I just built a new PC and I was wondering what would be the best settings for recording 1080p/60fps (local recording), and then as well the best settings for streaming to YouTube in 1080p/60fps?
ENCODING: x264 or NVIDIA? Which is the best option? (You can find my PC Specs down below). BITRATE: I've played around with 8,000, 10,000, and 12,000 for recording, but I heard you should do 10,000-12,000 for 1080p/60fps recording? Is that true? AUDIO: I'm using AAC, 44.1kHz, 192 bitrate and stereo.
Most of the other stuff is default, I do have delays set to make sure everything is in Sync visually/audio wise, but that's about it. Thoughts? What should I play with/change?
Also for some reason when I do record with those settings the OVERALL AUDIO seems off. . like low quality and low volume. . . Any idea why? (I don't know if it matters but I'm forcing Mic/Aux to Mono cause the way my stuff is set up, if I don't do that my mic will only record left channel). The video MIGHT look a bit off too I'm not sure. . . maybe a tad fuzzy? I don't know.
MY PC SPECS: CPU: Intel i7 6700K GPU: GTX 1060 3GB PSU: 500 watt PSU MEMORY: 16GB RAM (DDR4) COOLING: Cool Master Hyper 212 EVO MOBO: Gigabyte Z170 HD3P
