Question / Help Frame drops other than with Multi-adapter Compatibility
Post an updated log.
12:47:25.776: CPU Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
12:47:25.776: CPU Speed: 4008MHz
12:47:25.776: Physical Cores: 4, Logical Cores: 8
12:47:25.776: Physical Memory: 32639MB Total, 25792MB Free
12:47:25.776: Windows Version: 10.0 Build 14393 (revision: 1198; 64-bit)
12:47:25.776: Running as administrator: false
12:47:25.776: Aero is Enabled (Aero is always on for windows 8 and above)
12:47:25.777: Portable mode: false
12:47:25.785: OBS 18.0.1 (64bit, windows)
12:47:25.785: ---------------------------------
12:47:25.785: audio settings reset:
12:47:25.785: samples per sec: 44100
12:47:25.785: speakers: 2
12:47:25.786: ---------------------------------
12:47:25.786: Initializing D3D11..
12:47:25.786: Available Video Adapters:
12:47:25.787: Adapter 1: NVIDIA GeForce GTX 1060 6GB
12:47:25.787: Dedicated VRAM: 2084896768
12:47:25.787: Shared VRAM: 4227663872
12:47:25.787: output 1: pos={0, 0}, size={1920, 1080}, attached=true
12:47:25.787: output 2: pos={1920, 0}, size={1920, 1080}, attached=true
12:47:25.787: Adapter 2: Intel(R) HD Graphics 530
12:47:25.787: Dedicated VRAM: 134217728
12:47:25.788: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 6GB (0)
12:47:26.209: D3D11 loaded sucessfully, feature level used: 45056
12:47:26.727: ---------------------------------
12:47:26.727: video settings reset:
12:47:26.727: base resolution: 1920x1080
12:47:26.727: output resolution: 1920x1080
12:47:26.727: downscale filter: Bilinear
12:47:26.727: fps: 240/1
12:47:26.727: format: NV12
12:47:26.728: Audio monitoring device:
12:47:26.728: name: Default
12:47:26.728: id: default
12:47:26.728: ---------------------------------
12:47:26.729: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
12:47:26.730: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
12:47:26.731: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
12:47:26.737: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
12:47:26.738: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
12:47:26.738: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
12:47:26.739: Failed to load 'en-US' text for module: 'obs-browser.dll'
12:47:26.739: [browser_source: 'Version: 1.29.0']
12:47:26.740: NVENC supported
12:47:26.749: Couldn't find VLC installation, VLC video source disabled
12:47:26.753: No blackmagic support
12:47:26.925: ---------------------------------
12:47:26.925: Loaded Modules:
12:47:26.925: win-wasapi.dll
12:47:26.925: win-mf.dll
12:47:26.925: win-ivcam.dll
12:47:26.925: win-dshow.dll
12:47:26.925: win-decklink.dll
12:47:26.925: win-capture.dll
12:47:26.925: vlc-video.dll
12:47:26.925: text-freetype2.dll
12:47:26.925: rtmp-services.dll
12:47:26.925: obs-x264.dll
12:47:26.925: obs-vst.dll
12:47:26.925: obs-transitions.dll
12:47:26.925: obs-text.dll
12:47:26.925: obs-qsv11.dll
12:47:26.925: obs-outputs.dll
12:47:26.925: obs-filters.dll
12:47:26.925: obs-ffmpeg.dll
12:47:26.925: obs-browser.dll
12:47:26.925: image-source.dll
12:47:26.925: frontend-tools.dll
12:47:26.925: enc-amf.dll
12:47:26.925: coreaudio-encoder.dll
12:47:26.925: ==== Startup complete ===============================================
12:47:26.925: Service '' not found
12:47:26.926: All scene data cleared
12:47:26.926: ------------------------------------------------
12:47:26.944: WASAPI: Device 'Speakers (Logitech G35 Gaming Headset)' initialized
12:47:26.947: WASAPI: Device 'Microphone (Yeti Stereo Microphone)' initialized
12:47:26.950: Switched to scene 'Scene'
12:47:26.950: ------------------------------------------------
12:47:26.950: Loaded scenes:
12:47:26.950: - scene 'Scene':
12:47:26.950: - source: 'Display Capture' (monitor_capture)
12:47:26.951: CalculateFileHash: Failed to open file 'C:\Users\glyffe\AppData\Roaming\obs-studio\updates\manifest.json': 2
12:47:26.982: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
12:47:32.636: User Removed source 'Display Capture' (monitor_capture) from scene 'Scene'
12:47:36.073: rtmp-common.c: [initialize_output] Could not find service ''
12:47:36.074: rtmp-common.c: [initialize_output] Could not find service ''
12:47:36.123: rtmp-common.c: [initialize_output] Could not find service ''
12:47:42.027: rtmp-common.c: [initialize_output] Could not find service ''
12:47:42.057: rtmp-common.c: [initialize_output] Could not find service ''
12:47:42.187: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
12:47:43.306: rtmp-common.c: [initialize_output] Could not find service ''
12:47:44.186: rtmp-common.c: [initialize_output] Could not find service ''
12:47:45.035: rtmp-common.c: [initialize_output] Could not find service ''
12:48:07.057: User added source 'Game Capture' (game_capture) to scene 'Scene'
12:48:11.517: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
12:48:11.518: [game-capture: 'Game Capture'] using helper (compatibility hook)
12:48:11.520: [game-capture: 'Game Capture'] hook not loaded yet, retrying..
12:48:13.517: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
12:48:15.541: [game-capture: 'Game Capture'] capture stopped
12:48:17.521: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
12:48:17.524: [game-capture: 'Game Capture'] capture stopped
12:48:21.525: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
12:48:21.532: [game-capture: 'Game Capture'] shared texture capture successful
12:48:25.466: [game-capture: 'Game Capture'] capture window no longer exists, terminating capture
12:48:25.466: [game-capture: 'Game Capture'] capture stopped
12:48:25.529: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
12:48:25.549: [game-capture: 'Game Capture'] shared texture capture successful
12:48:25.649: [game-capture: 'Game Capture'] gl shared texture capture successful
12:48:25.653: [game-capture: 'Game Capture'] shared texture capture successful
12:48:27.247: ==== Shutting down ==================================================
12:48:27.250: Switched to scene '(null)'
12:48:27.250: [game-capture: 'Game Capture'] capture stopped
12:48:27.250: WASAPI: Device 'Speakers (Logitech G35 Gaming Headset)' Terminated
12:48:27.255: WASAPI: Device 'Microphone (Yeti Stereo Microphone)' Terminated
12:48:27.256: All scene data cleared
12:48:27.256: ------------------------------------------------
12:48:27.303: Freeing OBS context data
12:48:27.334: == Profiler Results =============================
12:48:27.334: run_program_init: 1215.34 ms
12:48:27.334: ┣OBSApp::AppInit: 1.262 ms
12:48:27.334: ┃ ┗OBSApp::InitLocale: 0.696 ms
12:48:27.334: ┗OBSApp::OBSInit: 1210.21 ms
12:48:27.334: ┣obs_startup: 0.729 ms
12:48:27.334: ┗OBSBasic::OBSInit: 1192.91 ms
12:48:27.334: ┣OBSBasic::InitBasicConfig: 0.264 ms
12:48:27.334: ┣OBSBasic::ResetAudio: 0.146 ms
12:48:27.334: ┣OBSBasic::ResetVideo: 943.052 ms
12:48:27.334: ┣OBSBasic::InitOBSCallbacks: 0.003 ms
12:48:27.334: ┣OBSBasic::InitHotkeys: 0.029 ms
12:48:27.334: ┣obs_load_all_modules: 196.675 ms
12:48:27.334: ┃ ┣obs_init_module(coreaudio-encoder.dll): 0.289 ms
12:48:27.334: ┃ ┣obs_init_module(enc-amf.dll): 0.185 ms
12:48:27.334: ┃ ┣obs_init_module(frontend-tools.dll): 0.98 ms
12:48:27.334: ┃ ┣obs_init_module(image-source.dll): 0.007 ms
12:48:27.334: ┃ ┣obs_init_module(obs-browser.dll): 0.035 ms
12:48:27.334: ┃ ┣obs_init_module(obs-ffmpeg.dll): 0.391 ms
12:48:27.334: ┃ ┣obs_init_module(obs-filters.dll): 0.006 ms
12:48:27.334: ┃ ┣obs_init_module(obs-outputs.dll): 0.003 ms
12:48:27.334: ┃ ┣obs_init_module(obs-qsv11.dll): 2.952 ms
12:48:27.334: ┃ ┣obs_init_module(obs-text.dll): 0.628 ms
12:48:27.334: ┃ ┣obs_init_module(obs-transitions.dll): 0.004 ms
12:48:27.334: ┃ ┣obs_init_module(obs-vst.dll): 0.001 ms
12:48:27.334: ┃ ┣obs_init_module(obs-x264.dll): 0.001 ms
12:48:27.334: ┃ ┣obs_init_module(rtmp-services.dll): 0.206 ms
12:48:27.334: ┃ ┣obs_init_module(text-freetype2.dll): 0.034 ms
12:48:27.334: ┃ ┣obs_init_module(vlc-video.dll): 0.025 ms
12:48:27.334: ┃ ┣obs_init_module(win-capture.dll): 0.08 ms
12:48:27.334: ┃ ┣obs_init_module(win-decklink.dll): 2.447 ms
12:48:27.334: ┃ ┣obs_init_module(win-dshow.dll): 0.86 ms
12:48:27.334: ┃ ┣obs_init_module(win-ivcam.dll): 0.001 ms
12:48:27.334: ┃ ┣obs_init_module(win-mf.dll): 167.85 ms
12:48:27.334: ┃ ┣obs_init_module(win-wasapi.dll): 0.004 ms
12:48:27.334: ┃ ┗reset_win32_symbol_paths: 0.061 ms
12:48:27.334: ┣OBSBasic::ResetOutputs: 0.288 ms
12:48:27.334: ┣OBSBasic::CreateHotkeys: 0.018 ms
12:48:27.334: ┣OBSBasic::InitService: 0.061 ms
12:48:27.334: ┣OBSBasic::InitPrimitives: 0.172 ms
12:48:27.334: ┗OBSBasic::Load: 24.927 ms
12:48:27.334: obs_hotkey_thread(25 ms): min=0.001 ms, median=0.003 ms, max=24.501 ms, 99th percentile=0.149 ms, 100% below 25 ms
12:48:27.334: audio_thread(Audio): min=0 ms, median=0.029 ms, max=0.414 ms, 99th percentile=0.097 ms
12:48:27.334: obs_video_thread(4.16667 ms): min=0.165 ms, median=0.698 ms, max=86.695 ms, 99th percentile=7.164 ms, 98.3543% below 4.167 ms
12:48:27.334: ┣tick_sources: min=0 ms, median=0.004 ms, max=40.063 ms, 99th percentile=0.11 ms
12:48:27.334: ┣render_displays: min=0 ms, median=0.108 ms, max=36.529 ms, 99th percentile=0.408 ms
12:48:27.334: ┗output_frame: min=0.162 ms, median=0.57 ms, max=50.16 ms, 99th percentile=7.031 ms
12:48:27.334: ┣gs_context(video->graphics): min=0.088 ms, median=0.263 ms, max=49.811 ms, 99th percentile=6.687 ms
12:48:27.334: ┃ ┣render_video: min=0.016 ms, median=0.027 ms, max=49.461 ms, 99th percentile=0.701 ms
12:48:27.334: ┃ ┃ ┣render_main_texture: min=0.001 ms, median=0.003 ms, max=2.428 ms, 99th percentile=0.062 ms
12:48:27.334: ┃ ┃ ┣render_output_texture: min=0.002 ms, median=0.009 ms, max=0.213 ms, 99th percentile=0.024 ms
12:48:27.334: ┃ ┃ ┣render_convert_texture: min=0.001 ms, median=0.007 ms, max=0.06 ms, 99th percentile=0.016 ms
12:48:27.334: ┃ ┃ ┗stage_output_texture: min=0 ms, median=0.006 ms, max=49.415 ms, 99th percentile=0.616 ms
12:48:27.334: ┃ ┣download_frame: min=0 ms, median=0.188 ms, max=27.91 ms, 99th percentile=2.618 ms
12:48:27.334: ┃ ┗gs_flush: min=0.01 ms, median=0.019 ms, max=14.914 ms, 99th percentile=0.326 ms
12:48:27.334: ┗output_video_data: min=0.248 ms, median=0.305 ms, max=1.436 ms, 99th percentile=0.519 ms
12:48:27.334: video_thread(video): min=0 ms, median=0.001 ms, max=0.028 ms, 99th percentile=0.002 ms
12:48:27.334: =================================================
12:48:27.334: == Profiler Time Between Calls ==================
12:48:27.334: obs_hotkey_thread(25 ms): min=24.855 ms, median=25.212 ms, max=49.076 ms, 80.1483% within ±2% of 25 ms (0% lower, 19.8517% higher)
12:48:27.334: obs_video_thread(4.16667 ms): min=1.027 ms, median=4.167 ms, max=86.706 ms, 95.5576% within ±2% of 4.167 ms (2.75472% lower, 1.6877% higher)
12:48:27.335: =================================================
12:48:27.367: Number of memory leaks: 1
I really question why you're recording at 240fps. Literally nothing supports it.
Can you please try at 60fps and see if you have the same issue?
Only other thing I can see is you have a display capture source running in the same scene as game capture. Remove the display capture source from the same scene as your game capture.
I did, it still has the same problem, it has to be something with game capture
Or something on your PC. It's working perfectly fine for everyone else, or we'd be hearing a lot more about it.
Check to make sure you don't have any performance boost/optimization software installed, and try disabling or uninstalling any non-Windows Defender antivirus as those are known to cause issues.
I have nothing on my PC that has impacted it, one day I wake up, turn my pc on and OBS randomly doesn't work
I'm playing minecraft, right now, as I'm typing this, capturing it with OBS and nothing is going wrong.
However, I'm not maxing out my GPU by trying to play at an obnoxious 700+fps which is a complete waste of system resources. Can you try capping FPS in the game at something reasonable and see if you have the same issues?
