Question / Help HELP! Quality help. (Logs are posted )
OliverAK
So I was testing my stream seeing how far my computer can handle. I noticed that my stream starts to pixalize when I move my character around.
OBS LOG : http://pastebin.com/R3LX2YHS
VOD : http://www.twitch.tv/loneoliver/b/564504557
OBS : 60FPS 1920x1080 Downscale 1.25 to 1536x864 Filter : Lanczos
x264 CBR
Bitrate : 3400 kb/s No custom buffer size.
AAC Bitrate :128
x264 CPU present : veryfast
Computer :
Processor: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.8GHz
RAM : 16GB
GPU: NVIDIA GeForce GTX 560 2GB
Internet : http://www.speedtest.net/my-result/3731639070
Boildown
13:55:55: Total frames encoded: 34884, total frames duplicated: 1370 (3.93%)
13:55:55: Number of frames skipped due to encoder lag: 70 (0.20%)
13:55:55: Total frames rendered: 34610, number of late frames: 129 (0.37%) (it's okay for some frames to be late)
The total frames duplicate: is something you want to be less than 1% to have a good looking stream. Since yours is too high, nearly 4%, you need to reduce your stream settings. I suggest a larger downscale (like 1.5) for a smaller stream, and lower FPS, like 30 instead of 60.
Then look at your log file and see if the total frames duplicated is less than 1%. If it is, your stream should look much improved. If it is not, then come back here for more help.
alpinlol
lower your downscale 720p60 should be fine probably consider going with 30 fps since its only an i5 but obviously its depending on the game you play if its heavy taxing on your cpu or not
