[Guide] How to use llanfair for speed-runs
NOTE: I would love to upload pics of this software in action, but I am unable at this time. The forums aren't letting me. Here's a pic of it, courtesy of Dropbox: https://www.dropbox.com/s/sepcfbm20xh6ntx/acapture.jpg
Most of us would love to speed-run, but we struggle to find the right software to do it. Now we have llanfair, software designed specifically for you speed-runners. Now this guide will consist of 2 things: downloading and setting up.
Downloading
1. Go here --> Click me
2. If you have Windows, click the windows version. If you have any other OS, click multiplatform
3. Click the green "Download" button
4. Download the latest version
5. When downloaded, extract the folder
6. Done
Setting up
1. Click "Llanfair" inside the folder
2. When it opens, right click and select "Edit"
3. Name your Run
4. For "Goal," enter a time goal (ex. 8 minutes)
4.5. If the run has different levels, click "Segmented Run"
5. For each segment, click the green plus
6. To name each segment, double click "<untitled>" and type the name you want to give it
7. If you want to give each segment an icon, double click the box under "icon"
8. When you are finished, click save
9. If you want to save the segment names, right click and click save
To start, press Enter, to stop, press Enter again. Each press will go to the next segment.
To add this window to your OBS stream, add a "Software Capture," and choose Llanfair.
I hope you enjoyed this guide and I hope it helps you speed-runners!
Jack0r
The Helping Squad
Does it do something better than WSplit?
You could add a screenshot to showcase it at work :)
It work a lot better than WSplit. In fact, it was designed for the purpose of out doing it.
