Question / Help Help Streaming - weird problems with animations and lag
Ian Manglaviti
Hi, for the past few days I have been trying to stream on twitch. My internet was bad so I upgraded my package to 100/5. I've tried many different settings in OBS to try to make my stream work without game interruption (csgo) but nothing seems to work. I check my fps and my ping while streaming and everything seems to be fine. The problem is I still get this screen tearing, lagging, and gun/ weapon animations that go all over the place. Its like I have bad frames or ping but I dont?
Build & Internet:
CPU: Intel i5-4690k @ 3.50ghz
RAM: 8.00 gb
Graphics: Nvidia GeForce GTX 780
Download: 100mbps
Upload: 5mbps
Also, something I noted is that my CPU seems to be fine, so I assumed it was my network. To test this, I went into a private match (offline) with bots on CSGO. I was able to stream 1280x720 3500 bit rate with no problems. In all online servers I get the above problems even with 2500 bit rate at 720. I really want to stream and need some help so my gameplay can be smooth!
Thanks for the help!
Log File Below:
https://gist.github.com/8925922bb04a24470cc2
