Help! Setting Up NDI
DatGuyCrank
Hi there! Recently I set up a NDI between my streaming pc and gaming pc. But I have been getting some delay :(
I am trying to record and stream at 1080 60fps. But people have mentioned that you need 100+ MBS between both your computers to achieve that.
Currently my task manager says my network is maxing out at 130mbs. However, both my pc's achieved a internet speed test of 500mbs + download and upload.
Both my network adapters are set to 1gbs and I am running cat 5e and some cat 6 cables across the network.
My goal is to get more network speed between my two pc's. Anything past 200mbs would be great so that I can record and stream.
Below I posted a picture of my current network setup. Are my network switches holding me back?
I am very novice at all of this I have it set up at my house to just work. Everything for the most part has been plug and play. Any help is greatly appreciated thanks you!
FzbVurt
Just an update I recently ran iperf to check the connection between my two pc's these where the results.
Still trying to figure out how to get past 100mbs in bandwidth while using NDI.
On both computer you have same workgroup ?
Disable firewall.
NDI For 1080p60 speed 125Mb/s. More info about NDI you can find on newtek site.
Hello, i also only have the dot on the corner.
The computer-source shows listed in the second computer,
when selected, the small dot in ther corner shows
I have follow all the advices youtube and forums have:
  • re-install latest version OBS in both
  • re-install latest version NDI TOOLS in both
  • re-install latest version of NDI-OBS.DLL in both
  • ndi dll placed a plugin folder in both
  • activate NDI in main game computer (output and preview)
  • disable firewall in both
  • create an exception in firewall in both
  • disable anti-virus in both
  • create and exception in AVG in both
still not working
the first time i install ndi for obs did worked perfectly
i change the c disk from mechanical to ssd and re-installed windows 7
is there something i am missing?
