Apparently my computer isn't bad but i'm streaming minecraft with like 14 fps???
17:58:05.439: CPU Name: AMD FX(tm)-4300 Quad-Core Processor
17:58:05.440: CPU Speed: 3800MHz
17:58:05.440: Physical Cores: 2, Logical Cores: 4
17:58:05.440: Physical Memory: 8191MB Total, 2659MB Free (NOTE: 32bit programs cannot use more than 3gb)
17:58:05.440: Windows Version: 6.1 Build 7601 (revision: 24000; 64-bit)
17:58:05.440: Running as administrator: false
17:58:05.440: Aero is Disabled
17:58:05.470: Portable mode: false
17:58:05.552: OBS 21.0.1 (windows)
17:58:05.552: ---------------------------------
17:58:05.572: ---------------------------------
17:58:05.572: audio settings reset:
17:58:05.572: samples per sec: 44100
17:58:05.572: speakers: 2
17:58:05.589: ---------------------------------
17:58:05.589: Initializing D3D11...
17:58:05.589: Available Video Adapters:
17:58:05.601: Adapter 1: AMD Radeon HD 5450
17:58:05.601: Dedicated VRAM: 1059917824
17:58:05.601: Shared VRAM: 3234983936
17:58:05.601: output 1: pos={0, 0}, size={1600, 900}, attached=true
17:58:05.601: output 2: pos={1600, 0}, size={1440, 900}, attached=true
17:58:05.880: Loading up D3D11 on adapter AMD Radeon HD 5450 (0)
17:58:05.887: D3D11 loaded successfully, feature level used: 45056
17:58:07.781: ---------------------------------
17:58:07.781: video settings reset:
17:58:07.781: base resolution: 1600x900
17:58:07.781: output resolution: 1280x720
17:58:07.781: downscale filter: Lanczos
17:58:07.781: fps: 30/1
17:58:07.781: format: NV12
17:58:07.782: Audio monitoring device:
17:58:07.782: name: Default
17:58:07.782: id: default
17:58:07.796: ---------------------------------
17:58:07.843: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/chrome_elf.dll' not found, loading of module failed
17:58:08.290: [CoreAudio encoder]: Adding CoreAudio AAC encoder
17:58:08.738: [AMF] <obs_module_load> AMF not supported (no AMD graphics)
17:58:08.738: Failed to initialize module 'enc-amf.dll'
17:58:09.132: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libcef.dll' not found, loading of module failed
17:58:09.148: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libEGL.dll' not found, loading of module failed
17:58:09.175: Required module function 'obs_module_load' in module '../../obs-plugins/32bit/libGLESv2.dll' not found, loading of module failed
17:58:09.189: Failed to load 'en-US' text for module: 'obs-browser.dll'
17:58:09.189: [browser_source: 'Version: 1.29.0']
17:58:09.664: LoadLibrary failed for 'nvEncodeAPI.dll': The specified module could not be found.
17:58:09.664: (126)
17:58:12.836: Couldn't find VLC installation, VLC video source disabled
17:58:13.179: No blackmagic support
17:58:13.588: [Media Foundation encoder]: plugin is disabled for performance reasons on Windows versions prior to 8
17:58:13.753: ---------------------------------
17:58:13.753: Loaded Modules:
17:58:13.753: win-wasapi.dll
17:58:13.753: win-mf.dll
17:58:13.753: win-dshow.dll
17:58:13.753: win-decklink.dll
17:58:13.753: win-capture.dll
17:58:13.754: vlc-video.dll
17:58:13.754: text-freetype2.dll
17:58:13.754: rtmp-services.dll
17:58:13.754: obs-x264.dll
17:58:13.754: obs-vst.dll
17:58:13.754: obs-transitions.dll
17:58:13.754: obs-text.dll
17:58:13.754: obs-qsv11.dll
17:58:13.754: obs-outputs.dll
17:58:13.754: obs-filters.dll
17:58:13.754: obs-ffmpeg.dll
17:58:13.754: obs-browser.dll
17:58:13.754: image-source.dll
17:58:13.754: frontend-tools.dll
17:58:13.754: enc-amf.dll
17:58:13.754: coreaudio-encoder.dll
17:58:13.754: ---------------------------------
17:58:13.759: ==== Startup complete ===============================================
17:58:14.217: All scene data cleared
17:58:14.217: ------------------------------------------------
17:58:14.431: WASAPI: Device 'Speakers (2- High Definition Audio Device)' initialized
17:58:14.515: WASAPI: Device 'Microphone (Webcam C260)' initialized
17:58:14.516: [window-capture: 'Window Capture'] update settings:
17:58:14.516: executable: RobloxPlayerBeta.exe
17:58:14.586: adding 139 milliseconds of audio buffering, total audio buffering is now 139 milliseconds
17:58:16.409: Switched to scene 'Scene'
17:58:16.437: ------------------------------------------------
17:58:16.438: Loaded scenes:
17:58:16.438: - scene 'Scene':
17:58:16.438: - source: 'Window Capture' (window_capture)
17:58:16.438: - source: 'Display Capture' (monitor_capture)
17:58:16.438: - source: 'Display Capture 2' (monitor_capture)
17:58:16.438: - source: 'BrowserSource' (browser_source)
17:58:16.438: ------------------------------------------------
17:58:26.916: [window-capture: 'Window Capture'] update settings:
17:58:26.916: executable: Discord.exe
17:58:29.349: [window-capture: 'Window Capture'] update settings:
17:58:29.349: executable: chrome.exe
17:59:03.429: ---------------------------------
17:59:03.429: [x264 encoder: 'streaming_h264'] preset: veryfast
17:59:03.434: [x264 encoder: 'streaming_h264'] settings:
17:59:03.434: rate_control: CBR
17:59:03.434: bitrate: 3500
17:59:03.434: buffer size: 3500
17:59:03.434: crf: 0
17:59:03.434: fps_num: 30
17:59:03.434: fps_den: 1
17:59:03.434: width: 1280
17:59:03.434: height: 720
17:59:03.434: keyint: 60
17:59:03.434:
17:59:03.435: [x264 encoder: 'streaming_h264'] custom settings: scenecut=0
17:59:03.464: [CoreAudio AAC: 'Track1']: settings:
17:59:03.464: mode: AAC
17:59:03.464: bitrate: 160
17:59:03.464: sample rate: 44100
17:59:03.464: cbr: on
17:59:03.464: output buffer: 1536
17:59:03.468: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live.twitch.tv/app...
17:59:03.490: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GBE Family Controller (ethernet, 1000 mbps)
17:59:04.116: [rtmp stream: 'adv_stream'] Connection to rtmp://live.twitch.tv/app successful
17:59:04.138: ==== Streaming Start ===============================================
19:27:27.541: adding 23 milliseconds of audio buffering, total audio buffering is now 162 milliseconds
19:28:37.658: [window-capture: 'Window Capture'] update settings:
19:28:37.658: executable: MediBangPaintPro.exe
19:34:11.602: [window-capture: 'Window Capture'] update settings:
19:34:11.602: executable: RobloxPlayerBeta.exe
19:34:24.176: adding 23 milliseconds of audio buffering, total audio buffering is now 185 milliseconds
20:02:11.406: device_texture_create_gdi (D3D11): Failed to create 2D texture (80070057)
20:02:11.409: [dc_capture_init] Failed to create textures
20:02:11.409: [capture_screen] Failed to get texture DC
20:03:02.009: [window-capture: 'Window Capture'] update settings:
20:03:02.009: executable: RobloxPlayerLauncher.exe
20:03:26.166: [window-capture: 'Window Capture'] update settings:
20:03:26.166: executable: RobloxPlayerBeta.exe
20:04:30.382: adding 394 milliseconds of audio buffering, total audio buffering is now 580 milliseconds
20:04:30.536: adding 92 milliseconds of audio buffering, total audio buffering is now 673 milliseconds
20:10:54.473: ==== Shutting down ==================================================
20:10:55.313: Switched to scene '(null)'
20:10:57.216: WASAPI: Device 'Speakers (2- High Definition Audio Device)' Terminated
20:10:57.744: WASAPI: Device 'Microphone (Webcam C260)' Terminated
20:10:57.830: All scene data cleared
20:10:57.830: ------------------------------------------------
20:10:58.049: [rtmp stream: 'adv_stream'] User stopped the stream
20:10:58.050: Output 'adv_stream': stopping
20:10:58.050: Output 'adv_stream': Total frames output: 236806 (237339 attempted)
20:10:58.050: Output 'adv_stream': Total drawn frames: 226246 (237428 attempted)
20:10:58.050: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 11182 (4.7%)
20:10:58.050: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 533 (0.2%)
20:10:58.050: [rtmp stream: 'adv_stream'] Freeing 4 remaining packets
20:10:58.050: Video stopped, number of skipped frames due to encoding lag: 2320/237407 (1.0%)
20:10:59.881: Freeing OBS context data
20:11:03.832: [Scripting] Total detached callbacks: 0
20:11:05.339: == Profiler Results =============================
20:11:05.339: run_program_init: 12457.2 ms
20:11:05.339: ┣OBSApp::AppInit: 269.198 ms
20:11:05.339: ┃ ┗OBSApp::InitLocale: 134.725 ms
20:11:05.339: ┗OBSApp::OBSInit: 12022.5 ms
20:11:05.339: ┣obs_startup: 32.109 ms
20:11:05.339: ┗OBSBasic::OBSInit: 11506.8 ms
20:11:05.339: ┣OBSBasic::InitBasicConfig: 0.921 ms
20:11:05.339: ┣OBSBasic::ResetAudio: 0.471 ms
20:11:05.339: ┣OBSBasic::ResetVideo: 2209.83 ms
20:11:05.339: ┣OBSBasic::InitOBSCallbacks: 0.006 ms
20:11:05.339: ┣OBSBasic::InitHotkeys: 0.066 ms
20:11:05.361: ┣obs_load_all_modules: 5957.39 ms
20:11:05.361: ┃ ┣obs_init_module(coreaudio-encoder.dll): 384.868 ms
20:11:05.361: ┃ ┣obs_init_module(enc-amf.dll): 369.924 ms
20:11:05.361: ┃ ┣obs_init_module(frontend-tools.dll): 17.703 ms
20:11:05.361: ┃ ┣obs_init_module(image-source.dll): 0.006 ms
20:11:05.361: ┃ ┣obs_init_module(obs-browser.dll): 18.93 ms
20:11:05.361: ┃ ┣obs_init_module(obs-ffmpeg.dll): 295.698 ms
20:11:05.361: ┃ ┃ ┗nvenc_check: 295.668 ms
20:11:05.361: ┃ ┣obs_init_module(obs-filters.dll): 0.02 ms
20:11:05.361: ┃ ┣obs_init_module(obs-outputs.dll): 0.016 ms
20:11:05.361: ┃ ┣obs_init_module(obs-qsv11.dll): 1844.19 ms
20:11:05.361: ┃ ┣obs_init_module(obs-text.dll): 0.641 ms
20:11:05.361: ┃ ┣obs_init_module(obs-transitions.dll): 0.009 ms
20:11:05.361: ┃ ┣obs_init_module(obs-vst.dll): 0.004 ms
20:11:05.361: ┃ ┣obs_init_module(obs-x264.dll): 0.004 ms
20:11:05.361: ┃ ┣obs_init_module(rtmp-services.dll): 106.954 ms
20:11:05.361: ┃ ┣obs_init_module(text-freetype2.dll): 0.063 ms
20:11:05.361: ┃ ┣obs_init_module(vlc-video.dll): 0.094 ms
20:11:05.361: ┃ ┣obs_init_module(win-capture.dll): 0.231 ms
20:11:05.362: ┃ ┣obs_init_module(win-decklink.dll): 82.586 ms
20:11:05.362: ┃ ┣obs_init_module(win-dshow.dll): 2.867 ms
20:11:05.362: ┃ ┣obs_init_module(win-mf.dll): 19.7 ms
20:11:05.362: ┃ ┣obs_init_module(win-wasapi.dll): 0.016 ms
20:11:05.362: ┃ ┗reset_win32_symbol_paths: 57.386 ms
20:11:05.362: ┣OBSBasic::ResetOutputs: 228.255 ms
20:11:05.362: ┣OBSBasic::CreateHotkeys: 0.047 ms
20:11:05.362: ┣OBSBasic::InitService: 74.235 ms
20:11:05.362: ┣OBSBasic::InitPrimitives: 7.253 ms
20:11:05.362: ┗OBSBasic::Load: 2426.97 ms
20:11:05.362: obs_hotkey_thread(25 ms): min=0.003 ms, median=0.006 ms, max=728.953 ms, 99th percentile=27.738 ms, 98.7165% below 25 ms
20:11:05.362: audio_thread(Audio): min=0.001 ms, median=1.248 ms, max=1089.32 ms, 99th percentile=14.217 ms
20:11:05.388: ┗receive_audio: min=0.006 ms, median=1.087 ms, max=459.161 ms, 99th percentile=11.44 ms, 1.07213 calls per parent call
20:11:05.388: ┣buffer_audio: min=0.001 ms, median=0.003 ms, max=33.834 ms, 99th percentile=0.008 ms
20:11:05.388: ┗do_encode: min=0.335 ms, median=1.075 ms, max=459.154 ms, 99th percentile=11.348 ms
20:11:05.388: ┗encode(Track1): min=0.326 ms, median=1.038 ms, max=459.133 ms, 99th percentile=11.082 ms
20:11:05.388: obs_graphics_thread(33.3333 ms): min=0.602 ms, median=12.435 ms, max=1791.96 ms, 99th percentile=80.882 ms, 87.2463% below 33.333 ms
20:11:05.389: ┣tick_sources: min=0.001 ms, median=5.748 ms, max=1790.97 ms, 99th percentile=52.569 ms
20:11:05.389: ┣output_frame: min=0.363 ms, median=1.276 ms, max=256.568 ms, 99th percentile=21.188 ms
20:11:05.389: ┃ ┣gs_context(video->graphics): min=0.272 ms, median=0.678 ms, max=256.23 ms, 99th percentile=20.429 ms
20:11:05.389: ┃ ┃ ┣render_video: min=0.031 ms, median=0.109 ms, max=140.271 ms, 99th percentile=4.58 ms
20:11:05.389: ┃ ┃ ┃ ┣render_main_texture: min=0.006 ms, median=0.05 ms, max=33.832 ms, 99th percentile=0.259 ms
20:11:05.389: ┃ ┃ ┃ ┣render_output_texture: min=0.005 ms, median=0.018 ms, max=30.449 ms, 99th percentile=0.103 ms
20:11:05.389: ┃ ┃ ┃ ┣render_convert_texture: min=0.002 ms, median=0.019 ms, max=32.757 ms, 99th percentile=0.103 ms
20:11:05.389: ┃ ┃ ┃ ┗stage_output_texture: min=0.001 ms, median=0.007 ms, max=140.169 ms, 99th percentile=3.818 ms
20:11:05.389: ┃ ┃ ┣download_frame: min=0.001 ms, median=0.011 ms, max=255.981 ms, 99th percentile=14.349 ms
20:11:05.390: ┃ ┃ ┗gs_flush: min=0.08 ms, median=0.36 ms, max=129.409 ms, 99th percentile=11.104 ms
20:11:05.390: ┃ ┗output_video_data: min=0.001 ms, median=0.51 ms, max=64.436 ms, 99th percentile=2.552 ms
20:11:05.390: ┗render_displays: min=0.001 ms, median=0.847 ms, max=316.24 ms, 99th percentile=45.249 ms
20:11:05.390: video_thread(video): min=0.001 ms, median=1.707 ms, max=1943.81 ms, 99th percentile=51.758 ms
20:11:05.390: ┗receive_video: min=1.307 ms, median=1.702 ms, max=1366.68 ms, 99th percentile=51.209 ms, 1.05019 calls per parent call
20:11:05.390: ┗do_encode: min=1.305 ms, median=1.7 ms, max=1366.68 ms, 99th percentile=51.207 ms
20:11:05.391: ┗encode(streaming_h264): min=1.278 ms, median=1.669 ms, max=1366.61 ms, 99th percentile=51.14 ms
20:11:05.391: =================================================
20:11:05.391: == Profiler Time Between Calls ==================
20:11:05.391: obs_hotkey_thread(25 ms): min=24.015 ms, median=25.023 ms, max=754.255 ms, 57.7303% within ±2% of 25 ms (5.69223% lower, 36.5775% higher)
20:11:05.391: obs_graphics_thread(33.3333 ms): min=2.376 ms, median=33.333 ms, max=1791.97 ms, 68.7636% within ±2% of 33.333 ms (14.563% lower, 16.6733% higher)
20:11:08.084: Number of memory leaks: 1
17:58:09.664: (126)
17:59:03.434:
