┃ ┣obs_init_module(obs-transitions.dll): 0.01 ms
21:58:20.185: ┃ ┣obs_init_module(obs-vst.dll): 0.003 ms
21:58:20.185: ┃ ┣obs_init_module(obs-x264.dll): 0.003 ms
21:58:20.185: ┃ ┣obs_init_module(rtmp-services.dll): 7.271 ms
21:58:20.185: ┃ ┣obs_init_module(text-freetype2.dll): 0.253 ms
21:58:20.185: ┃ ┣obs_init_module(vlc-video.dll): 0.052 ms
21:58:20.185: ┃ ┣obs_init_module(win-capture.dll): 6.136 ms
21:58:20.185: ┃ ┣obs_init_module(win-decklink.dll): 1.685 ms
21:58:20.185: ┃ ┣obs_init_module(win-dshow.dll): 3.264 ms
21:58:20.185: ┃ ┣obs_init_module(win-mf.dll): 0 ms
21:58:20.185: ┃ ┣obs_init_module(win-wasapi.dll): 0.008 ms
21:58:20.185: ┃ ┗reset_win32_symbol_paths: 0.225 ms
21:58:20.185: ┣OBSBasic::ResetOutputs: 0.62 ms
21:58:20.185: ┣OBSBasic::CreateHotkeys: 0.044 ms
21:58:20.185: ┣OBSBasic::InitService: 1.426 ms
21:58:20.185: ┣OBSBasic::InitPrimitives: 0.117 ms
21:58:20.185: ┗OBSBasic::Load: 817.726 ms
21:58:20.185: obs_hotkey_thread(25 ms): min=0.004 ms, median=0.006 ms, max=5.987 ms, 99th percentile=0.145 ms, 100% below 25 ms
21:58:20.185: audio_thread(Audio): min=0 ms, median=0.046 ms, max=1.552 ms, 99th percentile=0.267 ms
21:58:20.185: obs_graphics_thread(16.6667 ms): min=0.076 ms, median=0.449 ms, max=744.381 ms, 99th percentile=4.519 ms, 99.9769% below 16.667 ms
21:58:20.185: ┣tick_sources: min=0.001 ms, median=0.188 ms, max=744.291 ms, 99th percentile=2.715 ms
21:58:20.185: ┣output_frame: min=0.064 ms, median=0.132 ms, max=3.009 ms, 99th percentile=0.646 ms
21:58:20.185: ┃ ┗gs_context(video->graphics): min=0.063 ms, median=0.132 ms, max=3.005 ms, 99th percentile=0.645 ms
21:58:20.185: ┃ ┣render_video: min=0.003 ms, median=0.027 ms, max=1.363 ms, 99th percentile=0.158 ms
21:58:20.185: ┃ ┃ ┗render_main_texture: min=0.002 ms, median=0.025 ms, max=1.36 ms, 99th percentile=0.149 ms
21:58:20.185: ┃ ┗gs_flush: min=0.032 ms, median=0.1 ms, max=2.152 ms, 99th percentile=0.481 ms
21:58:20.185: ┗render_displays: min=0 ms, median=0.111 ms, max=6 ms, 99th percentile=0.626 ms
21:58:20.185: =================================================
21:58:20.185: == Profiler Time Between Calls ==================
21:58:20.185: obs_hotkey_thread(25 ms): min=24.636 ms, median=25.91 ms, max=57.891 ms, 23.0931% within ±2% of 25 ms (0% lower, 76.9069% higher)
21:58:20.185: obs_graphics_thread(16.6667 ms): min=0.191 ms, median=16.667 ms, max=744.385 ms, 98.0609% within ±2% of 16.667 ms (1.03878% lower, 0.900277% higher)
21:58:20.199: Number of memory leaks: 0
It's not clear what the issue is. Just posting a log without any information will not make me try to guess what the issue might be.
that's on me sorry about that. Was in a semi rush to get out of the house. This message (see attached) keeps appearing whenever I hit "start recording." We've checked and made sure OBS was fully updated, that my video drivers were up to date, that I had enough RAM to run (never had an issue before but one thread informed me that may be the issue so I checked anyway), and that my storage wasn't full (again unlikely but better safe than sorry). My PC is a budget PC as is probably obvious (student full time) but I've never had an issue running it until I booted today. Any insight or point in the right direction would be amazing!
I literally forgot to attach it im sorry it's been a long day
Hey i have the same problem here. The error message just now apperared now that i have updatet my video drivers (for my AMD RX 5700).
I had no problems before that.
It seems to be working while recording with H265, but that is no option for me, as my video editing software can't work with that.
Update: I found it helping to decrease my max Bitrate. Now OBS can start the recording and create a file that my editing software can work with, but at the Windows can't open the file.
Quiet strange.
