Question / Help Help! Audio Issues when recording
Crofty
So I was recording some GTA V and ran into some issues when finished. The audio is super choppy and skips around like a 5 year old playing hopscotch. I have no idea what would be causing this. The sound is like its fastforwarding and laggy. Video is fine.
Current Log:
12:47:35.258: CPU Name: AMD FX(tm)-4300 Quad-Core Processor
12:47:35.258: CPU Speed: 3817MHz
12:47:35.258: Physical Cores: 2, Logical Cores: 4
12:47:35.258: Physical Memory: 2047MB Total, 2047MB Free (NOTE: 2 or 4 gigs max is normal for 32bit programs)
12:47:35.258: Windows Version: 10.0 Build 14393 (revision: 693; 64-bit)
12:47:35.258: Running as administrator: false
12:47:35.258: Aero is Enabled (Aero is always on for windows 8 and above)
12:47:35.271: OBS 0.16.2 (windows)
12:47:35.271: ---------------------------------
12:47:35.272: ---------------------------------
12:47:35.273: audio settings reset:
12:47:35.273: samples per sec: 48000
12:47:35.273: speakers: 2
12:47:35.275: ---------------------------------
12:47:35.275: Initializing D3D11..
12:47:35.275: Available Video Adapters:
12:47:35.278: Adapter 1: NVIDIA GeForce GTX 960
12:47:35.278: Dedicated VRAM: 2114650112
12:47:35.278: Shared VRAM: 2180251648
12:47:35.278: output 1: pos={0, 0}, size={1366, 768}, attached=true
12:47:35.281: Loading up D3D11 on adapter NVIDIA GeForce GTX 960 (0)
12:47:35.316: D3D11 loaded sucessfully, feature level used: 45056
12:47:36.131: ---------------------------------
12:47:36.131: video settings reset:
12:47:36.131: base resolution: 1280x720
12:47:36.131: output resolution: 1280x720
12:47:36.131: downscale filter: Bicubic
12:47:36.131: fps: 60/1
12:47:36.131: format: NV12
12:47:36.133: ---------------------------------
12:47:36.142: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
12:47:36.176: [AMF Encoder] Version 1.3.1.0-1.3.0.5
12:47:36.176: [AMF Encoder] <Plugin::AMD::AMF::AMF> Initializing...
12:47:36.176: [AMF Encoder] <Plugin::AMD::AMF::AMF> Loading of 'amfrt32.dll' failed with error code 126.
12:47:36.234: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libcef.dll' not found, loading of module failed
12:47:36.236: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libEGL.dll' not found, loading of module failed
12:47:36.237: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libGLESv2.dll' not found, loading of module failed
12:47:36.239: Failed to load 'en-US' text for module: 'obs-browser.dll'
12:47:36.239: [browser_source: 'Version: 1.25.0']
12:47:36.254: NVENC supported
12:47:37.105: [rtmp-services plugin] Successfully updated file 'services.json' (version 52)
12:47:37.107: [rtmp-services plugin] Successfully updated package (version 52)
12:47:41.907: Couldn't find VLC installation, VLC video source disabled
12:47:42.491: No blackmagic support
12:47:42.670: ---------------------------------
12:47:42.670: Loaded Modules:
12:47:42.670: win-wasapi.dll
12:47:42.670: win-mf.dll
12:47:42.670: win-dshow.dll
12:47:42.670: win-decklink.dll
12:47:42.670: win-capture.dll
12:47:42.670: vlc-video.dll
12:47:42.670: text-freetype2.dll
12:47:42.670: rtmp-services.dll
12:47:42.670: obs-x264.dll
12:47:42.671: obs-transitions.dll
12:47:42.671: obs-text.dll
12:47:42.671: obs-qsv11.dll
12:47:42.671: obs-outputs.dll
12:47:42.671: obs-filters.dll
12:47:42.671: obs-ffmpeg.dll
12:47:42.671: obs-browser.dll
12:47:42.671: image-source.dll
12:47:42.671: frontend-tools.dll
12:47:42.671: enc-amf.dll
12:47:42.671: coreaudio-encoder.dll
12:47:42.671: ==== Startup complete ===============================================
12:47:42.785: All scene data cleared
12:47:42.785: ------------------------------------------------
12:47:42.851: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
12:47:42.858: WASAPI: Device 'Yeti (Yeti Stereo Microphone)' initialized
12:47:42.901: Switched to scene 'Games'
12:47:42.901: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds
12:47:42.923: ------------------------------------------------
12:47:42.923: Loaded scenes:
12:47:42.923: - scene 'Games':
12:47:42.924: - source: 'Golf' (game_capture)
12:47:42.924: - source: 'Game Capture' (game_capture)
12:47:42.924: - source: 'GTA' (game_capture)
12:47:42.924: ------------------------------------------------
And the recording date log
00:21:03.224: CPU Name: AMD FX(tm)-4300 Quad-Core Processor
00:21:03.224: CPU Speed: 3817MHz
00:21:03.225: Physical Cores: 2, Logical Cores: 4
00:21:03.225: Physical Memory: 2047MB Total, 2047MB Free (NOTE: 2 or 4 gigs max is normal for 32bit programs)
00:21:03.225: Windows Version: 10.0 Build 14393 (revision: 693; 64-bit)
00:21:03.225: Running as administrator: false
00:21:03.225: Aero is Enabled (Aero is always on for windows 8 and above)
00:21:03.249: OBS 0.16.2 (windows)
00:21:03.249: ---------------------------------
00:21:03.251: ---------------------------------
00:21:03.251: audio settings reset:
00:21:03.251: samples per sec: 48000
00:21:03.251: speakers: 2
00:21:03.257: ---------------------------------
00:21:03.257: Initializing D3D11..
00:21:03.257: Available Video Adapters:
00:21:03.260: Adapter 1: NVIDIA GeForce GTX 960
00:21:03.260: Dedicated VRAM: 2114650112
00:21:03.260: Shared VRAM: 2180251648
00:21:03.260: output 1: pos={0, 0}, size={1366, 768}, attached=true
00:21:03.267: Loading up D3D11 on adapter NVIDIA GeForce GTX 960 (0)
00:21:03.335: D3D11 loaded sucessfully, feature level used: 45056
00:21:04.936: ---------------------------------
00:21:04.936: video settings reset:
00:21:04.936: base resolution: 1280x720
00:21:04.936: output resolution: 1280x720
00:21:04.936: downscale filter: Bicubic
00:21:04.936: fps: 60/1
00:21:04.936: format: NV12
00:21:04.939: ---------------------------------
00:21:04.951: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
00:21:04.964: [AMF Encoder] Version 1.3.1.0-1.3.0.5
00:21:04.965: [AMF Encoder] <Plugin::AMD::AMF::AMF> Initializing...
00:21:04.965: [AMF Encoder] <Plugin::AMD::AMF::AMF> Loading of 'amfrt32.dll' failed with error code 126.
00:21:05.011: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libcef.dll' not found, loading of module failed
00:21:05.013: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libEGL.dll' not found, loading of module failed
00:21:05.015: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libGLESv2.dll' not found, loading of module failed
00:21:05.018: Failed to load 'en-US' text for module: 'obs-browser.dll'
00:21:05.018: [browser_source: 'Version: 1.25.0']
00:21:05.046: NVENC supported
00:21:05.308: Couldn't find VLC installation, VLC video source disabled
00:21:06.687: No blackmagic support
00:21:07.034: ---------------------------------
00:21:07.034: Loaded Modules:
00:21:07.034: win-wasapi.dll
00:21:07.034: win-mf.dll
00:21:07.034: win-dshow.dll
00:21:07.034: win-decklink.dll
00:21:07.035: win-capture.dll
00:21:07.035: vlc-video.dll
00:21:07.035: text-freetype2.dll
00:21:07.035: rtmp-services.dll
00:21:07.035: obs-x264.dll
00:21:07.035: obs-transitions.dll
00:21:07.035: obs-text.dll
00:21:07.035: obs-qsv11.dll
00:21:07.035: obs-outputs.dll
00:21:07.035: obs-filters.dll
00:21:07.035: obs-ffmpeg.dll
00:21:07.035: obs-browser.dll
00:21:07.035: image-source.dll
00:21:07.036: frontend-tools.dll
00:21:07.036: enc-amf.dll
00:21:07.036: coreaudio-encoder.dll
00:21:07.036: ==== Startup complete ===============================================
00:21:07.131: All scene data cleared
00:21:07.131: ------------------------------------------------
00:21:07.287: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
00:21:07.301: WASAPI: Device 'Yeti (Yeti Stereo Microphone)' initialized
00:21:07.344: Switched to scene 'Games'
00:21:07.346: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds
00:21:07.349: ------------------------------------------------
00:21:07.349: Loaded scenes:
00:21:07.349: - scene 'Games':
00:21:07.349: - source: 'Golf' (game_capture)
00:21:07.349: - source: 'Game Capture' (game_capture)
00:21:13.482: User added source 'GTA' (game_capture) to scene 'Games'
00:21:18.474: [game-capture: 'GTA'] attempting to hook process: GTA5.exe
00:21:18.559: [game-capture: 'GTA'] using helper (compatibility hook)
00:21:18.933: [game-capture: 'GTA'] Hooked to process: GTA5.exe
00:21:18.942: [game-capture: 'GTA'] (half life scientist) everything.. seems to be in order
00:21:18.943: [game-capture: 'GTA'] Hooked D3D9
00:21:19.008: [game-capture: 'GTA'] Hooked DXGI
00:21:20.490: [game-capture: 'GTA'] attempting to hook process: GTA5.exe
00:21:24.507: [game-capture: 'GTA'] attempting to hook process: GTA5.exe
00:22:23.328: ---------------------------------
00:22:23.352: [NVENC encoder: 'recording_h264'] settings:
00:22:23.352: rate_control: CBR
00:22:23.352: bitrate: 20000
00:22:23.352: cqp: 0
00:22:23.352: keyint: 250
00:22:23.352: preset: default
00:22:23.352: profile: main
00:22:23.352: level: auto
00:22:23.352: width: 1280
00:22:23.352: height: 720
00:22:23.352: 2-pass: true
00:22:23.352: GPU: 0
00:22:23.352:
00:22:24.289: ---------------------------------
00:22:24.290: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 0
00:22:24.338: ==== Recording Start ===============================================
00:22:24.338: [ffmpeg muxer: 'adv_file_output'] Writing file 'E:/Users/JUSTIN/Desktop/OVG/Recording/Golf/2017-02-23 00-22-23.mp4'...
00:25:11.688: [ffmpeg muxer: 'adv_file_output'] Output of file 'E:/Users/JUSTIN/Desktop/OVG/Recording/Golf/2017-02-23 00-22-23.mp4' stopped
00:25:11.688: Output 'adv_file_output': stopping
00:25:11.688: Output 'adv_file_output': Total encoded frames: 10038
00:25:11.690: Output 'adv_file_output': Total drawn frames: 10041
00:25:11.690: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 211 (2.1%)
00:25:11.690: ==== Recording Stop ================================================
00:42:53.214: ---------------------------------
00:42:53.214: [NVENC encoder: 'recording_h264'] settings:
00:42:53.214: rate_control: CBR
00:42:53.214: bitrate: 20000
00:42:53.214: cqp: 0
00:42:53.214: keyint: 250
00:42:53.214: preset: default
00:42:53.214: profile: main
00:42:53.214: level: auto
00:42:53.214: width: 1280
00:42:53.214: height: 720
00:42:53.214: 2-pass: true
00:42:53.214: GPU: 0
00:42:53.214:
00:42:53.956: ---------------------------------
00:42:53.957: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 0
00:42:53.970: ==== Recording Start ===============================================
00:42:53.970: [ffmpeg muxer: 'adv_file_output'] Writing file 'E:/Users/JUSTIN/Desktop/OVG/Recording/Golf/2017-02-23 00-42-53.mp4'...
00:51:26.737: [ffmpeg muxer: 'adv_file_output'] Output of file 'E:/Users/JUSTIN/Desktop/OVG/Recording/Golf/2017-02-23 00-42-53.mp4' stopped
00:51:26.737: Output 'adv_file_output': stopping
00:51:26.737: Output 'adv_file_output': Total encoded frames: 30756
00:51:26.737: Output 'adv_file_output': Total drawn frames: 30766
00:51:26.737: Output 'adv_file_output': Number of skipped frames due to encoding lag: 4875 (15.9%)
00:51:26.738: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 15293 (49.7%)
00:51:26.738: ==== Recording Stop ================================================
00:58:39.877: ---------------------------------
00:58:39.877: [NVENC encoder: 'recording_h264'] settings:
00:58:39.877: rate_control: CBR
00:58:39.877: bitrate: 20000
00:58:39.877: cqp: 0
00:58:39.877: keyint: 250
00:58:39.877: preset: default
00:58:39.877: profile: main
00:58:39.877: level: auto
00:58:39.877: width: 1280
00:58:39.877: height: 720
00:58:39.877: 2-pass: true
00:58:39.877: GPU: 0
00:58:39.877:
00:58:40.819: ---------------------------------
00:58:40.820: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 0
00:58:40.880: ==== Recording Start ===============================================
00:58:40.880: [ffmpeg muxer: 'adv_file_output'] Writing file 'E:/Users/JUSTIN/Desktop/OVG/Recording/Golf/2017-02-23 00-58-39.mp4'...
01:06:39.394: [ffmpeg muxer: 'adv_file_output'] Output of file 'E:/Users/JUSTIN/Desktop/OVG/Recording/Golf/2017-02-23 00-58-39.mp4' stopped
01:06:39.394: Output 'adv_file_output': stopping
01:06:39.394: Output 'adv_file_output': Total encoded frames: 28709
01:06:39.394: Output 'adv_file_output': Total drawn frames: 28711
01:06:39.394: Output 'adv_file_output': Number of skipped frames due to encoding lag: 17 (0.1%)
01:06:39.394: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 1233 (4.3%)
01:06:39.395: ==== Recording Stop ================================================
01:09:13.122: ---------------------------------
01:09:13.122: [NVENC encoder: 'recording_h264'] settings:
01:09:13.122: rate_control: CBR
01:09:13.122: bitrate: 20000
01:09:13.122: cqp: 0
01:09:13.122: keyint: 250
01:09:13.122: preset: default
01:09:13.122: profile: main
01:09:13.122: level: auto
01:09:13.122: width: 1280
01:09:13.122: height: 720
01:09:13.122: 2-pass: true
01:09:13.122: GPU: 0
01:09:13.122:
01:09:13.605: ---------------------------------
01:09:13.606: [FFmpeg aac encoder: 'Track1'] bitrate: 160, channels: 0
01:09:13.619: ==== Recording Start ===============================================
01:09:13.619: [ffmpeg muxer: 'adv_file_output'] Writing file 'E:/Users/JUSTIN/Desktop/OVG/Recording/Golf/2017-02-23 01-09-13.mp4'...
Fenrir
Forum Admin
The issue is that you're overloading your PC. Turn settings down either in-game or lower resolution/fps in OBS.
