Hi there so I have a non 16:9 screen wich is the correct aspect ratio to stream on Twitch if I'm not mistaken. It is has a 1366*768 resolution so I believe that I have a couple of options considering that the closest acceptable resolution is 720p:
- Stream at raw 1366*768 (wich I don't think is the best because of the "black bars" unless I stretch it, and because I don't have a 16:9 downscale resolution (720p for example))
- Stream at raw 1366*768 and downscale 1.25 in order to get closer to a 720p resolution (meh)
- Stream with a custom base resolution of 1280*720 but play the game at native screen resolution (best solution?)
- Stream with a custom base resolution of 1280*720 and play the game at 1280*720 wich will look bad for me
- Stream with a custom base resolution of 1280*720 and downscale if further performance needed
