Help OBS not seeing multiple cameras on a multi USB Dock.
Kev kinch
So I have a Lenovo laptop thinkpad Gen 1 with windows 11 and a seperate USB-c Expander docking port 48W with plenty of speed, made by VKUSAR.
(All 3 web cams are different makes & models BTW).
Now when using ‘windows camera’ App I can see all 3 cameras running fine when they are all connected on separate USB ports on the one USB dock expander which is plugged in to one of the USB -C ports on the laptop all 3 cameras work with no issues at all with ‘Windows Camera’ app.
But when I close the ‘windows Camera’ app and open OBS (despite previously setting up OBS to have all 3 cameras on it), OBS will only display 1 camera and not the other 2 cameras.
If I unplug 2 cameras and re-boot OBS it will see a camera that wasn’t being seen before, in no particular order, but not all 3 at anytime Together via the docking station ports.
If I plug each camera into a different USB port on the laptop (1 on left USB, 1 right USB and one in via USB-c docking station) then OBS display’s all 3 cameras with no issues, BUT I then have no more usb ports on laptop hence wanting to use the docking station in the 1st place.
Any Ideas?
