Question / Help Help Please. Audio Issue.
LssTz
Hello.
Before looking at the log files please read the following.
I've streamed before in the past no problem. But this was when I had 3Mbs Upload and a headset with a noise cancellation Mic. Now my Headset has broke so I'm using my 'Gummy JVC Earphones' and my built in Webcam Mic, sound quality isn't bad just not as good as I would like. I'm getting a new headset soon, Corsair Raptor HS40 USB 7.1 Gaming Headset.
Now here are my PC specs, internet and gear.
CPU - AMD FX-4100 QuadCore O/C'd @4GHz (Upgrading to FX-8350 8 Core with Arctic Cooling Freezer A30 CPU Cooler)
GPU - Radeon HD 6790 1GB (Upgrading to MSI Radeon R9 270X Gaming 2G AMD Graphics Card - 2GB)
RAM - 8GB Dual Channel @1333mhz (Upgrading to 16GB Dual Channel @1666mhz)
Rest doesn't matter to much. (If you want to know the rest visit my Twitch page http://www.twitch.tv/LssTz)
I am using JVC Gummy Earphones, Logitech C270 as my Webcam and Mic. Razer Arctosa and Razer Abyssus. Now my internet is awful, I use to be on Virgin Media getting 3mbs Upload and 50-60mbs Download. Now I get 10-15mbs Download and 0.8-1.2mbs Upload on Sky Broadband, now I can still stream perfectly fine on 480p with 600-800 bitrate and 25fps. Planning on upgrading internet in the future if streaming works out.
Now the problem I'm having is in the stream the audio from my Webcam Mic is coming through fine, not a single problem there. The problem is the game sound (Minecraft, COD... Any game) isn't coming through, also the music isn't coming through. You can hear it slightly when I turn it up, but that is my mic picking it up through the earphones. I use Spotify, I have tried VLC, Media Player and many others. I've tried changing the port my Webcam and Earphones are in and that hasn't changed a thing, I've messed around with settings and googled this issue. I can't find anything anywhere :/
Log files: (Not too sure which ones you want so here's a few from yesterday)
12:40:27: Settings::Video: Enabling Aero
12:43:43: Open Broadcaster Software v0.59b - 64bit ( ^ω^)
12:43:43: -------------------------------
12:43:43: CPU Name: AMD FX(tm)-4100 Quad-Core Processor
12:43:43: CPU Speed: 4018MHz
12:43:43: Physical Memory: 8174MB Total, 5566MB Free
12:43:43: stepping id: 2, model 1, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 2
12:43:43: monitor 1: pos={-1280, 56}, size={1280, 1024}
12:43:43: monitor 2: pos={0, 0}, size={1920, 1080}
12:43:43: Windows Version: 6.1 Build 7601 S
12:43:43: Aero is Disabled
12:43:43: OBS Modules:
12:43:43: Base Address Module
12:43:43: 000000003F200000 OBS.exe
12:43:43: 00000000E0E80000 OBSApi.dll
12:43:43: 00000000F50F0000 DShowPlugin.dll
12:43:43: 00000000FB070000 GraphicsCapture.dll
12:43:43: 00000000FB360000 NoiseGate.dll
12:43:43: 00000000FA950000 PSVPlugin.dll
12:43:43: ------------------------------------------
12:43:43: Adapter 1
12:43:43: Video Adapter: AMD Radeon HD 6700 Series
12:43:43: Video Adapter Dedicated Video Memory: 1060859904
12:43:43: Video Adapter Shared System Memory: 4017156096
12:43:43: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
12:43:43: Video Adapter Output 2: pos={-1280, 56}, size={1280, 1024}, attached=true
12:43:43: =====Stream Start: 2013-12-16, 12:43:43===============================================
12:43:43: Multithreaded optimizations: On
12:43:43: Base resolution: 1920x1080
12:43:43: Output resolution: 852x480
12:43:43: Loading up D3D10 on AMD Radeon HD 6700 Series...
12:43:43: Audio Format: 44100hz
12:43:43: Playback device Default
12:43:43: Using desktop audio input: Microphone (USB Audio Device)
12:43:43: Using auxilary audio input: Microphone (USB Audio Device)
12:43:43: Audio Encoding: AAC
12:43:43: bitrate: 128
12:43:43: device: Logitech HD Webcam C270,
12:43:43: device id \\?\usb#vid_046d&pid_0825&mi_00#6&fadec2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
12:43:43: chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000
12:43:43: use buffering: false - 0, fourCC: 'I420'
12:43:43: audio device: Disable,
12:43:43: audio device id Disabled,
12:43:43:
12:43:43: Using directshow input
12:43:43: Using graphics capture
12:43:44: Scene buffering time set to 400
12:43:44: ------------------------------------------
12:43:44: Video Encoding: x264
12:43:44: fps: 25
12:43:44: width: 852, height: 480
12:43:44: preset: veryfast
12:43:44: profile: high
12:43:44: keyint: 50
12:43:44: CBR: yes
12:43:44: CFR: yes
12:43:44: max bitrate: 900
12:43:44: buffer size: 900
12:43:44: MMDeviceAudioSource: Frequency for device 'Microphone (USB Audio Device)' is 192000, samples per sec is 48000
12:44:09: Using Monitor Capture
12:44:20: Using Monitor Capture
12:44:42: Using Monitor Capture
12:45:16: Using text output
12:45:41: Using text output
12:48:29: Total frames encoded: 7095, total frames duplicated: 113 (1.59%)
12:48:29: Total frames rendered: 7097, number of late frames: 1 (0.01%) (it's okay for some frames to be late)
12:48:29:
12:48:29: Profiler time results:
12:48:29:
12:48:29: ==============================================================
12:48:29: video thread frame - [100%] [avg time: 2.461 ms] [children: 61.7%] [unaccounted: 38.3%]
12:48:29: | scene->Preprocess - [56.4%] [avg time: 1.389 ms]
12:48:29: | GPU download and conversion - [5.28%] [avg time: 0.13 ms] [children: 4.51%] [unaccounted: 0.772%]
12:48:29: | | flush - [3.62%] [avg time: 0.089 ms]
12:48:29: | | CopyResource - [0.488%] [avg time: 0.012 ms]
12:48:29: | | conversion to 4:2:0 - [0.406%] [avg time: 0.01 ms]
12:48:29: Convert444Thread - [100%] [avg time: 0.68 ms] [children: 99.4%] [unaccounted: 0.588%]
12:48:29: | Convert444toNV12 - [99.4%] [avg time: 0.676 ms]
12:48:29: encoder thread frame - [100%] [avg time: 0.898 ms]
12:48:29:
12:48:29:
12:48:29: Profiler CPU results:
12:48:29:
12:48:29: video thread frame - [cpu time: avg 0.877 ms, total 6224.44 ms] [avg calls per frame: 1]
12:48:29: | scene->Preprocess - [cpu time: avg 0.589 ms, total 4180.83 ms] [avg calls per frame: 1]
12:48:29: | GPU download and conversion - [cpu time: avg 0.024 ms, total 171.6 ms] [avg calls per frame: 1]
12:48:29: | | flush - [cpu time: avg 0.013 ms, total 93.6 ms] [avg calls per frame: 1]
12:48:29: | | CopyResource - [cpu time: avg 0.002 ms, total 15.6 ms] [avg calls per frame: 1]
12:48:29: | | conversion to 4:2:0 - [cpu time: avg 0.002 ms, total 15.6 ms] [avg calls per frame: 1]
12:48:29: Convert444Thread - [cpu time: avg 0.832 ms, total 5896.84 ms] [avg calls per frame: 1]
12:48:29: | Convert444toNV12 - [cpu time: avg 0.83 ms, total 5881.24 ms] [avg calls per frame: 1]
12:48:29: encoder thread frame - [cpu time: avg 0.05 ms, total 358.802 ms] [avg calls per frame: 1]
12:48:29:
12:48:29: =====Stream End: 2013-12-16, 12:48:29=================================================
15:12:34: Open Broadcaster Software v0.59b - 64bit ( ^ω^)
15:12:34: -------------------------------
15:12:34: CPU Name: AMD FX(tm)-4100 Quad-Core Processor
15:12:34: CPU Speed: 4018MHz
15:12:34: Physical Memory: 8174MB Total, 6645MB Free
15:12:34: stepping id: 2, model 1, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 2
15:12:34: monitor 1: pos={-1280, 56}, size={1280, 1024}
15:12:34: monitor 2: pos={0, 0}, size={1920, 1080}
15:12:34: Windows Version: 6.1 Build 7601 S
15:12:34: Aero is Disabled
15:12:34: OBS Modules:
15:12:34: Base Address Module
15:12:34: 000000003F9A0000 OBS.exe
15:12:34: 00000000E0450000 OBSApi.dll
15:12:34: 00000000FADD0000 DShowPlugin.dll
15:12:34: 00000000F5160000 GraphicsCapture.dll
15:12:34: 00000000FA950000 NoiseGate.dll
15:12:34: 00000000F7C70000 PSVPlugin.dll
15:12:34: ------------------------------------------
15:12:34: Adapter 1
15:12:34: Video Adapter: AMD Radeon HD 6700 Series
15:12:34: Video Adapter Dedicated Video Memory: 1060859904
15:12:34: Video Adapter Shared System Memory: 4017156096
15:12:34: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:12:34: Video Adapter Output 2: pos={-1280, 56}, size={1280, 1024}, attached=true
15:12:34: =====Stream Start: 2013-12-16, 15:12:34===============================================
15:12:34: Multithreaded optimizations: On
15:12:34: Base resolution: 1920x1080
15:12:34: Output resolution: 852x480
15:12:34: Loading up D3D10 on AMD Radeon HD 6700 Series...
15:12:34: Audio Format: 44100hz
15:12:34: Playback device Default
15:12:34: Using desktop audio input: Microphone (USB Audio Device)
15:12:35: ------------------------------------------
15:12:35: Using auxilary audio input: Microphone (USB Audio Device)
15:12:35: Audio Encoding: AAC
15:12:35: bitrate: 128
15:12:35: Using text output
15:12:35: device: Logitech HD Webcam C270,
15:12:35: device id \\?\usb#vid_046d&pid_0825&mi_00#6&fadec2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:12:35: chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000
15:12:35: use buffering: false - 0, fourCC: 'I420'
15:12:35: audio device: Disable,
15:12:35: audio device id Disabled,
15:12:35:
15:12:35: Using directshow input
15:12:35: Using graphics capture
15:12:36: Scene buffering time set to 400
15:12:36: ------------------------------------------
15:12:36: Video Encoding: x264
15:12:36: fps: 25
15:12:36: width: 852, height: 480
15:12:36: preset: veryfast
15:12:36: profile: high
15:12:36: keyint: 50
15:12:36: CBR: yes
15:12:36: CFR: yes
15:12:36: max bitrate: 900
15:12:36: buffer size: 900
15:12:36: MMDeviceAudioSource: Frequency for device 'Microphone (USB Audio Device)' is 192000, samples per sec is 48000
15:12:55: Total frames encoded: 456, total frames duplicated: 0 (0.00%)
15:12:55: Total frames rendered: 460, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
15:12:55:
15:12:55: Profiler time results:
15:12:55:
15:12:55: ==============================================================
15:12:55: video thread frame - [100%] [avg time: 0.999 ms] [children: 50.1%] [unaccounted: 49.9%]
15:12:55: | scene->Preprocess - [18.9%] [avg time: 0.189 ms]
15:12:55: | GPU download and conversion - [31.1%] [avg time: 0.311 ms] [children: 29.2%] [unaccounted: 1.9%]
15:12:55: | | flush - [25.8%] [avg time: 0.258 ms]
15:12:55: | | CopyResource - [2.9%] [avg time: 0.029 ms]
15:12:55: | | conversion to 4:2:0 - [0.501%] [avg time: 0.005 ms]
15:12:55: Convert444Thread - [100%] [avg time: 0.775 ms] [children: 99.5%] [unaccounted: 0.516%]
15:12:55: | Convert444toNV12 - [99.5%] [avg time: 0.771 ms]
15:12:55: encoder thread frame - [100%] [avg time: 0.778 ms]
15:12:55:
15:12:55:
15:12:55: Profiler CPU results:
15:12:55:
15:12:55: video thread frame - [cpu time: avg 0.271 ms, total 124.8 ms] [avg calls per frame: 1]
15:12:55: | scene->Preprocess - [cpu time: avg 0.033 ms, total 15.6 ms] [avg calls per frame: 1]
15:12:55: | GPU download and conversion - [cpu time: avg 0.033 ms, total 15.6 ms] [avg calls per frame: 1]
15:12:55: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:12:55: | | CopyResource - [cpu time: avg 0.034 ms, total 15.6 ms] [avg calls per frame: 1]
15:12:55: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:12:55: Convert444Thread - [cpu time: avg 0.663 ms, total 296.401 ms] [avg calls per frame: 1]
15:12:55: | Convert444toNV12 - [cpu time: avg 0.663 ms, total 296.401 ms] [avg calls per frame: 1]
15:12:55: encoder thread frame - [cpu time: avg 0.104 ms, total 46.8 ms] [avg calls per frame: 1]
15:12:55:
15:12:55: =====Stream End: 2013-12-16, 15:12:55=================================================
15:12:55: Using fixed low latency mode, factor 20
15:12:55: =====Stream Start: 2013-12-16, 15:12:55===============================================
15:12:55: Multithreaded optimizations: On
15:12:55: Base resolution: 1920x1080
15:12:55: Output resolution: 852x480
15:12:55: ------------------------------------------
15:12:55: Loading up D3D10 on AMD Radeon HD 6700 Series...
15:12:55: Audio Format: 44100hz
15:12:55: Playback device Default
15:12:55: Using desktop audio input: Microphone (USB Audio Device)
15:12:55: Using auxilary audio input: Microphone (USB Audio Device)
15:12:55: Audio Encoding: AAC
15:12:55: bitrate: 128
15:12:55: Using text output
15:12:55: device: Logitech HD Webcam C270,
15:12:55: device id \\?\usb#vid_046d&pid_0825&mi_00#6&fadec2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:12:55: chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000
15:12:55: use buffering: false - 0, fourCC: 'I420'
15:12:55: audio device: Disable,
15:12:55: audio device id Disabled,
15:12:55:
15:12:56: Using directshow input
15:12:56: Using graphics capture
15:12:56: Scene buffering time set to 400
15:12:56: ------------------------------------------
15:12:56: Video Encoding: x264
15:12:56: fps: 25
15:12:56: width: 852, height: 480
15:12:56: preset: veryfast
15:12:56: profile: high
15:12:56: keyint: 50
15:12:56: CBR: yes
15:12:56: CFR: yes
15:12:56: max bitrate: 900
15:12:56: buffer size: 900
15:12:56: MMDeviceAudioSource: Frequency for device 'Microphone (USB Audio Device)' is 192000, samples per sec is 48000
15:12:58: Using RTMP service: Twitch / Justin.tv
15:12:58: Server selection: rtmp://live-lhr.justin.tv/app
15:12:58: Interface: 802.11n Wireless LAN Card (802.11, 182 mbps)
15:12:59: Completed handshake with rtmp://live-lhr.justin.tv/app in 402 ms.
15:13:00: SO_SNDBUF was at 8192
15:13:00: SO_SNDBUF is now 65536
15:13:37: Total frames encoded: 988, total frames duplicated: 22 (2.23%)
Warning -- GraphicsCaptureSource::BeginScene: Failed to inject library, GetLastError = 2
15:13:38: Total frames rendered: 982, number of late frames: 3 (0.31%) (it's okay for some frames to be late)
15:13:38: RTMPPublisher::SocketLoop: Graceful loop exit
15:13:39: Average send payload: 7001 bytes, average send interval: 69 ms
15:13:39: Number of times waited to send: 225, Waited for a total of 709408 bytes
15:13:39: Number of b-frames dropped: 99 (11%), Number of p-frames dropped: 74 (8.1%), Total 173 (19%)
15:13:39: Number of bytes sent: 3815634
15:13:39:
15:13:39: Profiler time results:
15:13:39:
15:13:39: ==============================================================
15:13:39: video thread frame - [100%] [avg time: 5.066 ms] [children: 23.8%] [unaccounted: 76.2%]
15:13:39: | scene->Preprocess - [4.32%] [avg time: 0.219 ms]
15:13:39: | GPU download and conversion - [19.5%] [avg time: 0.986 ms] [children: 12.7%] [unaccounted: 6.75%]
15:13:39: | | flush - [12.2%] [avg time: 0.62 ms]
15:13:39: | | CopyResource - [0.415%] [avg time: 0.021 ms]
15:13:39: | | conversion to 4:2:0 - [0.0592%] [avg time: 0.003 ms]
15:13:39: Convert444Thread - [100%] [avg time: 0.768 ms] [children: 99%] [unaccounted: 1.04%]
15:13:39: | Convert444toNV12 - [99%] [avg time: 0.76 ms]
15:13:39: encoder thread frame - [100%] [avg time: 1.063 ms]
15:13:39:
15:13:39:
15:13:39: Profiler CPU results:
15:13:39:
15:13:39: video thread frame - [cpu time: avg 0.635 ms, total 624.004 ms] [avg calls per frame: 1]
15:13:39: | scene->Preprocess - [cpu time: avg 0.047 ms, total 46.801 ms] [avg calls per frame: 1]
15:13:39: | GPU download and conversion - [cpu time: avg 0.142 ms, total 140.401 ms] [avg calls per frame: 1]
15:13:39: | | flush - [cpu time: avg 0.063 ms, total 62.4 ms] [avg calls per frame: 1]
15:13:39: | | CopyResource - [cpu time: avg 0.032 ms, total 31.2 ms] [avg calls per frame: 1]
15:13:39: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
15:13:39: Convert444Thread - [cpu time: avg 0.741 ms, total 717.604 ms] [avg calls per frame: 1]
15:13:39: | Convert444toNV12 - [cpu time: avg 0.725 ms, total 702.003 ms] [avg calls per frame: 1]
15:13:39: encoder thread frame - [cpu time: avg 0.159 ms, total 156.001 ms] [avg calls per frame: 1]
15:13:39:
15:13:39: =====Stream End: 2013-12-16, 15:13:39=================================================
15:14:07: Using fixed low latency mode, factor 20
15:14:07: =====Stream Start: 2013-12-16, 15:14:07===============================================
15:14:07: Multithreaded optimizations: On
15:14:07: Base resolution: 1920x1080
15:14:07: Output resolution: 852x480
15:14:07: ------------------------------------------
15:14:07: Loading up D3D10 on AMD Radeon HD 6700 Series...
15:14:07: Audio Format: 44100hz
15:14:07: Playback device Default
15:14:07: Using desktop audio input: Microphone (USB Audio Device)
15:14:07: Using auxilary audio input: Microphone (USB Audio Device)
15:14:07: Audio Encoding: AAC
15:14:07: bitrate: 128
15:14:07: Using text output
15:14:07: device: Logitech HD Webcam C270,
15:14:07: device id \\?\usb#vid_046d&pid_0825&mi_00#6&fadec2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
15:14:07: chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000
15:14:07: use buffering: false - 0, fourCC: 'I420'
15:14:07: audio device: Disable,
15:14:07: audio device id Disabled,
15:14:07:
15:14:07: Using directshow input
15:14:07: Using graphics capture
15:14:08: Scene buffering time set to 400
15:14:08: ------------------------------------------
15:14:08: Video Encoding: x264
15:14:08: fps: 25
15:14:08: width: 852, height: 480
15:14:08: preset: veryfast
15:14:08: profile: high
15:14:08: keyint: 50
15:14:08: CBR: yes
15:14:08: CFR: yes
15:14:08: max bitrate: 800
15:14:08: buffer size: 800
15:14:08: MMDeviceAudioSource: Frequency for device 'Microphone (USB Audio Device)' is 192000, samples per sec is 48000
15:14:10: Using RTMP service: Twitch / Justin.tv
15:14:10: Server selection: rtmp://live-lhr.justin.tv/app
15:14:10: Interface: 802.11n Wireless LAN Card (802.11, 186 mbps)
15:14:10: Completed handshake with rtmp://live-lhr.justin.tv/app in 390 ms.
15:14:11: SO_SNDBUF was at 8192
15:14:11: SO_SNDBUF is now 65536
15:14:25: SharedTexCapture hooked
15:14:33: GraphicsCaptureSource::NewCapture: eliminating old capture
15:14:33: SharedTexCapture hooked
15:15:19: Using Window Capture
15:15:37: Using Window Capture
15:15:53: Using Window Capture
15:45:31: RTMPPublisher::SocketLoop: Received FD_CLOSE, 5000 ms since last send (buffer: 129937 / 131072)
15:45:31: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
15:45:32: Total frames encoded: 47075, total frames duplicated: 195 (0.41%)
15:45:32: Number of frames skipped due to encoder lag: 9 (0.02%)
15:45:32: Total frames rendered: 46991, number of late frames: 30 (0.06%) (it's okay for some frames to be late)
15:45:32: Average send payload: 6238 bytes, average send interval: 55 ms
15:45:32: Number of times waited to send: 3232, Waited for a total of 10075058 bytes
15:45:32: Number of b-frames dropped: 364 (0.77%), Number of p-frames dropped: 605 (1.3%), Total 969 (2.1%)
15:45:32: Number of bytes sent: 208905848
15:45:32:
15:45:32: Profiler time results:
15:45:32:
15:45:32: ==============================================================
15:45:32: video thread frame - [100%] [avg time: 2.2 ms] [children: 40.8%] [unaccounted: 59.2%]
15:45:32: | scene->Preprocess - [23.2%] [avg time: 0.511 ms]
15:45:32: | GPU download and conversion - [17.6%] [avg time: 0.387 ms] [children: 11.8%] [unaccounted: 5.77%]
15:45:32: | | flush - [10.8%] [avg time: 0.237 ms]
15:45:32: | | CopyResource - [0.773%] [avg time: 0.017 ms]
15:45:32: | | conversion to 4:2:0 - [0.273%] [avg time: 0.006 ms]
15:45:32: Convert444Thread - [100%] [avg time: 0.712 ms] [children: 98.9%] [unaccounted: 1.12%]
15:45:32: | Convert444toNV12 - [98.9%] [avg time: 0.704 ms]
15:45:32: encoder thread frame - [100%] [avg time: 0.778 ms]
15:45:32:
15:45:32:
15:45:32: Profiler CPU results:
15:45:32:
15:45:32: video thread frame - [cpu time: avg 0.91 ms, total 42791.1 ms] [avg calls per frame: 1]
15:45:32: | scene->Preprocess - [cpu time: avg 0.197 ms, total 9282.07 ms] [avg calls per frame: 1]
15:45:32: | GPU download and conversion - [cpu time: avg 0.073 ms, total 3463.22 ms] [avg calls per frame: 1]
15:45:32: | | flush - [cpu time: avg 0.034 ms, total 1606.81 ms] [avg calls per frame: 1]
15:45:32: | | CopyResource - [cpu time: avg 0.011 ms, total 530.402 ms] [avg calls per frame: 1]
15:45:32: | | conversion to 4:2:0 - [cpu time: avg 0.004 ms, total 218.401 ms] [avg calls per frame: 1]
15:45:32: Convert444Thread - [cpu time: avg 0.551 ms, total 25927.4 ms] [avg calls per frame: 1]
15:45:32: | Convert444toNV12 - [cpu time: avg 0.547 ms, total 25740.2 ms] [avg calls per frame: 1]
15:45:32: encoder thread frame - [cpu time: avg 0.071 ms, total 3385.22 ms] [avg calls per frame: 1]
15:45:32:
15:45:32: =====Stream End: 2013-12-16, 15:45:32=================================================
15:45:42: Using fixed low latency mode, factor 20
15:45:42: =====Stream Start: 2013-12-16, 15:45:42===============================================
15:45:42: Multithreaded optimizations: On
15:45:42: Base resolution: 1920x1080
15:45:42: Output resolution: 852x480
15:45:42: ------------------------------------------
15:45:42: Loading up D3D10 on AMD Radeon HD 6700 Series...
15:45:42: Audio Format: 44100hz
15:45:42: Playback device {0.0.1.00000000}.{5adc5396-5605-4c51-9a39-0218394cc1f5}
Warning -- MMDeviceAudioSource::Initialize(0): Could not create IAudioClient = 88890004
Error: Cannot initialize desktop audio sound, more info in the log file.
15:46:13: Using fixed low latency mode, factor 20
15:46:13: =====Stream Start: 2013-12-16, 15:46:13===============================================
15:46:13: Multithreaded optimizations: On
15:46:13: Base resolution: 1920x1080
15:46:13: Output resolution: 852x480
15:46:13: ------------------------------------------
15:46:13: Loading up D3D10 on AMD Radeon HD 6700 Series...
15:46:13: Audio Format: 44100hz
15:46:13: Playback device {0.0.1.00000000}.{5adc5396-5605-4c51-9a39-0218394cc1f5}
16:03:55: Open Broadcaster Software v0.59b - 64bit ( ^ω^)
16:03:55: -------------------------------
16:03:55: CPU Name: AMD FX(tm)-4100 Quad-Core Processor
16:03:55: CPU Speed: 4018MHz
16:03:55: Physical Memory: 8174MB Total, 5228MB Free
16:03:55: stepping id: 2, model 1, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 2
16:03:55: monitor 1: pos={-1280, 56}, size={1280, 1024}
16:03:55: monitor 2: pos={0, 0}, size={1920, 1080}
16:03:55: Windows Version: 6.1 Build 7601 S
16:03:55: Aero is Disabled
16:03:55: OBS Modules:
16:03:55: Base Address Module
16:03:55: 000000003F980000 OBS.exe
16:03:55: 00000000E0450000 OBSApi.dll
16:03:55: 00000000FADD0000 DShowPlugin.dll
16:03:55: 00000000FA940000 GraphicsCapture.dll
16:03:55: 00000000F7C70000 NoiseGate.dll
16:03:55: 00000000F5170000 PSVPlugin.dll
16:03:55: ------------------------------------------
16:03:55: Adapter 1
16:03:55: Video Adapter: AMD Radeon HD 6700 Series
16:03:55: Video Adapter Dedicated Video Memory: 1060859904
16:03:55: Video Adapter Shared System Memory: 4017156096
16:03:55: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
16:03:55: Video Adapter Output 2: pos={-1280, 56}, size={1280, 1024}, attached=true
16:03:55: =====Stream Start: 2013-12-16, 16:03:55===============================================
16:03:55: Multithreaded optimizations: On
16:03:55: Base resolution: 1920x1080
16:03:55: Output resolution: 852x480
16:03:55: Loading up D3D10 on AMD Radeon HD 6700 Series...
16:03:56: ------------------------------------------
16:03:56: Audio Format: 44100hz
16:03:56: Playback device Default
16:03:56: Using desktop audio input: Microphone (USB Audio Device)
16:03:56: Using auxilary audio input: Microphone (USB Audio Device)
16:03:56: Audio Encoding: AAC
16:03:56: bitrate: 128
16:03:56: Using text output
16:03:56: device: Logitech HD Webcam C270,
16:03:56: device id \\?\usb#vid_046d&pid_0825&mi_00#6&fadec2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
16:03:56: chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000
16:03:56: use buffering: false - 0, fourCC: 'I420'
16:03:56: audio device: Disable,
16:03:56: audio device id Disabled,
16:03:56:
16:03:56: Using directshow input
16:03:56: Using graphics capture
16:03:57: Scene buffering time set to 400
16:03:57: ------------------------------------------
16:03:57: Video Encoding: x264
16:03:57: fps: 25
16:03:57: width: 852, height: 480
16:03:57: preset: veryfast
16:03:57: profile: high
16:03:57: keyint: 50
16:03:57: CBR: yes
16:03:57: CFR: yes
16:03:57: max bitrate: 800
16:03:57: buffer size: 800
16:03:57: MMDeviceAudioSource: Frequency for device 'Microphone (USB Audio Device)' is 192000, samples per sec is 48000
16:03:57: SharedTexCapture hooked
16:04:01: Total frames encoded: 79, total frames duplicated: 0 (0.00%)
16:04:01: Total frames rendered: 79, number of late frames: 1 (1.27%) (it's okay for some frames to be late)
16:04:02:
16:04:02: Profiler time results:
16:04:02:
16:04:02: ==============================================================
16:04:02: video thread frame - [100%] [avg time: 4.192 ms] [children: 10.3%] [unaccounted: 89.7%]
16:04:02: | scene->Preprocess - [6.06%] [avg time: 0.254 ms]
16:04:02: | GPU download and conversion - [4.22%] [avg time: 0.177 ms] [children: 3.96%] [unaccounted: 0.262%]
16:04:02: | | flush - [3.72%] [avg time: 0.156 ms]
16:04:02: | | CopyResource - [0.191%] [avg time: 0.008 ms]
16:04:02: | | conversion to 4:2:0 - [0.0477%] [avg time: 0.002 ms]
16:04:02: Convert444Thread - [100%] [avg time: 0.632 ms] [children: 99.5%] [unaccounted: 0.475%]
16:04:02: | Convert444toNV12 - [99.5%] [avg time: 0.629 ms]
16:04:02: encoder thread frame - [100%] [avg time: 1.365 ms]
16:04:02:
16:04:02:
16:04:02: Profiler CPU results:
16:04:02:
16:04:02: video thread frame - [cpu time: avg 0.197 ms, total 15.6 ms] [avg calls per frame: 1]
16:04:02: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:04:02: | GPU download and conversion - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:04:02: | | flush - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:04:02: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:04:02: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:04:02: Convert444Thread - [cpu time: avg 1.337 ms, total 93.6 ms] [avg calls per frame: 1]
16:04:02: | Convert444toNV12 - [cpu time: avg 1.337 ms, total 93.6 ms] [avg calls per frame: 1]
16:04:02: encoder thread frame - [cpu time: avg 0.904 ms, total 62.4 ms] [avg calls per frame: 1]
16:04:02:
16:04:02: =====Stream End: 2013-12-16, 16:04:02=================================================
16:04:55: Using fixed low latency mode, factor 20
16:04:55: =====Stream Start: 2013-12-16, 16:04:55===============================================
16:04:55: Multithreaded optimizations: On
16:04:55: Base resolution: 1920x1080
16:04:55: Output resolution: 852x480
16:04:55: ------------------------------------------
16:04:55: Loading up D3D10 on AMD Radeon HD 6700 Series...
16:04:55: Audio Format: 44100hz
16:04:55: Playback device Default
16:04:55: Using desktop audio input: Microphone (USB Audio Device)
16:04:55: Using auxilary audio input: Microphone (USB Audio Device)
16:04:55: Audio Encoding: AAC
16:04:55: bitrate: 128
16:04:55: Using text output
16:04:55: device: Logitech HD Webcam C270,
16:04:55: device id \\?\usb#vid_046d&pid_0825&mi_00#6&fadec2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
16:04:55: chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000
16:04:55: use buffering: false - 0, fourCC: 'I420'
16:04:55: audio device: Disable,
16:04:55: audio device id Disabled,
16:04:55:
16:04:55: Using directshow input
16:04:55: Using graphics capture
16:04:56: Scene buffering time set to 400
16:04:56: ------------------------------------------
16:04:56: Video Encoding: x264
16:04:56: fps: 25
16:04:56: width: 852, height: 480
16:04:56: preset: veryfast
16:04:56: profile: high
16:04:56: keyint: 50
16:04:56: CBR: yes
16:04:56: CFR: yes
16:04:56: max bitrate: 800
16:04:56: buffer size: 800
16:04:56: MMDeviceAudioSource: Frequency for device 'Microphone (USB Audio Device)' is 192000, samples per sec is 48000
16:04:56: SharedTexCapture hooked
16:04:58: Using RTMP service: Twitch / Justin.tv
16:04:58: Server selection: rtmp://live-lhr.justin.tv/app
16:04:58: Interface: 802.11n Wireless LAN Card (802.11, 182 mbps)
16:04:58: Completed handshake with rtmp://live-lhr.justin.tv/app in 406 ms.
16:04:59: SO_SNDBUF was at 8192
16:04:59: SO_SNDBUF is now 65536
16:08:45: Total frames encoded: 5708, total frames duplicated: 26 (0.46%)
16:08:45: Total frames rendered: 5698, number of late frames: 4 (0.07%) (it's okay for some frames to be late)
16:08:46: RTMPPublisher::SocketLoop: Graceful loop exit
16:08:47: Average send payload: 6471 bytes, average send interval: 57 ms
16:08:47: Number of times waited to send: 150, Waited for a total of 472014 bytes
16:08:47: Number of b-frames dropped: 17 (0.3%), Number of p-frames dropped: 69 (1.2%), Total 86 (1.5%)
16:08:47: Number of bytes sent: 25366774
16:08:47:
16:08:47: Profiler time results:
16:08:47:
16:08:47: ==============================================================
16:08:47: video thread frame - [100%] [avg time: 2.385 ms] [children: 31.6%] [unaccounted: 68.4%]
16:08:47: | scene->Preprocess - [8.72%] [avg time: 0.208 ms]
16:08:47: | GPU download and conversion - [22.9%] [avg time: 0.545 ms] [children: 15.9%] [unaccounted: 6.92%]
16:08:47: | | flush - [15.2%] [avg time: 0.362 ms]
16:08:47: | | CopyResource - [0.671%] [avg time: 0.016 ms]
16:08:47: | | conversion to 4:2:0 - [0.0839%] [avg time: 0.002 ms]
16:08:47: Convert444Thread - [100%] [avg time: 0.918 ms] [children: 99.2%] [unaccounted: 0.763%]
16:08:47: | Convert444toNV12 - [99.2%] [avg time: 0.911 ms]
16:08:47: encoder thread frame - [100%] [avg time: 1.151 ms]
16:08:47:
16:08:47:
16:08:47: Profiler CPU results:
16:08:47:
16:08:47: video thread frame - [cpu time: avg 0.298 ms, total 1700.41 ms] [avg calls per frame: 1]
16:08:47: | scene->Preprocess - [cpu time: avg 0.041 ms, total 234.002 ms] [avg calls per frame: 1]
16:08:47: | GPU download and conversion - [cpu time: avg 0.054 ms, total 312.001 ms] [avg calls per frame: 1]
16:08:47: | | flush - [cpu time: avg 0.038 ms, total 218.4 ms] [avg calls per frame: 1]
16:08:47: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:08:47: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
16:08:47: Convert444Thread - [cpu time: avg 0.765 ms, total 4352.43 ms] [avg calls per frame: 1]
16:08:47: | Convert444toNV12 - [cpu time: avg 0.765 ms, total 4352.43 ms] [avg calls per frame: 1]
16:08:47: encoder thread frame - [cpu time: avg 0.235 ms, total 1341.61 ms] [avg calls per frame: 1]
16:08:47:
16:08:47: =====Stream End: 2013-12-16, 16:08:47=================================================
16:09:10: Settings::Video: Enabling Aero
16:09:13: Using fixed low latency mode, factor 20
16:09:13: =====Stream Start: 2013-12-16, 16:09:13===============================================
16:09:13: Multithreaded optimizations: On
16:09:13: Base resolution: 1920x1080
16:09:13: Output resolution: 768x432
16:09:13: ------------------------------------------
16:09:13: Loading up D3D10 on AMD Radeon HD 6700 Series...
16:09:13: Audio Format: 44100hz
16:09:13: Playback device Default
16:09:13: Using desktop audio input: Microphone (USB Audio Device)
16:09:13: Using auxilary audio input: Microphone (USB Audio Device)
16:09:13: Audio Encoding: AAC
16:09:13: bitrate: 128
16:09:13: Using text output
16:09:13: device: Logitech HD Webcam C270,
16:09:13: device id \\?\usb#vid_046d&pid_0825&mi_00#6&fadec2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
16:09:13: chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000
16:09:13: use buffering: false - 0, fourCC: 'I420'
16:09:13: audio device: Disable,
16:09:13: audio device id Disabled,
16:09:13:
16:09:13: Using directshow input
16:09:13: Using graphics capture
16:09:14: Scene buffering time set to 400
16:09:14: ------------------------------------------
16:09:14: Video Encoding: x264
16:09:14: fps: 25
16:09:14: width: 768, height: 432
16:09:14: preset: veryfast
16:09:14: profile: high
16:09:14: keyint: 50
16:09:14: CBR: yes
16:09:14: CFR: yes
16:09:14: max bitrate: 600
16:09:14: buffer size: 600
16:09:14: MMDeviceAudioSource: Frequency for device 'Microphone (USB Audio Device)' is 192000, samples per sec is 48000
16:09:14: SharedTexCapture hooked
16:09:16: Using RTMP service: Twitch / Justin.tv
16:09:16: Server selection: rtmp://live-lhr.justin.tv/app
16:09:16: Interface: 802.11n Wireless LAN Card (802.11, 186 mbps)
16:09:16: Completed handshake with rtmp://live-lhr.justin.tv/app in 400 ms.
16:09:17: SO_SNDBUF was at 8192
16:09:17: SO_SNDBUF is now 65536
16:26:44: RTMPPublisher::SocketLoop: Stalled for 1817 ms to write 7281 bytes (buffer: 123391 / 131072), unstable connection?
16:42:06: Capture window 0x0012037A invalid or changing, terminating capture
16:42:13: SharedTexCapture hooked
16:54:45: Exit signal received, terminating capture
16:55:08: Using graphics capture
16:55:25: Total frames encoded: 69251, total frames duplicated: 83 (0.12%)
16:55:25: Total frames rendered: 69205, number of late frames: 12 (0.02%) (it's okay for some frames to be late)
16:55:28: RTMPPublisher::SocketLoop: Graceful loop exit
16:55:30: Average send payload: 4773 bytes, average send interval: 55 ms
16:55:30: Number of times waited to send: 1826, Waited for a total of 4979773 bytes
16:55:30: Number of b-frames dropped: 1073 (1.6%), Number of p-frames dropped: 1579 (2.3%), Total 2652 (3.8%)
16:55:30: Number of bytes sent: 239033743
16:55:30:
16:55:30: Profiler time results:
16:55:30:
16:55:30: ==============================================================
16:55:30: video thread frame - [100%] [avg time: 1.787 ms] [children: 55.4%] [unaccounted: 44.6%]
16:55:30: | scene->Preprocess - [10.2%] [avg time: 0.182 ms]
16:55:30: | GPU download and conversion - [45.2%] [avg time: 0.808 ms] [children: 37%] [unaccounted: 8.23%]
16:55:30: | | flush - [36.2%] [avg time: 0.647 ms]
16:55:30: | | CopyResource - [0.616%] [avg time: 0.011 ms]
16:55:30: | | conversion to 4:2:0 - [0.168%] [avg time: 0.003 ms]
16:55:30: Convert444Thread - [100%] [avg time: 0.66 ms] [children: 99.1%] [unaccounted: 0.909%]
16:55:30: | Convert444toNV12 - [99.1%] [avg time: 0.654 ms]
16:55:30: encoder thread frame - [100%] [avg time: 0.764 ms]
16:55:30:
16:55:30:
16:55:30: Profiler CPU results:
16:55:30:
16:55:30: video thread frame - [cpu time: avg 0.243 ms, total 16879.3 ms] [avg calls per frame: 1]
16:55:30: | scene->Preprocess - [cpu time: avg 0.03 ms, total 2106.01 ms] [avg calls per frame: 1]
16:55:30: | GPU download and conversion - [cpu time: avg 0.045 ms, total 3166.82 ms] [avg calls per frame: 1]
16:55:30: | | flush - [cpu time: avg 0.024 ms, total 1700.42 ms] [avg calls per frame: 1]
16:55:30: | | CopyResource - [cpu time: avg 0.008 ms, total 592.8 ms] [avg calls per frame: 1]
16:55:30: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 46.8 ms] [avg calls per frame: 1]
16:55:30: Convert444Thread - [cpu time: avg 0.666 ms, total 46098.3 ms] [avg calls per frame: 1]
16:55:30: | Convert444toNV12 - [cpu time: avg 0.661 ms, total 45755.1 ms] [avg calls per frame: 1]
16:55:30: encoder thread frame - [cpu time: avg 0.118 ms, total 8190.05 ms] [avg calls per frame: 1]
16:55:30:
16:55:30: =====Stream End: 2013-12-16, 16:55:30=================================================
16:55:31: Using fixed low latency mode, factor 20
16:55:31: =====Stream Start: 2013-12-16, 16:55:31===============================================
16:55:31: Multithreaded optimizations: On
16:55:31: Base resolution: 1920x1080
16:55:31: Output resolution: 768x432
16:55:31: ------------------------------------------
16:55:31: Loading up D3D10 on AMD Radeon HD 6700 Series...
16:55:31: Audio Format: 44100hz
16:55:31: Playback device Default
16:55:31: Using desktop audio input: Microphone (USB Audio Device)
16:55:31: Using auxilary audio input: Microphone (USB Audio Device)
16:55:31: Audio Encoding: AAC
16:55:31: bitrate: 128
16:55:31: Using text output
16:55:31: device: Logitech HD Webcam C270,
16:55:31: device id \\?\usb#vid_046d&pid_0825&mi_00#6&fadec2&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
16:55:31: chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 333333-2000000
16:55:31: use buffering: false - 0, fourCC: 'I420'
16:55:31: audio device: Disable,
16:55:31: audio device id Disabled,
16:55:31:
16:55:31: Using directshow input
16:55:31: Using graphics capture
16:55:32: Scene buffering time set to 400
16:55:32: ------------------------------------------
16:55:32: Video Encoding: x264
16:55:32: fps: 25
16:55:32: width: 768, height: 432
16:55:32: preset: veryfast
16:55:32: profile: high
16:55:32: keyint: 50
16:55:32: CBR: yes
16:55:32: CFR: yes
16:55:32: max bitrate: 600
16:55:32: buffer size: 600
16:55:32: MMDeviceAudioSource: Frequency for device 'Microphone (USB Audio Device)' is 192000, samples per sec is 48000
16:55:34: Using RTMP service: Twitch / Justin.tv
16:55:34: Server selection: rtmp://live-lhr.justin.tv/app
16:55:34: Interface: 802.11n Wireless LAN Card (802.11, 186 mbps)
16:55:35: Completed handshake with rtmp://live-lhr.justin.tv/app in 774 ms.
16:55:37: SO_SNDBUF was at 8192
16:55:37: SO_SNDBUF is now 65536
16:56:06: SharedTexCapture hooked
17:02:00: Capture window 0x000903B6 invalid or changing, terminating capture
17:02:02: Using Monitor Capture
17:10:17: Total frames encoded: 22102, total frames duplicated: 900 (4.07%)
17:10:17: Total frames rendered: 21986, number of late frames: 23 (0.10%) (it's okay for some frames to be late)
17:10:17: RTMPPublisher::SocketLoop: Graceful loop exit
17:10:17: Average send payload: 4773 bytes, average send interval: 55 ms
17:10:17: Number of times waited to send: 466, Waited for a total of 1369507 bytes
17:10:17: Number of b-frames dropped: 365 (1.7%), Number of p-frames dropped: 433 (2%), Total 798 (3.6%)
17:10:17: Number of bytes sent: 76045101
17:10:17:
17:10:17: Profiler time results:
17:10:17:
17:10:17: ==============================================================
17:10:17: video thread frame - [100%] [avg time: 8.004 ms] [children: 72%] [unaccounted: 28%]
17:10:17: | scene->Preprocess - [62.2%] [avg time: 4.98 ms]
17:10:17: | GPU download and conversion - [9.82%] [avg time: 0.786 ms] [children: 7.97%] [unaccounted: 1.85%]
17:10:17: | | flush - [7.68%] [avg time: 0.615 ms]
17:10:17: | | CopyResource - [0.225%] [avg time: 0.018 ms]
17:10:17: | | conversion to 4:2:0 - [0.0625%] [avg time: 0.005 ms]
17:10:17: Convert444Thread - [100%] [avg time: 0.651 ms] [children: 99.1%] [unaccounted: 0.922%]
17:10:17: | Convert444toNV12 - [99.1%] [avg time: 0.645 ms]
17:10:17: encoder thread frame - [100%] [avg time: 0.715 ms]
17:10:17:
17:10:17:
17:10:17: Profiler CPU results:
17:10:17:
17:10:17: video thread frame - [cpu time: avg 4.791 ms, total 105347 ms] [avg calls per frame: 1]
17:10:17: | scene->Preprocess - [cpu time: avg 3.681 ms, total 80948.9 ms] [avg calls per frame: 1]
17:10:17: | GPU download and conversion - [cpu time: avg 0.08 ms, total 1778.42 ms] [avg calls per frame: 1]
17:10:17: | | flush - [cpu time: avg 0.038 ms, total 842.408 ms] [avg calls per frame: 1]
17:10:17: | | CopyResource - [cpu time: avg 0.017 ms, total 390.002 ms] [avg calls per frame: 1]
17:10:17: | | conversion to 4:2:0 - [cpu time: avg 0.004 ms, total 93.602 ms] [avg calls per frame: 1]
17:10:17: Convert444Thread - [cpu time: avg 0.469 ms, total 10311.7 ms] [avg calls per frame: 1]
17:10:17: | Convert444toNV12 - [cpu time: avg 0.466 ms, total 10249.3 ms] [avg calls per frame: 1]
17:10:17: encoder thread frame - [cpu time: avg 0.076 ms, total 1684.81 ms] [avg calls per frame: 1]
17:10:17:
17:10:17: =====Stream End: 2013-12-16, 17:10:17=================================================
Last game capture log:
2013-12-16, 16:56:06: we're booting up:
16:56:06: CaptureThread: attached to process javaw.exe
16:56:06: NV Capture available
16:56:06: FBO available
16:56:06: GL Present
16:56:06: (half life scientist) everything.. seems to be in order
16:56:06: SwapBuffers(620829939) Called
16:56:06: setting up gl data
16:56:06: share device: 250878856
16:56:06: share texture: 250946160
16:56:06: share device handle: 245633904
16:56:06: share texture handle: 250363120
16:56:06: DoGLGPUHook: success
16:56:06: wglSwapBuffers(620829939) Called
17:02:00: wglDeleteContext Called
17:02:00: ---------------------- Cleared OpenGL Capture ----------------------
So if any of you have a clue please let me know, if you'd like to know more please don't hesitate to add me on Skype - JimmyNibble.
Also check out my Twitch and if you'd like to do some stuff on Twitch together also hit me up, thanks!
Sapiens
Forum Moderator
Go to Settings > Audio in OBS and select the correct desktop audio device, you currently have it set to your mic.
LssTz
I get this message when I select my actual audio, that being my earphones. "Cannot initialize desktop audio sound, more info in the log file."
Log file:
18:00:45: Open Broadcaster Software v0.59b - 64bit ( ^ω^)
18:00:45: -------------------------------
18:00:45: CPU Name: AMD FX(tm)-4100 Quad-Core Processor
18:00:45: CPU Speed: 4018MHz
18:00:45: Physical Memory: 8174MB Total, 5694MB Free
18:00:45: stepping id: 2, model 1, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 4, total cores 2
18:00:45: monitor 1: pos={-1280, 56}, size={1280, 1024}
18:00:45: monitor 2: pos={0, 0}, size={1920, 1080}
18:00:45: Windows Version: 6.1 Build 7601 S
18:00:45: Aero is Enabled
18:00:45: OBS Modules:
18:00:45: Base Address Module
18:00:45: 000000003F480000 OBS.exe
18:00:45: 00000000F01F0000 OBSApi.dll
18:00:45: 00000000F05F0000 DShowPlugin.dll
18:00:45: 00000000F0910000 GraphicsCapture.dll
18:00:45: 00000000F4DE0000 NoiseGate.dll
18:00:45: 00000000F2470000 PSVPlugin.dll
18:00:45: ------------------------------------------
18:00:45: Adapter 1
18:00:45: Video Adapter: AMD Radeon HD 6700 Series
18:00:45: Video Adapter Dedicated Video Memory: 1060859904
18:00:45: Video Adapter Shared System Memory: 4017156096
18:00:45: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:00:45: Video Adapter Output 2: pos={-1280, 56}, size={1280, 1024}, attached=true
18:00:45: Using fixed low latency mode, factor 20
18:00:45: =====Stream Start: 2013-12-17, 18:00:45===============================================
18:00:45: Multithreaded optimizations: On
18:00:45: Base resolution: 1920x1080
18:00:45: Output resolution: 852x480
18:00:45: Loading up D3D10 on AMD Radeon HD 6700 Series...
18:00:45: Audio Format: 44100hz
18:00:45: Playback device {0.0.1.00000000}.{5adc5396-5605-4c51-9a39-0218394cc1f5}
LssTz
No one? Really need this fixed, it's something which will more than likely affect others in the future.
Sapiens
Forum Moderator
What is your Windows default playback device?
What device are you trying to select as your desktop audio device in OBS?
Lain
Forum Admin
Lain
Forum Moderator
Developer
That error seems to say "Device Invalidated", meaning device unplugged or soemthing perhaps. Not entirely sure why it's saying that error though. Have you tried selecting different audio devices in audio settings? Sometimes it has the wrong one selected depending on what device you use. Seems like you're using a headset -- some headsets can have problems capturing if they're not set up correctly.
Also, could you check something for me? See if disabling the mic causes the sound to become louder. There's some sort of bug with older windows versions where the windows mixer will inadvertently lower sound on the system when a mic is turned on, so I'm curious if maybe that's the issue. Though for some reason I doubt it.
If you can't find a solution and your desktop sound is really low despite being maxed on the main window, you can use "desktop audio boost" in audio settings to boost the sound by multiples, which usually will do the trick.
dodgepong
Administrator
Community Helper
Also: please don't unnecessarily bump your thread only a couple hours after you posted. If you need assistance immediately, you can try the webchat, linked at the top.
