Ghosting / Pixilation Issue
FGSTAUH
We are facing a persistent issue with our church streaming. The issue is having a very pixelated photo/ghosting for the PTZ cameras only. Other fixed cameras are working fine. (see the attached)
I have contacted the manufacturer, and still no resolution. The issue is evident using Wirecast, on OBS, there is an issue of Interlacing, rather than pixelation.
The following has been done trying to narrow down the root cause:
1. New streaming PC (i7, 10Gen, 2.5GHz,16Ram, 6GB Geforce GTX 1660 Ti , Giga port, WAN speed is around 800Mbs Down/100 Mbs Up, 2 ms Ping
2. Lowered/Increased the Bitrate, FPS, I frame, Resolution, VBR/CBR whatever combination is out there
3. Ran live tests for more than 40hr, the issue is isolated with the PTZ cameras only.
4. In OBS , tried all interlacing options
I have two theories:
1. The firmware of the PTZ cameras has issues with graphics cards. The manufacturer does not seem to fully understand the issue and insists to use IE it is more optimized (what IE has to do with the streaming over RTSP, I have no clue)
2. There is a joystick controller that connects to the cameras through a LAN cable, the cameras and the joystick are connected through a branch switch. I have to inspect this...but is there a way to know if it is causing any throttling? Without having access to this switch (yet)
What do you think? Is it hardware related (switch) or software (codecs/firmware compatibility) or something else?
Here is a log
Hello, I have a similar problem and I have two different models of IP PTZ cameras and it happens to me with both, but it is only in OBS, when I put them in wirecast they look good and in UFO it also looks good, and open in both sites to the once and only does it ne obs, it looks pixelated and the ghost image,
Check all the NETWORK and it works correctly, the problem is only in OBS
I was trying several things and I noticed that when the network is stressed by 70% the failure increases, I switched to connecting the PC to 1GB and the frequency of the error decreased.
In my research I noticed that when there are several programs requesting video from the same camera, it tends to fail.
The problem is not on the bandwidth, but in the UDP protocol. Switch to TCP instead
