Question / Help Help Setting for 480P twitch (low upload speed)
Juaner
Hi
I'm from Colombia and the max Upload Speed you can get here is 1MG (unless u are a company) so with that speed i want to Stream in Twitch at 480p (i think is the best quality I can get with that upload speed)
My PC is: Intel i7 2600
14 Gb RAM
Nvidia 560ti
Internet: 7MG Download Speed 1Mg upload Speed
how do i configure OBS to stream league of legends at 480p? (i also want to stream Plants Vs ZOmbies garden warfare, Cities Skyline and Gnomoria)
help me please T_T
Edit:
My preference in OBS
In enconder i put: Use CBR check
Bitrate 700 kb/s
Audio AAC 48kHz Bitrate 64 Stereo
In VIDEO: Base resolution 1920 x 1080
Scale video to: 852x480
25 FPS
In Advanced
check Use Multithread optimizations
Process priority class Normal
Scene Buffering time 700
Allow other modifers on hotkey check
x264 CPU preset Slower
Encoding profile Main
Keyframe interval 2
Use CFR check
i'm making any mistakes?
what i get playing Plants vs ZOmbies garden warfare
700 bit rate
try changing the preset till you feel your lagging or losing frames
higher preset reduces the amount of bityou need to upload as you pre render it for veiwers
Juaner
Bitrate 700 kb/s
25 FPS
In Advanced
Keyframe interval 2
Use CFR check
thats what i get when playign Plants vs Zombies garden warfare
dping
Bitrate 700 kb/s
25 FPS
In Advanced
Keyframe interval 2
Use CFR check
at 480p25fps slower should be fine for an i7
lower your audio bitrate to 64 or 96kb/s then use that little bit to go into your main bitrate.
audio and video bitrate are separate so if audio bitrate was 128kb/s and you change it to 64kb/s then add 64kb/s to your main bitrate, i.e. bitrate and buffer set to 764kb/s.
every little bit helps at this low rate :D
Juaner
yeah wirless, well i will not stream online games.. T_T when i stream singleplayer games like FEZ it streams well!
the strange part is that i had saw some streamers from colombia in twitch streaming league of legends... i dont know how they do it. cause i have ask and any internet company at colombia sells more upload speed than 1MG unless u r a company...
dping
connect your pc to the router from a cable, not wireless. it will make what little connection you have, worse with wireless.
