I could really use some "to the point" help with he following. I need to figure out what the minimum level GPU that will provide smooth and fast performance for 1) AMD processors and 2) Intel I5 processors.
Is there anyone out there that can answer this question for me or provide a link to some sort of chart that will make it easy.
Use case:
Using a Logitech camera 920 or higher.
OBS will be simply chromakeying, replacing background with mpg file and streaming it via WebRTC.
There will be NO RECORDING.
I have used many i5 systems with integrated and some dedicated GPU's and get choppy or poor quaity.
I appreciate any and all help.
Again, I'm not looking for advice on the best or good cards out there like the NVIDIA GTX 1650-1650 Super or 1660 as I know they work but the cost point is too high.
Im looking for the least priced and least performing GPUS' for both AMD and Intel CPU systems hat will perform smoothly and handle the requirement to only key and stream.
THANK YOU FOR ALL HELP.
Use case:
