BlueJayNinja
20:53:51.544: CPU Name: 11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz
20:53:51.544: CPU Speed: 2419MHz
20:53:51.544: Physical Cores: 4, Logical Cores: 8
20:53:51.544: Physical Memory: 7971MB Total, 3011MB Free
20:53:51.544: Windows Version: 10.0 Build 22000 (release: 2009; revision: 613; 64-bit)
20:53:51.544: Running as administrator: false
20:53:51.544: Aero is Enabled (Aero is always on for windows 8 and above)
20:53:51.544: Windows 10 Gaming Features:
20:53:51.544: Game DVR: On
20:53:51.544: Game Mode: Off
20:53:51.545: Sec. Software Status:
20:53:51.546: Microsoft Defender Antivirus: enabled (AV)
20:53:51.546: Microsoft Firewall: enabled (FW)
20:53:51.546: Current Date/Time: 2022-04-21, 20:53:51
20:53:51.546: Browser Hardware Acceleration: true
20:53:51.546: Hide OBS windows from screen capture: false
20:53:51.546: Qt Version: 5.15.2 (runtime), 5.15.2 (compiled)
20:53:51.546: Portable mode: false
20:53:52.007: OBS 27.2.4 (64-bit, windows)
20:53:52.007: ---------------------------------
20:53:52.026: ---------------------------------
20:53:52.026: audio settings reset:
20:53:52.026: samples per sec: 48000
20:53:52.026: speakers: 2
20:53:52.038: ---------------------------------
20:53:52.038: Initializing D3D11...
20:53:52.038: Available Video Adapters:
20:53:52.040: Adapter 0: Intel(R) Iris(R) Xe Graphics
20:53:52.040: Dedicated VRAM: 134217728
20:53:52.040: Shared VRAM: 4179259392
20:53:52.040: PCI ID: 8086:9a49
20:53:52.040: Driver Version: 27.20.100.8439
20:53:52.040: output 0:
20:53:52.040: name=
20:53:52.040: pos={0, 0}
20:53:52.040: size={1920, 1080}
20:53:52.040: attached=true
20:53:52.040: refresh=60
20:53:52.040: space=RGB_FULL_G22_NONE_P709
20:53:52.040: sdr_white_nits=80
20:53:52.040: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
20:53:52.042: Loading up D3D11 on adapter Intel(R) Iris(R) Xe Graphics (0)
20:53:52.153: D3D11 loaded successfully, feature level used: b000
20:53:52.153: DXGI increase maximum frame latency success
20:53:52.513: ---------------------------------
20:53:52.513: video settings reset:
20:53:52.513: base resolution: 1919x1011
20:53:52.513: output resolution: 1916x1010
20:53:52.513: downscale filter: Bicubic
20:53:52.513: fps: 60/1
20:53:52.513: format: NV12
20:53:52.513: YUV mode: 709/Partial
20:53:52.513: NV12 texture support enabled
20:53:52.515: Audio monitoring device:
20:53:52.515: name: Default
20:53:52.515: id: default
20:53:52.515: ---------------------------------
20:53:52.534: No AJA devices found, skipping loading AJA UI plugin
20:53:52.534: Failed to initialize module 'aja-output-ui.dll'
20:53:52.550: No AJA devices found, skipping loading AJA plugin
20:53:52.550: Failed to initialize module 'aja.dll'
20:53:52.573: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
20:53:52.586: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
20:53:52.598: Failed to load 'en-US' text for module: 'decklink-captions.dll'
20:53:52.613: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
20:53:52.690: [AMF] Unable to load 'amfrt64.dll', error code 126.
20:53:52.691: [AMF] AMF Test failed due to one or more errors.
20:53:52.691: Failed to initialize module 'enc-amf.dll'
20:53:52.782: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
20:53:52.810: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
20:53:52.846: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
20:53:52.880: [obs-browser]: Version 2.17.13
20:53:52.880: [obs-browser]: CEF Version 95.0.0-MediaHandler.2467+g8092a57+chromium-95.0.4638.69
20:53:52.937: [noise suppress]: NVIDIA RTX denoiser disabled, redistributable not found
20:53:53.082: [vlc-video]: Couldn't find VLC installation, VLC video source disabled
20:53:53.243: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
20:53:53.244: No blackmagic support
20:53:53.291: ---------------------------------
20:53:53.291: Loaded Modules:
20:53:53.292: win-wasapi.dll
20:53:53.292: win-mf.dll
20:53:53.292: win-dshow.dll
20:53:53.292: win-decklink.dll
20:53:53.292: win-capture.dll
20:53:53.292: vlc-video.dll
20:53:53.292: text-freetype2.dll
20:53:53.292: rtmp-services.dll
20:53:53.292: obs-x264.dll
20:53:53.292: obs-vst.dll
20:53:53.292: obs-transitions.dll
20:53:53.292: obs-text.dll
20:53:53.292: obs-qsv11.dll
20:53:53.292: obs-outputs.dll
20:53:53.292: obs-filters.dll
20:53:53.292: obs-ffmpeg.dll
20:53:53.292: obs-browser.dll
20:53:53.292: image-source.dll
20:53:53.292: frontend-tools.dll
20:53:53.292: decklink-ouput-ui.dll
20:53:53.292: decklink-captions.dll
20:53:53.292: coreaudio-encoder.dll
20:53:53.292: ---------------------------------
20:53:53.292: ==== Startup complete ===============================================
20:53:53.401: All scene data cleared
20:53:53.401: ------------------------------------------------
20:53:53.413: [win-wasapi: 'Desktop Audio'] update settings:
20:53:53.413: device id: {0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}
20:53:53.413: use device timing: 1
20:53:53.415: [WASAPISource::TryInitialize]:[{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}] Failed to enumerate device: 80070490
20:53:53.415: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:53:53.416: [Loaded global audio device]: 'Desktop Audio'
20:53:53.416: - filter: 'Ducking' (compressor_filter)
20:53:53.416: [win-wasapi: 'Mic/Aux'] update settings:
20:53:53.416: device id: {0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}
20:53:53.416: use device timing: 0
20:53:53.417: [WASAPISource::TryInitialize]:[{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}] Failed to enumerate device: 80070490
20:53:53.417: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:53:53.417: [noise suppress: 'Noise Suppression'] NVAFX redist is not installed.
20:53:53.417: [Loaded global audio device]: 'Mic/Aux'
20:53:53.417: - filter: 'Noise Suppression' (noise_suppress_filter_v2)
20:53:53.417: - filter: 'Gain' (gain_filter)
20:53:53.417: - filter: 'Noise Gate' (noise_gate_filter)
20:53:53.574: [duplicator-monitor-capture: 'Display Capture'] update settings:
20:53:53.574: display: 1 (1920x1080)
20:53:53.574: cursor: true
20:53:53.574: method: DXGI
20:53:53.574: [window-capture: 'Window Capture'] update settings:
20:53:53.574: executable: Discord.exe
20:53:53.574: method selected: Automatic
20:53:53.574: method chosen: WGC
20:53:53.574:
20:53:53.574: [duplicator-monitor-capture: 'Display Capture 2'] update settings:
20:53:53.575: [window-capture: 'Window Capture 2'] update settings:
20:53:53.575: executable: chrome.exe
20:53:53.575: method selected: Automatic
20:53:53.575: method chosen: WGC
20:53:53.575:
20:53:53.576: Switched to scene 'passion project slideshow'
20:53:53.576: ------------------------------------------------
20:53:53.576: Loaded scenes:
20:53:53.576: - scene 'passion project slideshow':
20:53:53.576: - source: 'Display Capture' (monitor_capture)
20:53:53.576: - source: 'Game Capture' (game_capture)
20:53:53.576: - source: 'Window Capture' (window_capture)
20:53:53.576: - scene 'korean school':
20:53:53.576: - source: 'Display Capture 2' (monitor_capture)
20:53:53.576: - source: 'Image' (image_source)
20:53:53.576: - source: 'Video Capture Device' (dshow_input)
20:53:53.576: - scene 'koreanschool rec':
20:53:53.576: - scene 'forfun':
20:53:53.576: - source: 'Window Capture 2' (window_capture)
20:53:53.745: ---------------------------------
20:53:53.745: [DShow Device: 'Video Capture Device'] settings updated:
20:53:53.745: video device: HD User Facing
20:53:53.745: video path: \\?\usb#vid_04f2&pid_b72b&mi_00#6&29091d58&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
20:53:53.745: resolution: 1280x720
20:53:53.745: flip: 0
20:53:53.745: fps: 30.00 (interval: 333333)
20:53:53.745: format: MJPEG
20:53:53.745: buffering: disabled
20:53:56.416: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:53:56.418: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:53:59.416: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:53:59.418: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:02.417: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:02.418: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:05.417: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:05.418: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:08.426: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:08.426: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:11.432: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:11.432: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:14.438: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:14.438: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:17.442: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:17.442: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:20.446: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start20:54:20.446: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:23.451: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start20:54:23.451: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:26.463: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start20:54:26.463: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:29.472: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:29.472: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:32.482: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start20:54:32.482: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:35.489: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start20:54:35.489: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:38.494: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:54:38.494: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:54:41.504: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:55:08.785: Last log entry repeated for 19 more lines
20:55:08.785: User switched to scene 'forfun'
20:55:09.617: User switched to scene 'korean school'
20:55:11.169: User switched to scene 'passion project slideshow'
20:55:11.606: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:55:11.606: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:55:14.481: User switched to scene 'forfun'
20:55:14.607: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start20:55:14.607: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:55:17.607: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:55:17.607: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:55:20.608: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start20:55:20.608: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:55:23.608: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start20:55:23.608: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:55:26.608: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:55:26.608: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:55:29.608: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:55:29.609: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:55:32.609: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:55:32.609: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:55:35.609: WASAPI: Device '{0.0.0.00000000}.{88068be5-6aa8-4968-b221-f71ece369b20}' failed to start
20:55:35.609: WASAPI: Device '{0.0.1.00000000}.{06ccf919-ad8f-436e-b8af-849ec40014a0}' failed to start
20:53:52.040: name=
20:53:53.574:
20:53:53.575:
