Question / Help Frame Drops And Connecting Problems Please Help
Only_Mac
I'v been trying to stream for the past 4 days i ended the stream one day and tried to start it the next day i didn't work i called my internet provider to see if it was on there end but it was not please help me someone
14:33:29: Open Broadcaster Software v0.657b - 32bit (´・ω・`)
14:33:29: -------------------------------
14:33:29: CPU Name: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
14:33:29: CPU Speed: 4000MHz
14:33:29: Physical Memory: 4095MB Total, 4095MB Free
14:33:29: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
14:33:29: monitor 1: pos={0, 0}, size={1920, 1080}
14:33:29: monitor 2: pos={-1920, 0}, size={1920, 1080}
14:33:29: Windows Version: 10.0 Build 10240 (revision 16384)
14:33:29: Aero is Enabled
14:33:29: OBS Modules:
14:33:29: Base Address Module
14:33:29: 01160000 OBS.exe
14:33:29: 66230000 OBSApi.dll
14:33:29: 66900000 CLRHostPlugin.dll
14:33:29: 65420000 DShowPlugin.dll
14:33:29: 653F0000 GraphicsCapture.dll
14:33:29: 653C0000 NoiseGate.dll
14:33:29: 653A0000 PSVPlugin.dll
14:33:29: 65370000 scenesw.dll
14:33:29: ------------------------------------------
14:33:29: Adapter 1
14:33:29: Video Adapter: NVIDIA GeForce GTX 970
14:33:29: Video Adapter Dedicated Video Memory: 3221225472
14:33:29: Video Adapter Shared System Memory: 1073676288
14:33:29: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
14:33:29: Video Adapter Output 2: pos={-1920, 0}, size={1920, 1080}, attached=true
14:33:29: =====Stream Start: 2016-01-07, 14:33:29===============================================
14:33:29: Multithreaded optimizations: On
14:33:29: Base resolution: 1920x1080
14:33:29: Output resolution: 1536x864
14:33:29: Loading up D3D10 on NVIDIA GeForce GTX 970 (Adapter 1)...
14:33:29: Audio Format: 48000 Hz
14:33:29: Audio Channels: 2 Ch
14:33:29: Playback device {0.0.0.00000000}.{b4d22045-7887-4dc1-8203-7af516550884}
14:33:29: Using desktop audio input: Speakers (Realtek High Definition Audio)
14:33:29: Global Audio time adjust: 0
14:33:29: Using auxilary audio input: Microphone (Blue Snowball)
14:33:29: Mic time offset: 0
14:33:29: Audio Encoding: AAC
14:33:29: bitrate: 128
14:33:29: Using graphics capture
14:33:29: Trying to hook process: H1Z1.exe
Warning -- GraphicsCaptureSource::AttemptCapture: Failed to inject library, error code = 5
14:33:29: Scene buffering time set to 700
14:33:29: Video Encoding: x264
14:33:29: fps: 30
14:33:29: width: 1536, height: 864
14:33:29: preset: veryfast
14:33:29: profile: main
14:33:29: keyint: 60
14:33:29: CBR: yes
14:33:29: CFR: yes
14:33:29: max bitrate: 2000
14:33:29: buffer size: 2000
14:33:31: Using RTMP service: Twitch
14:33:31: Server selection: rtmp://live-ord.twitch.tv/app
14:33:31: Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
14:33:31: Completed handshake with rtmp://live-ord.twitch.tv/app in 148 ms.
14:33:32: SO_SNDBUF was at 65536
14:33:37: RTMPPublisher::SocketLoop: Stalled for 1682 ms to write 272019 bytes (buffer: 0 / 272384), unstable connection?
14:33:43: RTMPPublisher::SocketLoop: Stalled for 1746 ms to write 271974 bytes (buffer: 0 / 272384), unstable connection?
14:33:46: Total frames encoded: 472, total frames duplicated: 7 (1.48%)
14:33:46: Total frames rendered: 495, number of late frames: 2 (0.40%) (it's okay for some frames to be late)
14:33:46:
14:33:46: Profiler time results:
14:33:46:
14:33:46: ==============================================================
14:33:46: video thread frame - [100%] [avg time: 1.211 ms] [children: 14.5%] [unaccounted: 85.5%]
14:33:46: | scene->Preprocess - [0.165%] [avg time: 0.002 ms]
14:33:46: | GPU download and conversion - [14.3%] [avg time: 0.173 ms] [children: 12.6%] [unaccounted: 1.73%]
14:33:46: | | flush - [11.6%] [avg time: 0.141 ms]
14:33:46: | | CopyResource - [0.578%] [avg time: 0.007 ms]
14:33:46: | | conversion to 4:2:0 - [0.33%] [avg time: 0.004 ms]
14:33:46: Convert444Threads - [100%] [avg time: 0.814 ms] [children: 98.8%] [unaccounted: 1.23%]
14:33:46: | Convert444toNV12 - [98.8%] [avg time: 0.804 ms]
14:33:46: encoder thread frame - [100%] [avg time: 1.928 ms] [children: 3.63%] [unaccounted: 96.4%]
14:33:46: | sending stuff out - [3.63%] [avg time: 0.07 ms]
14:33:46:
14:33:46:
14:33:46: Profiler CPU results:
14:33:46:
14:33:46: video thread frame - [cpu time: avg 0.284 ms, total 140.625 ms] [avg calls per frame: 1]
14:33:46: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
14:33:46: | GPU download and conversion - [cpu time: avg 0.126 ms, total 62.5 ms] [avg calls per frame: 1]
14:33:46: | | flush - [cpu time: avg 0.063 ms, total 31.25 ms] [avg calls per frame: 1]
14:33:46: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
14:33:46: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
14:33:46: Convert444Threads - [cpu time: avg 0.779 ms, total 734.375 ms] [avg calls per frame: 2]
14:33:46: | Convert444toNV12 - [cpu time: avg 0.779 ms, total 734.375 ms] [avg calls per frame: 2]
14:33:46: encoder thread frame - [cpu time: avg 1.886 ms, total 890.625 ms] [avg calls per frame: 1]
14:33:46: | sending stuff out - [cpu time: avg 0.066 ms, total 31.25 ms] [avg calls per frame: 1]
