Question / Help Frame drops other than with Multi-adapter Compatibility
glyffe
I have a good PC, i7 6700k, 1060 6GB graphics card, and basically the second i make a game capture, my game drops to 22 fps, then when I delete the game capture the game goes back to 700 fps. I enabled "Multi-adapter compatibility" and it only increased my frames to a stable 60. I don't know if this is my drivers or what but OBS used to work perfectly fine with the same settings now it randomly doesn't work and caps my game at 60 fps..
Here are my OBS setting,s
https://gyazo.com/f320f16144b559b333316eb62fa35b75
https://gyazo.com/3768a743a6289cf47fb9c265a9d23219
Fenrir
Forum Admin
Please post a link to a clean log file. To make a clean log file, first restart OBS, then start your stream/recording for ~30 seconds and stop it again. Make sure you replicate any issues as best you can, which means having any games/apps open and captured, etc. When you're done select Help > Log Files > Upload Current Log File. Copy the URL and paste it here.
glyffe
So whenever I turn game capture on I go from 500 to 22 stable...
15:06:46.610: CPU Name: Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
15:06:46.610: CPU Speed: 4008MHz
15:06:46.610: Physical Cores: 4, Logical Cores: 8
15:06:46.610: Physical Memory: 32639MB Total, 25626MB Free
15:06:46.610: Windows Version: 10.0 Build 14393 (revision: 1198; 64-bit)
15:06:46.610: Running as administrator: false
15:06:46.610: Aero is Enabled (Aero is always on for windows 8 and above)
15:06:46.610: Portable mode: false
15:06:46.617: OBS 18.0.1 (64bit, windows)
15:06:46.617: ---------------------------------
15:06:46.617: audio settings reset:
15:06:46.617: samples per sec: 44100
15:06:46.617: speakers: 2
15:06:46.628: ---------------------------------
15:06:46.628: Initializing D3D11..
15:06:46.628: Available Video Adapters:
15:06:46.629: Adapter 1: NVIDIA GeForce GTX 1060 6GB
15:06:46.629: Dedicated VRAM: 2084896768
15:06:46.629: Shared VRAM: 4227663872
15:06:46.629: output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:06:46.629: Adapter 2: Intel(R) HD Graphics 530
15:06:46.629: Dedicated VRAM: 134217728
15:06:46.629: output 1: pos={1920, -7}, size={1920, 1080}, attached=true
15:06:46.630: Loading up D3D11 on adapter NVIDIA GeForce GTX 1060 6GB (0)
15:06:47.085: D3D11 loaded sucessfully, feature level used: 45056
15:06:47.721: ---------------------------------
15:06:47.721: video settings reset:
15:06:47.721: base resolution: 1920x1080
15:06:47.721: output resolution: 1920x1080
15:06:47.721: downscale filter: Bilinear
15:06:47.721: fps: 240/1
15:06:47.721: format: NV12
15:06:47.722: Audio monitoring device:
15:06:47.722: name: Default
15:06:47.722: id: default
15:06:47.722: ---------------------------------
15:06:47.797: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
15:06:47.812: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
15:06:47.827: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
15:06:47.931: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
15:06:47.940: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
15:06:47.950: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
15:06:47.962: Failed to load 'en-US' text for module: 'obs-browser.dll'
15:06:47.962: [browser_source: 'Version: 1.29.0']
15:06:48.007: NVENC supported
15:06:48.183: Couldn't find VLC installation, VLC video source disabled
15:06:48.215: No blackmagic support
15:06:48.513: ---------------------------------
15:06:48.513: Loaded Modules:
15:06:48.513: win-wasapi.dll
15:06:48.513: win-mf.dll
15:06:48.513: win-dshow.dll
15:06:48.513: win-decklink.dll
15:06:48.513: win-capture.dll
15:06:48.513: vlc-video.dll
15:06:48.513: text-freetype2.dll
15:06:48.513: rtmp-services.dll
15:06:48.513: obs-x264.dll
15:06:48.513: obs-vst.dll
15:06:48.513: obs-transitions.dll
15:06:48.513: obs-text.dll
15:06:48.513: obs-qsv11.dll
15:06:48.513: obs-outputs.dll
15:06:48.513: obs-filters.dll
15:06:48.513: obs-ffmpeg.dll
15:06:48.513: obs-browser.dll
15:06:48.513: image-source.dll
15:06:48.513: frontend-tools.dll
15:06:48.513: enc-amf.dll
15:06:48.513: coreaudio-encoder.dll
15:06:48.513: ==== Startup complete ===============================================
15:06:48.513: Service '' not found
15:06:48.516: All scene data cleared
15:06:48.516: ------------------------------------------------
15:06:48.552: WASAPI: Device 'Speakers (Logitech G35 Gaming Headset)' initialized
15:06:48.558: WASAPI: Device 'Microphone (Yeti Stereo Microphone)' initialized
15:06:48.600: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
15:06:53.814: Switched to scene 'Scene'
15:06:53.815: [game-capture: 'Game Capture'] attempting to hook process: ts3client_win64.exe
15:06:53.863: [game-capture: 'Game Capture'] using helper (compatibility hook)
15:06:53.865: [game-capture: 'Game Capture'] hook not loaded yet, retrying..
15:06:53.865: [game-capture: 'Game Capture 2'] attempting to hook process: javaw.exe
15:06:53.867: [game-capture: 'Game Capture 2'] using helper (compatibility hook)
15:06:53.868: [game-capture: 'Game Capture 2'] hook not loaded yet, retrying..
15:06:53.868: ------------------------------------------------
15:06:53.868: Loaded scenes:
15:06:53.868: - scene 'Scene':
15:06:53.868: - source: 'Game Capture' (game_capture)
15:06:53.869: - source: 'Game Capture 2' (game_capture)
15:06:53.869: ------------------------------------------------
15:06:53.870: CalculateFileHash: Failed to open file 'C:\Users\glyffe\AppData\Roaming\obs-studio\updates\manifest.json': 2
15:06:55.810: [game-capture: 'Game Capture'] attempting to hook process: ts3client_win64.exe
15:06:55.812: [game-capture: 'Game Capture 2'] attempting to hook process: javaw.exe
15:06:57.894: [game-capture: 'Game Capture'] capture stopped
15:06:57.897: [game-capture: 'Game Capture 2'] capture stopped
15:06:59.814: [game-capture: 'Game Capture'] attempting to hook process: ts3client_win64.exe
15:06:59.816: [game-capture: 'Game Capture 2'] attempting to hook process: javaw.exe
15:06:59.820: [game-capture: 'Game Capture'] capture stopped
15:06:59.821: [game-capture: 'Game Capture 2'] capture stopped
15:07:03.091: User Removed source 'Game Capture 2' (game_capture) from scene 'Scene'
15:07:03.822: [game-capture: 'Game Capture'] attempting to hook process: ts3client_win64.exe
15:07:03.837: [game-capture: 'Game Capture'] capture stopped
15:07:07.004: User Removed source 'Game Capture' (game_capture) from scene 'Scene'
15:07:09.222: rtmp-common.c: [initialize_output] Could not find service ''
15:07:09.223: rtmp-common.c: [initialize_output] Could not find service ''
15:07:09.274: rtmp-common.c: [initialize_output] Could not find service ''
15:07:10.870: rtmp-common.c: [initialize_output] Could not find service ''
15:07:13.377: rtmp-common.c: [initialize_output] Could not find service ''
15:07:16.058: rtmp-common.c: [initialize_output] Could not find service ''
15:07:16.705: rtmp-common.c: [initialize_output] Could not find service ''
15:07:17.867: rtmp-common.c: [initialize_output] Could not find service ''
15:07:43.596: Settings changed (outputs)
15:07:43.596: ------------------------------------------------
15:08:11.554: User added source 'Display Capture' (monitor_capture) to scene 'Scene'
15:08:24.052: rtmp-common.c: [initialize_output] Could not find service ''
15:08:24.052: ---------------------------------
15:08:24.052: [x264 encoder: 'recording_h264'] preset: veryfast
15:08:24.053: [x264 encoder: 'recording_h264'] settings:
15:08:24.053: rate_control: CBR
15:08:24.053: bitrate: 70000
15:08:24.053: buffer size: 70000
15:08:24.053: crf: 0
15:08:24.053: fps_num: 240
15:08:24.053: fps_den: 1
15:08:24.053: width: 1920
15:08:24.053: height: 1080
15:08:24.053: keyint: 250
15:08:24.053: vfr: off
15:08:24.053:
15:08:24.060: [Media Foundation AAC: 'Track1']: encoder created
15:08:24.060: bitrate: 160
15:08:24.060: channels: 2
15:08:24.060: sample rate: 44100
15:08:24.060: bits-per-sample: 16
15:08:24.060:
15:08:24.061: [Media Foundation AAC: 'Track2']: encoder created
15:08:24.061: bitrate: 160
15:08:24.061: channels: 2
15:08:24.061: sample rate: 44100
15:08:24.061: bits-per-sample: 16
15:08:24.061:
15:08:24.077: ==== Recording Start ===============================================
15:08:24.077: [ffmpeg muxer: 'adv_file_output'] Writing file 'C:/Users/glyffe/Videos/Arcane/2017-05-19 15-08-24.mp4'...
15:09:15.136: [ffmpeg muxer: 'adv_file_output'] Output of file 'C:/Users/glyffe/Videos/Arcane/2017-05-19 15-08-24.mp4' stopped
15:09:15.136: Output 'adv_file_output': stopping
15:09:15.136: Output 'adv_file_output': Total encoded frames: 8847
15:09:15.136: Output 'adv_file_output': Total drawn frames: 12254
15:09:15.136: Output 'adv_file_output': Number of skipped frames due to encoding lag: 12161 (137.5%)
15:09:15.136: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 176 (1.4%)
15:09:15.136: ==== Recording Stop ================================================
15:09:56.043: User Removed source 'Display Capture' (monitor_capture) from scene 'Scene'
15:09:57.717: rtmp-common.c: [initialize_output] Could not find service ''
15:09:57.718: rtmp-common.c: [initialize_output] Could not find service ''
15:09:57.760: rtmp-common.c: [initialize_output] Could not find service ''
15:11:08.163: rtmp-common.c: [initialize_output] Could not find service ''
15:11:08.667: rtmp-common.c: [initialize_output] Could not find service ''
15:11:09.651: rtmp-common.c: [initialize_output] Could not find service ''
15:11:10.475: rtmp-common.c: [initialize_output] Could not find service ''
15:11:11.780: rtmp-common.c: [initialize_output] Could not find service ''
15:11:25.797: Settings changed (outputs)
15:11:25.797: ------------------------------------------------
15:11:28.873: rtmp-common.c: [initialize_output] Could not find service ''
15:11:28.874: rtmp-common.c: [initialize_output] Could not find service ''
15:11:28.919: rtmp-common.c: [initialize_output] Could not find service ''
15:11:29.788: rtmp-common.c: [initialize_output] Could not find service ''
15:11:50.155: Settings changed (outputs)
15:11:50.156: ------------------------------------------------
15:12:50.110: User added source 'Game Capture' (game_capture) to scene 'Scene'
15:12:56.596: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
15:12:56.603: [game-capture: 'Game Capture'] shared texture capture successful
15:13:04.614: [game-capture: 'Game Capture'] capture stopped
15:13:04.816: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
15:13:04.831: [game-capture: 'Game Capture'] shared texture capture successful
15:13:11.769: [game-capture: 'Game Capture'] capture stopped
15:13:11.771: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
15:13:11.793: [game-capture: 'Game Capture'] gl memory capture successful
15:13:11.794: [game-capture: 'Game Capture'] memory capture successful
15:13:23.238: [game-capture: 'Game Capture'] capture stopped
15:13:23.239: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
15:13:23.253: [game-capture: 'Game Capture'] capture stopped
15:13:25.238: [game-capture: 'Game Capture'] attempting to hook process: javaw.exe
15:13:25.261: [game-capture: 'Game Capture'] memory capture successful
Sapiens
Forum Moderator
Get both monitors connected to the 1060.
glyffe
Can't, it doesn't have multiple Ports
