Graphics Monitor Pen Freezing When I Stream/Record with OBS - HELP
N3sting3yes
I have a three monitor set up, two HP Pavillion 27cw (1920x1080) and one Wacom Cintiq 27QHDT (2560x1440).
My Issue: When I stream, at random during my stream my pen loses connection to the screen. My wacom driver shows that things are running fine, restarting my driver doesn't fix the issue, only turning my monitor off and on will fix it temporarily. Every 2, 5, or 10 minutes it will happen again and again. This only happens when running OBS to stream. Using Xsplit for example never does this! (I don't want to use Xsplit, because I have lots of plugins that I enjoy using that aren't available in Xsplit)
I do have an older AMD Radeon graphics card, and am basically running a system from 2015. I know that I need to update my system when I can afford it. However, I have a feeling that's not the issue here. Considering that this issue will disappear just as randomly as it shows up again for weeks to a month. It doesn't make any sense, because I haven't changed anything in terms of configuration or OBS settings.
Does ANYONE have any idea of why this is happening or how to fix it? (Besides mirroring a 1920x1080 resolution onto my 2560x1440 Cintiq... Because that warped screen garbage is impossible to work on.)
Thanks for taking the time!
