Question / Help Framerate after 10 seconds starts to slow down and then skip for a second, then resumes.
Nirud
I've posted the log. Let me know if I can do anything. I did the speed test with Twitch.tv and using a server with 10000kbps and 100quality and yet my stream has a slowdown. Also i'm using a network adapter that plugs into the wall which i'm not sure if going to cause any issues but i've never noticed any problems with latency when im gaming. Hope this offers some proper context. Let me know what you think.
16:14:39.788: CPU Name: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
16:14:39.788: CPU Speed: 3398MHz
16:14:39.788: Physical Cores: 4, Logical Cores: 4
16:14:39.788: Physical Memory: 16322MB Total, 5401MB Free
16:14:39.788: Windows Version: 6.1 Build 7601 (revision: 24168; 64-bit)
16:14:39.788: Running as administrator: false
16:14:39.788: Aero is Enabled
16:14:39.789: Portable mode: false
16:14:39.878: OBS 21.1.2 (64bit, windows)
16:14:39.878: ---------------------------------
16:14:39.879: ---------------------------------
16:14:39.879: audio settings reset:
16:14:39.879: samples per sec: 44100
16:14:39.879: speakers: 2
16:14:39.880: ---------------------------------
16:14:39.880: Initializing D3D11...
16:14:39.880: Available Video Adapters:
16:14:39.882: Adapter 1: NVIDIA GeForce GTX 1070 Ti
16:14:39.882: Dedicated VRAM: 4182441984
16:14:39.882: Shared VRAM: 3994445824
16:14:39.882: output 1: pos={0, 0}, size={2560, 1440}, attached=true
16:14:39.882: output 2: pos={2560, 0}, size={1920, 1080}, attached=true
16:14:39.885: Loading up D3D11 on adapter NVIDIA GeForce GTX 1070 Ti (0)
16:14:39.900: D3D11 loaded successfully, feature level used: 45056
16:14:40.617: ---------------------------------
16:14:40.617: video settings reset:
16:14:40.617: base resolution: 2560x1440
16:14:40.617: output resolution: 1920x1080
16:14:40.617: downscale filter: Lanczos
16:14:40.617: fps: 60/1
16:14:40.617: format: NV12
16:14:40.617: YUV mode: 601/Full
16:14:40.619: Audio monitoring device:
16:14:40.619: name: Default
16:14:40.619: id: default
16:14:40.619: ---------------------------------
16:14:40.621: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
16:14:40.637: [CoreAudio encoder]: Adding CoreAudio AAC encoder
16:14:40.681: [AMF] AMF Test failed due to one or more errors.
16:14:40.681: Failed to initialize module 'enc-amf.dll'
16:14:40.709: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
16:14:40.710: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
16:14:40.710: (127)
16:14:40.710: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
16:14:40.712: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
16:14:40.715: [browser_source: 'Version: 1.31.0']
16:14:40.722: NVENC supported
16:14:40.838: Couldn't find VLC installation, VLC video source disabled
16:14:40.843: No blackmagic support
16:14:40.849: ---------------------------------
16:14:40.849: Loaded Modules:
16:14:40.849: win-wasapi.dll
16:14:40.849: win-mf.dll
16:14:40.849: win-dshow.dll
16:14:40.849: win-decklink.dll
16:14:40.849: win-capture.dll
16:14:40.849: vlc-video.dll
16:14:40.849: text-freetype2.dll
16:14:40.849: rtmp-services.dll
16:14:40.849: obs-x264.dll
16:14:40.849: obs-vst.dll
16:14:40.849: obs-transitions.dll
16:14:40.849: obs-text.dll
16:14:40.849: obs-qsv11.dll
16:14:40.849: obs-outputs.dll
16:14:40.849: obs-filters.dll
16:14:40.849: obs-ffmpeg.dll
16:14:40.849: obs-browser.dll
16:14:40.849: image-source.dll
16:14:40.849: frontend-tools.dll
16:14:40.849: enc-amf.dll
16:14:40.849: coreaudio-encoder.dll
16:14:40.849: ==== Startup complete ===============================================
16:14:40.864: All scene data cleared
16:14:40.864: ------------------------------------------------
16:14:40.883: WASAPI: Device 'Speakers (Yeti Stereo Microphone)' initialized
16:14:40.939: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
16:14:40.948: WASAPI: Device 'Microphone (Yeti Stereo Microphone)' initialized
16:14:41.159: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
16:14:41.426: [game-capture: 'World of Warcraft'] attempting to hook process: Wow-64.exe
16:14:41.427: Switched to scene 'World of Warcraft Recording'
16:14:41.428: ------------------------------------------------
16:14:41.428: Loaded scenes:
16:14:41.428: - scene 'World of Warcraft Recording':
16:14:41.428: - source: 'World of Warcraft' (game_capture)
16:14:41.428: - source: 'Video Capture Device' (dshow_input)
16:14:41.436: [game-capture: 'World of Warcraft'] shared texture capture successful
16:15:05.434: Settings changed (outputs)
16:15:05.434: ------------------------------------------------
16:15:10.842: ---------------------------------
16:15:10.842: [NVENC encoder: 'simple_h264_stream'] settings:
16:15:10.842: rate_control: CBR
16:15:10.842: bitrate: 6000
16:15:10.842: cqp: 0
16:15:10.842: keyint: 120
16:15:10.842: preset: default
16:15:10.842: profile: main
16:15:10.842: level: auto
16:15:10.842: width: 1920
16:15:10.842: height: 1080
16:15:10.842: 2-pass: true
16:15:10.842: b-frames: 2
16:15:10.842: GPU: 0
16:15:10.842:
16:15:11.117: [CoreAudio AAC: 'simple_aac']: settings:
16:15:11.117: mode: AAC
16:15:11.117: bitrate: 160
16:15:11.117: sample rate: 44100
16:15:11.117: cbr: on
16:15:11.117: output buffer: 1536
16:15:11.118: [rtmp stream: 'simple_stream'] Connecting to RTMP URL rtmp://live-sea.twitch.tv/app...
16:15:11.160: [rtmp stream: 'simple_stream'] Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
16:15:12.035: [rtmp stream: 'simple_stream'] Connection to rtmp://live-sea.twitch.tv/app successful
16:15:12.035: [rtmp stream: 'simple_stream'] New socket loop enabled by user
16:15:12.035: [rtmp stream: 'simple_stream'] Low latency mode enabled by user
16:15:12.038: ==== Streaming Start ===============================================
16:16:17.956: [rtmp stream: 'simple_stream'] User stopped the stream
16:16:17.993: socket_thread_windows: Normal exit
16:16:17.993: Output 'simple_stream': stopping
16:16:17.993: Output 'simple_stream': Total frames output: 3945
16:16:17.993: Output 'simple_stream': Total drawn frames: 4006 (4013 attempted)
16:16:17.993: Output 'simple_stream': Number of lagged frames due to rendering lag/stalls: 7 (0.2%)
16:16:17.993: [rtmp stream: 'simple_stream'] Freeing 4 remaining packets
16:16:17.995: ==== Streaming Stop ================================================
