Question / Help Help setting up OBS for stream
Dlewis933
Any help with this issue would be greatly appreciated. The issue i am having now is with OBS freezing my computer and crashing during streams. Currently i am able to stream for about 5-6 minutes before the program crashes and freezes my computer. What i am trying to do is stream with my Xbox one app do to lack of kinect. After a lot of research i found the OBS system. I have taking all steps in assuring that my computer can run both programs and stream, however when the OBS crash report( i am including below ) comes up and i analyse it is telling me to use window capture instead of monitor capture and disable Aero (which is a greyed out box).I have run the OBS system recommendations for my computer setup and changed all settings to what was recommended,however no change. I have been working on this program for 3 days now and i am no closer to streaming then i was before OBS. Thank you to all who can help me. I would love to start streaming ASAP!
My last crash report;
https://gist.github.com/e5c198405090e2c34603
Don't listen to the analyzer.
And that log is NOT a crash report.
You can't game capture or window capture metro apps like the xbox app. you MUST use display/monitor capture in order to capture them AT ALL.
That's what i was told by fellow streamers, but that does not really help me to fix my issue. Monitor capture works great and i got my widgets working with it as well but it still crashes. Do you have a recommended settings that would maybe stop the program from crashing? I have tried uninstalling and reinstalling OBS however that did not help either.
