Game audio clips in and out, Mic audio fine
Key19
Here is a YouTube link showing the issue: https://youtu.be/DCPb8UCUXBs
Here are pics of my settings:
This has happened despite a full re-install of both Windows 10 and OBS itself. It happens randomly for about 10-15 seconds at a time usually once within every recording I make. Please let me know if there is any other information I can provide that helps diagnose the issue. Thank you for any help!
Here is what I believe the associated Log File is (part 1)
21:19:41.023: CPU Name: Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
21:19:41.023: CPU Speed: 3504MHz
21:19:41.023: Physical Cores: 4, Logical Cores: 4
21:19:41.023: Physical Memory: 16322MB Total, 10358MB Free
21:19:41.023: Windows Version: 10.0 Build 19045 (release: 22H2; revision: 5679; 64-bit)
21:19:41.023: Running as administrator: false
21:19:41.023: Windows 10/11 Gaming Features:
21:19:41.023: Game Bar: On
21:19:41.023: Game DVR: On
21:19:41.023: Game DVR Background Recording: Off
21:19:41.023: Game Mode: Probably On (no reg key set)
21:19:41.024: Sec. Software Status:
21:19:41.025: Microsoft Defender Antivirus: enabled (AV)
21:19:41.025: Windows Firewall: enabled (FW)
21:19:41.026: Current Date/Time: 2025-04-02, 21:19:41
21:19:41.026: Browser Hardware Acceleration: true
21:19:41.026: Hide OBS windows from screen capture: false
21:19:41.026: Qt Version: 6.6.3 (runtime), 6.6.3 (compiled)
21:19:41.026: Portable mode: false
21:19:41.345: OBS 31.0.3 (64-bit, windows)
21:19:41.345: ---------------------------------
21:19:41.363: ---------------------------------
21:19:41.364: audio settings reset:
21:19:41.364: samples per sec: 48000
21:19:41.364: speakers: 2
21:19:41.364: max buffering: 960 milliseconds
21:19:41.364: buffering type: dynamically increasing
21:19:41.366: ---------------------------------
21:19:41.366: Initializing D3D11...
21:19:41.366: Available Video Adapters:
21:19:41.367: Adapter 0: NVIDIA GeForce GTX 1050
21:19:41.367: Dedicated VRAM: 2057363456 (1.9 GiB)
21:19:41.367: Shared VRAM: 8557928448 (8.0 GiB)
21:19:41.367: PCI ID: 10de:1c81
21:19:41.368: HAGS Status: Disabled (Default: No, Driver status: Supported)
21:19:41.368: Driver Version: 32.0.15.7283
21:19:41.368: output 0:
21:19:41.368: name=ASUS VS238
21:19:41.368: pos={0, 0}
21:19:41.368: size={1920, 1080}
21:19:41.368: attached=true
21:19:41.368: refresh=60
21:19:41.368: bits_per_color=8
21:19:41.368: space=RGB_FULL_G22_NONE_P709
21:19:41.368: primaries=[r=(0.635742, 0.333008), g=(0.302734, 0.625977), b=(0.153320, 0.070312), wp=(0.313477, 0.329102)]
21:19:41.368: relative_gamut_area=[709=1.021036, P3=0.752678, 2020=0.539996]
21:19:41.368: sdr_white_nits=80
21:19:41.368: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
21:19:41.368: dpi=96 (100%)
21:19:41.368: id=\\?\DISPLAY#ACI23FA#5&a9c006a&0&UID4353#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
21:19:41.368: alt_id=\\.\DISPLAY1
21:19:41.369: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 (0)
21:19:41.517: D3D11 loaded successfully, feature level used: b000
21:19:41.517: DXGI increase maximum frame latency success
21:19:41.517: D3D11 GPU priority setup failed (not admin?)
21:19:41.609: ---------------------------------
21:19:41.609: video settings reset:
21:19:41.609: base resolution: 1920x1080
21:19:41.609: output resolution: 1920x1080
21:19:41.609: downscale filter: Bicubic
21:19:41.609: fps: 60/1
21:19:41.609: format: NV12
21:19:41.609: YUV mode: Rec. 709/Partial
21:19:41.609: NV12 texture support enabled
21:19:41.609: P010 texture support not available
21:19:41.611: Audio monitoring device:
21:19:41.611: name: Default
21:19:41.611: id: default
21:19:41.613: ---------------------------------
21:19:41.615: No AJA devices found, skipping loading AJA UI plugin
21:19:41.615: Failed to initialize module 'aja-output-ui.dll'
21:19:41.616: No AJA devices found, skipping loading AJA plugin
21:19:41.616: Failed to initialize module 'aja.dll'
21:19:41.616: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
21:19:41.619: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
21:19:41.619: Failed to load 'en-US' text for module: 'decklink-captions.dll'
21:19:41.620: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
21:19:41.624: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
21:19:41.624: Failed to initialize module 'decklink.dll'
21:19:41.632: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
21:19:41.633: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
21:19:41.633: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
21:19:41.634: [NVIDIA Audio Effects:] NVIDIA denoiser disabled, redistributable not found or could not be loaded.
21:19:41.634: Failed to get NVVideoEffects.dll version info size
21:19:41.635: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
21:19:41.642: [obs-browser]: Version 2.24.6
21:19:41.642: [obs-browser]: CEF Version 127.0.6533.120 (runtime), 127.145.7+g2b7d20b+chromium-127.0.6533.120 (compiled)
21:19:41.850: [obs-nvenc] NVENC version: 12.2 (compiled) / 13.0 (driver), CUDA driver version: 12.80, AV1 supported: false
21:19:41.950: [obs-websocket] [obs_module_load] you can haz websockets (Version: 5.5.6 | RPC Version: 1)
21:19:41.950: [obs-websocket] [obs_module_load] Qt version (compile-time): 6.6.3 | Qt version (run-time): 6.6.3
21:19:41.950: [obs-websocket] [obs_module_load] Linked ASIO Version: 103100
21:19:41.950: DEPRECATION: obs_frontend_get_global_config is deprecated. Read from global or user configuration explicitly instead.
21:19:41.960: [obs-websocket] [obs_module_load] Module loaded.
21:19:41.964: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
21:19:41.973: ---------------------------------
21:19:41.973: Loaded Modules:
21:19:41.973: win-wasapi.dll
21:19:41.973: win-dshow.dll
21:19:41.973: win-capture.dll
21:19:41.973: vlc-video.dll
21:19:41.973: text-freetype2.dll
21:19:41.973: rtmp-services.dll
21:19:41.973: obs-x264.dll
21:19:41.973: obs-websocket.dll
21:19:41.973: obs-webrtc.dll
21:19:41.973: obs-vst.dll
21:19:41.973: obs-transitions.dll
21:19:41.973: obs-text.dll
21:19:41.973: obs-qsv11.dll
21:19:41.973: obs-outputs.dll
21:19:41.973: obs-nvenc.dll
21:19:41.973: obs-filters.dll
21:19:41.973: obs-ffmpeg.dll
21:19:41.973: obs-browser.dll
21:19:41.973: nv-filters.dll
21:19:41.973: image-source.dll
21:19:41.973: frontend-tools.dll
21:19:41.973: decklink-output-ui.dll
21:19:41.973: decklink-captions.dll
21:19:41.973: coreaudio-encoder.dll
21:19:41.973: Available Encoders:
21:19:41.973: Video Encoders:
21:19:41.973: - ffmpeg_svt_av1 (SVT-AV1)
21:19:41.973: - ffmpeg_aom_av1 (AOM AV1)
21:19:41.973: - obs_nvenc_h264_tex (NVIDIA NVENC H.264)
21:19:41.973: - obs_nvenc_hevc_tex (NVIDIA NVENC HEVC)
21:19:41.973: - obs_x264 (x264)
21:19:41.973: Audio Encoders:
21:19:41.973: - ffmpeg_aac (FFmpeg AAC)
21:19:41.973: - ffmpeg_opus (FFmpeg Opus)
21:19:41.973: - ffmpeg_pcm_s16le (FFmpeg PCM (16-bit))
21:19:41.973: - ffmpeg_pcm_s24le (FFmpeg PCM (24-bit))
21:19:41.973: - ffmpeg_pcm_f32le (FFmpeg PCM (32-bit float))
21:19:41.973: - ffmpeg_alac (FFmpeg ALAC (24-bit))
21:19:41.973: - ffmpeg_flac (FFmpeg FLAC (16-bit))
21:19:41.973: ==== Startup complete ===============================================
21:19:41.976: Encoder ID 'jim_nvenc' is deprecated and may be removed in a future version.
21:19:42.026: All scene data cleared
21:19:42.026: ------------------------------------------------
21:19:42.028: [win-wasapi: 'Desktop'] update settings:
21:19:42.028: device id: {0.0.0.00000000}.{5fb14b25-c9db-4da7-a55c-8fc819309759}
21:19:42.028: use device timing: 1
21:19:42.029: [Loaded global audio device]: 'Desktop'
21:19:42.029: [win-wasapi: 'MXL 990'] update settings:
21:19:42.029: device id: {0.0.1.00000000}.{d8fc523c-47c2-4f7c-b64e-07900c7f194b}
21:19:42.029: use device timing: 0
21:19:42.029: [Loaded global audio device]: 'MXL 990'
21:19:42.030: [win-wasapi: 'Berserk Boy'] update settings:
21:19:42.030: executable: BERSERK BOY.exe
21:19:42.030: title: BERSERK BOY (0.0.6.3, 10:44:36 PM)
21:19:42.030: class: YYGameMakerYY
21:19:42.030: priority: 2
21:19:42.031: [WASAPISource::TryInitialize]:[[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]] Failed to find window
21:19:42.031: WASAPI: Device '' failed to start (source: Berserk Boy)
21:19:42.063: WASAPI: Device 'Line 1/2 (M-Audio M-Track Solo and Duo)' [44100 Hz] initialized (source: MXL 990)
21:19:42.082: WASAPI: Device 'Speakers (Razer Leviathan V2 X)' [48000 Hz] initialized (source: Desktop)
21:19:43.127: [win-wasapi: 'YouTube (Audio)'] update settings:
21:19:43.127: executable: msedge.exe
21:19:43.127: title: YouTube - First Time EVER Playing UFO 50 - Wicked Retro Game Collection - YouTube
21:19:43.127: class: Chrome_WidgetWin_1
21:19:43.127: priority: 2
21:19:43.128: [window-capture: 'YouTube'] update settings:
21:19:43.128: executable: msedge.exe
21:19:43.128: method selected: Automatic
21:19:43.128: method chosen: WGC
21:19:43.128: force SDR: false
21:19:43.128: [win-wasapi: 'Archaeogem'] update settings:
21:19:43.128: executable: Archaeogem.exe
21:19:43.128: title: Archaeogem
21:19:43.128: class: YYGameMakerYY
21:19:43.128: priority: 2
21:19:43.128: [win-wasapi: 'Slippi'] update settings:
21:19:43.128: executable: Slippi Dolphin.exe
21:19:43.128: title: Faster Melee - Slippi (3.4.5)
21:19:43.128: class: wxWindowNR
21:19:43.129: [WASAPISource::TryInitialize]:[[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]] Failed to find window
21:19:43.129: WASAPI: Device '' failed to start (source: YouTube (Audio))
21:19:43.130: [WASAPISource::TryInitialize]:[[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]] Failed to find window
21:19:43.130: WASAPI: Device '' failed to start (source: Archaeogem)
21:19:43.131: [WASAPISource::TryInitialize]:[[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]] Failed to find window
21:19:43.131: WASAPI: Device '' failed to start (source: Slippi)
21:19:43.135: Switched to scene 'Scene'
21:19:43.136: ------------------------------------------------
21:19:43.136: Loaded scenes:
21:19:43.136: - scene 'Scene':
21:19:43.136: - source: 'YouTube' (window_capture)
21:19:43.136: - source: 'Slippi' (wasapi_process_output_capture)
21:19:43.136: - source: 'MXL 990' (wasapi_input_capture)
21:19:43.136: - source: 'Berserk Boy' (wasapi_process_output_capture)
21:19:43.136: - source: 'Archaeogem' (wasapi_process_output_capture)
21:19:43.136: - source: 'Game' (game_capture)
Part 2:
21:20:10.181: WASAPI: Device '[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]' [48000 Hz] initialized (source: Archaeogem)
21:20:12.380: [game-capture: 'Game'] attempting to hook process: Archaeogem.exe
21:20:12.417: [game-capture: 'Game'] using helper (compatibility hook)
21:20:12.451: [game-capture: 'Game'] hook not loaded yet, retrying..
21:20:15.396: [game-capture: 'Game'] attempting to hook process: Archaeogem.exe
21:20:15.434: [game-capture: 'Game'] DXGI_SWAP_CHAIN_DESC:
21:20:15.434: BufferDesc.Width: 1920
21:20:15.434: BufferDesc.Height: 1080
21:20:15.434: BufferDesc.RefreshRate.Numerator: 0
21:20:15.434: BufferDesc.RefreshRate.Denominator: 1
21:20:15.434: BufferDesc.Format: 87
21:20:15.434: BufferDesc.ScanlineOrdering: 0
21:20:15.434: BufferDesc.Scaling: 0
21:20:15.434: SampleDesc.Count: 1
21:20:15.434: SampleDesc.Quality: 0
21:20:15.434: BufferUsage: 32
21:20:15.434: BufferCount: 2
21:20:15.434: Windowed: 1
21:20:15.434: SwapEffect: 0
21:20:15.434: Flags: 0
21:20:15.435: [game-capture: 'Game'] d3d11 shared texture capture successful
21:20:15.446: [game-capture: 'Game'] shared texture capture successful
21:20:43.884: [obs-nvenc: 'advanced_video_recording'] settings:
21:20:43.884: codec: H264
21:20:43.884: rate_control: CQP
21:20:43.884: cqp: 20
21:20:43.884: keyint: 250
21:20:43.884: preset: p6
21:20:43.884: tuning: hq
21:20:43.884: multipass: qres
21:20:43.884: profile: high
21:20:43.884: width: 1920
21:20:43.884: height: 1080
21:20:43.884: b-frames: 2
21:20:43.884: b-ref-mode: 0
21:20:43.884: lookahead: true (16 frames)
21:20:43.884: aq: true
21:20:43.884:
21:20:43.979: ---------------------------------
21:20:43.981: [FFmpeg aac encoder: 'Track1'] bitrate: 320, channels: 2, channel_layout: stereo, track: 1
21:20:43.981:
21:20:43.992: ---------------------------------
21:20:43.992: [FFmpeg aac encoder: 'Track2'] bitrate: 320, channels: 2, channel_layout: stereo, track: 2
21:20:43.992:
21:20:43.992: [FFmpeg aac encoder: 'Track3'] bitrate: 320, channels: 2, channel_layout: stereo, track: 3
21:20:43.992:
21:20:44.026: ==== Recording Start ===============================================
21:20:44.026: [ffmpeg muxer: 'adv_file_output'] Writing file 'C:/Users/nelde/Videos/Captures/2025-04-02 21-20-43.mkv'...
22:14:16.381: [ffmpeg muxer: 'adv_file_output'] Output of file 'C:/Users/nelde/Videos/Captures/2025-04-02 21-20-43.mkv' stopped
22:14:16.381: Output 'adv_file_output': stopping
22:14:16.381: Output 'adv_file_output': Total frames output: 192716
22:14:16.381: Output 'adv_file_output': Total drawn frames: 192742
22:14:16.381: ==== Recording Stop ================================================
22:27:53.220: [obs-nvenc: 'advanced_video_recording'] settings:
22:27:53.220: codec: H264
22:27:53.220: rate_control: CQP
22:27:53.220: cqp: 20
22:27:53.220: keyint: 250
22:27:53.220: preset: p6
22:27:53.220: tuning: hq
22:27:53.220: multipass: qres
22:27:53.220: profile: high
22:27:53.220: width: 1920
22:27:53.220: height: 1080
22:27:53.220: b-frames: 2
22:27:53.220: b-ref-mode: 0
22:27:53.220: lookahead: true (16 frames)
22:27:53.220: aq: true
22:27:53.220:
22:27:53.305: ---------------------------------
22:27:53.306: [FFmpeg aac encoder: 'Track1'] bitrate: 320, channels: 2, channel_layout: stereo, track: 1
22:27:53.306:
22:27:53.306: ---------------------------------
22:27:53.306: [FFmpeg aac encoder: 'Track2'] bitrate: 320, channels: 2, channel_layout: stereo, track: 2
22:27:53.306:
22:27:53.307: ---------------------------------
22:27:53.307: [FFmpeg aac encoder: 'Track3'] bitrate: 320, channels: 2, channel_layout: stereo, track: 3
22:27:53.307:
22:27:53.317: ==== Recording Start ===============================================
22:27:53.317: [ffmpeg muxer: 'adv_file_output'] Writing file 'C:/Users/nelde/Videos/Captures/2025-04-02 22-27-53.mkv'...
22:51:29.970: [WASAPISource::ProcessCaptureData] window disappeared
22:51:29.979: [game-capture: 'Game'] capture window no longer exists, terminating capture
22:51:29.979: [game-capture: 'Game'] capture stopped
22:51:29.987: Device '[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]' invalidated. Retrying (source: Archaeogem)
22:51:32.989: [WASAPISource::TryInitialize]:[[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]] Failed to find window
22:51:34.072: [ffmpeg muxer: 'adv_file_output'] Output of file 'C:/Users/nelde/Videos/Captures/2025-04-02 22-27-53.mkv' stopped
22:51:34.072: Output 'adv_file_output': stopping
22:51:34.072: Output 'adv_file_output': Total frames output: 85220
22:51:34.072: Output 'adv_file_output': Total drawn frames: 85244 (85245 attempted)
22:51:34.072: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 1 (0.0%)
22:51:34.072: Video stopped, number of skipped frames due to encoding lag: 1/85244 (0.0%)
22:51:34.074: ==== Recording Stop ================================================
22:52:06.731: Max audio buffering reached!
22:52:06.731: adding 960 milliseconds of audio buffering, total audio buffering is now 960 milliseconds (source: Desktop)
22:52:06.731:
22:52:06.751: Source Desktop audio is lagging (over by 35384.08 ms) at max audio buffering. Restarting source audio.
22:52:19.368: ==== Shutting down ==================================================
22:52:19.404: WASAPI: Device 'Speakers (Razer Leviathan V2 X)' Terminated
22:52:19.409: WASAPI: Device '[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]' Terminated
22:52:19.409: WASAPI: Device 'Line 1/2 (M-Audio M-Track Solo and Duo)' Terminated
22:52:19.413: WASAPI: Device '[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]' Terminated
22:52:19.414: WASAPI: Device '[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]' Terminated
22:52:19.446: All scene data cleared
22:52:19.446: ------------------------------------------------
22:52:19.574: [obs-websocket] [obs_module_unload] Shutting down...
22:52:19.579: Tried to call obs_frontend_remove_event_callback with no callbacks!
22:52:19.579: [obs-websocket] [obs_module_unload] Finished shutting down.
22:52:19.690: [Scripting] Total detached callbacks: 0
22:52:19.690: Freeing OBS context data
22:52:19.719: == Profiler Results =============================
22:52:19.719: run_program_init: 3666.26 ms
22:52:19.719: ┣OBSApp::AppInit: 26.901 ms
22:52:19.719: ┃ ┗OBSApp::InitLocale: 1.525 ms
22:52:19.719: ┗OBSApp::OBSInit: 3608.93 ms
22:52:19.719: ┣obs_startup: 4.185 ms
22:52:19.719: ┗OBSBasic::OBSInit: 3285.75 ms
22:52:19.719: ┣OBSBasic::InitBasicConfig: 18.52 ms
22:52:19.719: ┣OBSBasic::ResetAudio: 0.268 ms
22:52:19.719: ┣OBSBasic::ResetVideo: 247.31 ms
22:52:19.719: ┃ ┗obs_init_graphics: 245.024 ms
22:52:19.719: ┃ ┗shader compilation: 81.807 ms
22:52:19.719: ┣OBSBasic::InitOBSCallbacks: 0.006 ms
22:52:19.719: ┣OBSBasic::InitHotkeys: 0.024 ms
22:52:19.719: ┣obs_load_all_modules2: 359.88 ms
22:52:19.719: ┃ ┣obs_init_module(aja-output-ui.dll): 0.175 ms
22:52:19.719: ┃ ┣obs_init_module(aja.dll): 0.154 ms
22:52:19.719: ┃ ┣obs_init_module(coreaudio-encoder.dll): 1.466 ms
22:52:19.719: ┃ ┣obs_init_module(decklink-captions.dll): 0.001 ms
22:52:19.719: ┃ ┣obs_init_module(decklink-output-ui.dll): 0 ms
22:52:19.719: ┃ ┣obs_init_module(decklink.dll): 2.56 ms
22:52:19.719: ┃ ┣obs_init_module(frontend-tools.dll): 6.044 ms
22:52:19.719: ┃ ┣obs_init_module(image-source.dll): 0.008 ms
22:52:19.719: ┃ ┣obs_init_module(nv-filters.dll): 1.123 ms
22:52:19.719: ┃ ┣obs_init_module(obs-browser.dll): 0.246 ms
22:52:19.719: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.746 ms
22:52:19.719: ┃ ┣obs_init_module(obs-filters.dll): 0.04 ms
22:52:19.719: ┃ ┣obs_init_module(obs-nvenc.dll): 203.061 ms
22:52:19.719: ┃ ┃ ┗nvenc_check: 203.053 ms
22:52:19.719: ┃ ┣obs_init_module(obs-outputs.dll): 0.007 ms
22:52:19.719: ┃ ┣obs_init_module(obs-qsv11.dll): 91.507 ms
22:52:19.719: ┃ ┣obs_init_module(obs-text.dll): 0.207 ms
22:52:19.719: ┃ ┣obs_init_module(obs-transitions.dll): 0.004 ms
22:52:19.719: ┃ ┣obs_init_module(obs-vst.dll): 0.006 ms
22:52:19.719: ┃ ┣obs_init_module(obs-webrtc.dll): 0.006 ms
22:52:19.719: ┃ ┣obs_init_module(obs-websocket.dll): 9.645 ms
22:52:19.719: ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
22:52:19.719: ┃ ┣obs_init_module(rtmp-services.dll): 1.118 ms
22:52:19.719: ┃ ┣obs_init_module(text-freetype2.dll): 0.219 ms
22:52:19.719: ┃ ┣obs_init_module(vlc-video.dll): 0.036 ms
22:52:19.719: ┃ ┣obs_init_module(win-capture.dll): 1.712 ms
22:52:19.719: ┃ ┣obs_init_module(win-dshow.dll): 1.612 ms
22:52:19.719: ┃ ┣obs_init_module(win-wasapi.dll): 2.083 ms
22:52:19.719: ┃ ┗reset_win32_symbol_paths: 0.247 ms
22:52:19.719: ┣OBSBasic::InitService: 2.184 ms
22:52:19.719: ┣OBSBasic::ResetOutputs: 0.699 ms
22:52:19.719: ┣OBSBasic::CreateHotkeys: 0.037 ms
22:52:19.719: ┣OBSBasic::InitPrimitives: 0.097 ms
22:52:19.719: ┗OBSBasic::Load: 1184.68 ms
22:52:19.719: obs_hotkey_thread(25 ms): min=0.004 ms, median=0.005 ms, max=11.206 ms, 99th percentile=0.073 ms, 100% below 25 ms
22:52:19.719: audio_thread(Audio): min=0.011 ms, median=3.354 ms, max=70.134 ms, 99th percentile=9.094 ms
22:52:19.719: ┗receive_audio: min=0.001 ms, median=0.6 ms, max=68.534 ms, 99th percentile=4.262 ms, 2.5008 calls per parent call
22:52:19.719: ┣buffer_audio: min=0 ms, median=0 ms, max=0.106 ms, 99th percentile=0.001 ms
22:52:19.719: ┗do_encode: min=0.004 ms, median=0.597 ms, max=68.532 ms, 99th percentile=4.259 ms
22:52:19.719: ┣encode(Track1): min=0.012 ms, median=1.027 ms, max=68.522 ms, 99th percentile=7.63 ms, 0.333333 calls per parent call
22:52:19.719: ┣encode(Track2): min=0.003 ms, median=1.375 ms, max=6.42 ms, 99th percentile=3.066 ms, 0.333333 calls per parent call
22:52:19.719: ┣encode(Track3): min=0.004 ms, median=0.085 ms, max=0.303 ms, 99th percentile=0.115 ms, 0.333333 calls per parent call
22:52:19.719: ┗send_packet: min=0 ms, median=0.01 ms, max=6.803 ms, 99th percentile=0.043 ms
22:52:19.719: obs_graphics_thread(16.6667 ms): min=0.058 ms, median=0.321 ms, max=1104.27 ms, 99th percentile=1.031 ms, 99.9991% below 16.667 ms
22:52:19.719: ┣tick_sources: min=0.001 ms, median=0.01 ms, max=1103.9 ms, 99th percentile=0.134 ms
22:52:19.719: ┣output_frame: min=0.05 ms, median=0.19 ms, max=14.996 ms, 99th percentile=0.757 ms
22:52:19.719: ┃ ┗gs_context(video->graphics): min=0.05 ms, median=0.189 ms, max=14.995 ms, 99th percentile=0.753 ms
22:52:19.719: ┃ ┣render_video: min=0.003 ms, median=0.171 ms, max=12.165 ms, 99th percentile=0.539 ms
22:52:19.719: ┃ ┃ ┣render_main_texture: min=0.002 ms, median=0.017 ms, max=1.667 ms, 99th percentile=0.038 ms
22:52:19.719: ┃ ┃ ┣render_convert_texture: min=0.008 ms, median=0.01 ms, max=0.544 ms, 99th percentile=0.037 ms, 0.833779 calls per parent call
22:52:19.719: ┃ ┃ ┗output_gpu_encoders: min=0 ms, median=0.032 ms, max=4.44 ms, 99th percentile=0.265 ms, 0.833779 calls per parent call
22:52:19.719: ┃ ┗gs_flush: min=0.003 ms, median=0.021 ms, max=7.559 ms, 99th percentile=0.25 ms
22:52:19.719: ┗render_displays: min=0 ms, median=0.091 ms, max=52.114 ms, 99th percentile=0.393 ms
22:52:19.719: obs_gpu_encode_thread(16.6667 ms): min=0.262 ms, median=0.416 ms, max=15.756 ms, 99th percentile=1.273 ms, 100% below 16.667 ms
22:52:19.719: ┣gpu_encode_frame: min=0.246 ms, median=0.394 ms, max=15.732 ms, 99th percentile=1.234 ms
22:52:19.719: ┗send_packet: min=0.005 ms, median=0.012 ms, max=5.181 ms, 99th percentile=0.053 ms
22:52:19.719: obs_gpu_encode_thread(16.6667 ms): min=0.285 ms, median=0.427 ms, max=7.509 ms, 99th percentile=1.3 ms, 100% below 16.667 ms
22:52:19.719: ┣gpu_encode_frame: min=0.27 ms, median=0.399 ms, max=7.486 ms, 99th percentile=1.265 ms
22:52:19.719: ┗send_packet: min=0.005 ms, median=0.012 ms, max=4.819 ms, 99th percentile=0.079 ms
22:52:19.719: =================================================
22:52:19.719: == Profiler Time Between Calls ==================
22:52:19.719: obs_hotkey_thread(25 ms): min=24.497 ms, median=25.93 ms, max=62.326 ms, 6.59233% within ±2% of 25 ms (0.000465988% lower, 93.4072% higher)
22:52:19.719: obs_graphics_thread(16.6667 ms): min=0.469 ms, median=16.667 ms, max=1104.27 ms, 99.928% within ±2% of 16.667 ms (0.0377919% lower, 0.0341926% higher)
22:52:19.719: obs_gpu_encode_thread(16.6667 ms): min=1.165 ms, median=16.667 ms, max=43.309 ms, 98.4248% within ±2% of 16.667 ms (0.790188% lower, 0.784999% higher)
22:52:19.719: obs_gpu_encode_thread(16.6667 ms): min=1.724 ms, median=16.666 ms, max=49.457 ms, 98.3365% within ±2% of 16.667 ms (0.84699% lower, 0.816489% higher)
22:52:20.062: Number of memory leaks: 0
