SethEvandor
Even though my CPU and GPU are not maxed out, I still get FPS drops in-game. I've had the same problem with several versions of OBS, every time an update hasn't changed anything. I've been searching over the last few months but I haven't seen a thread about anyone else having this problem.
I can't get a stable 60 FPS with any modern game with OBS but when I use Fraps I do get 60 stable. I've been using just the file output to test higher quality and it doesn't seem to affect the FPS much. The very frequent drops are terrible but they are very noticeable and I see no reason why they occur. I can actually increase the quality by changing the encoding preset and my cores will not be maxed out at any point but the problem still exists. I also tried the 64bit exe after I noticed it last night, but same thing happens. I also get no frame drops with file outputs when I don't play a game.
Also, I see streams with crystal clear quality but every guide suggests 3000/3000 or 5000/5000 which is awful. What sort of upload does one need for a clear 1080 at 30 and 60 FPS?
Below is my recent log
14:47:30: Settings::Video: Disabling Aero
14:47:34: Open Broadcaster Software v0.554b - 64bit ( ^ω^)
14:47:34: -------------------------------
14:47:34: CPU Name: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
14:47:34: CPU Speed: 3430MHz
14:47:34: Physical Memory: 16346MB Total, 13299MB Free
14:47:34: stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
14:47:34: monitor 1: pos={0, 0}, size={1920, 1080}
14:47:34: Windows Version: 6.1 Build 7601 S
14:47:34: Aero is Disabled
14:47:34: OBS Modules:
14:47:34: Base Address Module
14:47:34: 000000003F120000 OBS.exe
14:47:34: 00000000F3A30000 OBSApi.dll
14:47:34: 00000000FA1D0000 DShowPlugin.dll
14:47:34: 00000000FA290000 GraphicsCapture.dll
14:47:34: 00000000FCB80000 NoiseGate.dll
14:47:34: 00000000FC400000 PSVPlugin.dll
14:47:34: ------------------------------------------
14:47:34: Adapter 1
14:47:34: Video Adapter: NVIDIA GeForce GTX 660 Ti
14:47:34: Video Adapter Dedicated Video Memory: 2091319296
14:47:34: Video Adapter Shared System Memory: 2147807232
14:47:34: =====Stream Start: 2013-09-09, 14:47:34===============================================
14:47:34: Multithreaded optimizations: On
14:47:34: Base resolution: 1920x1080
14:47:34: Output resolution: 1280x720
14:47:34: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
14:47:34: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
14:47:34: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
14:47:34: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DownscaleBilinear1YUV.pShader.blob
14:47:34: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
14:47:34: Using desktop audio input: Speakers (Realtek High Definition Audio)
Warning -- MMDeviceAudioSource::Initialize(1): Could not create IAudioClient = 88890004
14:47:35: ------------------------------------------
14:47:35: Audio Encoding: AAC
14:47:35: bitrate: 192
14:47:35: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
14:47:35: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
14:47:35: Using Monitor Capture
14:47:35: Video Encoding: x264
14:47:35: fps: 30
14:47:35: width: 1280, height: 720
14:47:35: preset: faster
14:47:35: CBR: yes
14:47:35: CFR: yes
14:47:35: max bitrate: 3000
14:47:35: buffer size: 3000
14:47:35: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
14:47:35: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
14:47:58: Total frames rendered: 653, number of late frames: 5 (0.77%) (it's okay for some frames to be late)
14:47:58: Total duplicated frames to ensure constant framerate: 33 (5.05%)
14:47:58:
14:47:58: Profiler results:
14:47:58:
14:47:58: ==============================================================
14:47:58: frame - [100%] [avg time: 7.308 ms (cpu time: avg 4.276 ms, total 2792.42 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0411%]
14:47:58: | frame preprocessing and rendering - [81.3%] [avg time: 5.938 ms (cpu time: avg 2.986 ms, total 1950.02 ms)] [avg calls per frame: 1] [children: 72%] [unaccounted: 9.22%]
14:47:58: | | scene->Preprocess - [72%] [avg time: 5.264 ms (cpu time: avg 2.341 ms, total 1528.81 ms)] [avg calls per frame: 1]
14:47:58: | video encoding and uploading - [18.7%] [avg time: 1.367 ms (cpu time: avg 1.29 ms, total 842.403 ms)] [avg calls per frame: 1] [children: 18.6%] [unaccounted: 0.151%]
14:47:58: | | flush - [1.04%] [avg time: 0.076 ms (cpu time: avg 0.071 ms, total 46.801 ms)] [avg calls per frame: 1]
14:47:58: | | CopyResource - [0.164%] [avg time: 0.012 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:47:58: | | conversion to 4:2:0 - [0.109%] [avg time: 0.008 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:47:58: | | call to encoder - [17.1%] [avg time: 1.249 ms (cpu time: avg 1.218 ms, total 795.602 ms)] [avg calls per frame: 1]
14:47:58: | | sending stuff out - [0.151%] [avg time: 0.011 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
14:47:58: | Convert444Threads - [935%] [avg time: 68.322 ms (cpu time: avg 1.528 ms, total 998.406 ms)] [avg calls per frame: 1]
14:47:58:
14:47:58: =====Stream End: 2013-09-09, 14:47:58=================================================
14:49:46: Settings::Video: Disabling Aero
14:49:48: =====Stream Start: 2013-09-09, 14:49:48===============================================
14:49:48: Multithreaded optimizations: On
14:49:48: Base resolution: 1920x1080
14:49:48: Output resolution: 1920x1080
14:49:48: ------------------------------------------
14:49:48: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
14:49:48: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
14:49:48: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
14:49:48: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
14:49:48: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
14:49:48: Using desktop audio input: Speakers (Realtek High Definition Audio)
14:49:49: ------------------------------------------
14:49:49: Audio Encoding: AAC
14:49:49: bitrate: 192
14:49:49: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
14:49:49: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
14:49:49: Using Monitor Capture
14:49:49: Video Encoding: x264
14:49:49: fps: 30
14:49:49: width: 1920, height: 1080
14:49:49: preset: faster
14:49:49: CBR: yes
14:49:49: CFR: yes
14:49:49: max bitrate: 3000
14:49:49: buffer size: 3000
14:49:49: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
14:49:49: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
14:50:20: Total frames rendered: 925, number of late frames: 1 (0.11%) (it's okay for some frames to be late)
14:50:20: Total duplicated frames to ensure constant framerate: 0 (0.00%)
14:50:20:
14:50:20: Profiler results:
14:50:20:
14:50:20: ==============================================================
14:50:20: frame - [100%] [avg time: 5.6 ms (cpu time: avg 5.278 ms, total 4882.83 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0536%]
14:50:20: | frame preprocessing and rendering - [50.4%] [avg time: 2.825 ms (cpu time: avg 2.799 ms, total 2589.62 ms)] [avg calls per frame: 1] [children: 40.5%] [unaccounted: 9.95%]
14:50:20: | | scene->Preprocess - [40.5%] [avg time: 2.268 ms (cpu time: avg 2.175 ms, total 2012.41 ms)] [avg calls per frame: 1]
14:50:20: | video encoding and uploading - [49.5%] [avg time: 2.772 ms (cpu time: avg 2.479 ms, total 2293.22 ms)] [avg calls per frame: 1] [children: 49.3%] [unaccounted: 0.25%]
14:50:20: | | flush - [1.38%] [avg time: 0.077 ms (cpu time: avg 0.033 ms, total 31.201 ms)] [avg calls per frame: 1]
14:50:20: | | CopyResource - [0.232%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:50:20: | | conversion to 4:2:0 - [0.232%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:50:20: | | call to encoder - [47.2%] [avg time: 2.643 ms (cpu time: avg 2.428 ms, total 2246.42 ms)] [avg calls per frame: 0]
14:50:20: | | sending stuff out - [0.214%] [avg time: 0.012 ms (cpu time: avg 0.016 ms, total 15.6 ms)] [avg calls per frame: 0]
14:50:20: | Convert444Threads - [1.17e+003%] [avg time: 65.432 ms (cpu time: avg 3.136 ms, total 2901.62 ms)] [avg calls per frame: 1]
14:50:20:
14:50:20: =====Stream End: 2013-09-09, 14:50:20=================================================
14:51:32: Settings::Video: Disabling Aero
14:51:33: =====Stream Start: 2013-09-09, 14:51:33===============================================
14:51:33: Multithreaded optimizations: On
14:51:33: Base resolution: 1920x1080
14:51:33: Output resolution: 1920x1080
14:51:33: ------------------------------------------
14:51:33: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
14:51:33: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
14:51:33: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
14:51:33: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
14:51:33: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
14:51:33: Using desktop audio input: Speakers (Realtek High Definition Audio)
14:51:34: ------------------------------------------
14:51:34: Audio Encoding: AAC
14:51:34: bitrate: 192
14:51:34: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
14:51:34: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
14:51:34: Using Monitor Capture
14:51:34: Video Encoding: x264
14:51:34: fps: 30
14:51:34: width: 1920, height: 1080
14:51:34: preset: faster
14:51:34: CBR: yes
14:51:34: CFR: yes
14:51:34: max bitrate: 3000
14:51:34: buffer size: 3000
14:51:34: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
14:51:34: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
14:51:54: Total frames rendered: 576, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
14:51:54: Total duplicated frames to ensure constant framerate: 0 (0.00%)
14:51:54:
14:51:54: Profiler results:
14:51:54:
14:51:54: ==============================================================
14:51:54: frame - [100%] [avg time: 5.753 ms (cpu time: avg 5.47 ms, total 3151.22 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0869%]
14:51:54: | frame preprocessing and rendering - [53.7%] [avg time: 3.092 ms (cpu time: avg 2.897 ms, total 1669.21 ms)] [avg calls per frame: 1] [children: 44.4%] [unaccounted: 9.37%]
14:51:54: | | scene->Preprocess - [44.4%] [avg time: 2.553 ms (cpu time: avg 2.437 ms, total 1404.01 ms)] [avg calls per frame: 1]
14:51:54: | video encoding and uploading - [46.2%] [avg time: 2.656 ms (cpu time: avg 2.572 ms, total 1482.01 ms)] [avg calls per frame: 1] [children: 46%] [unaccounted: 0.209%]
14:51:54: | | flush - [1.48%] [avg time: 0.085 ms (cpu time: avg 0.027 ms, total 15.6 ms)] [avg calls per frame: 1]
14:51:54: | | CopyResource - [0.209%] [avg time: 0.012 ms (cpu time: avg 0.027 ms, total 15.6 ms)] [avg calls per frame: 0]
14:51:54: | | conversion to 4:2:0 - [0.661%] [avg time: 0.038 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:51:54: | | call to encoder - [43.4%] [avg time: 2.495 ms (cpu time: avg 2.437 ms, total 1404.01 ms)] [avg calls per frame: 0]
14:51:54: | | sending stuff out - [0.243%] [avg time: 0.014 ms (cpu time: avg 0.054 ms, total 31.2 ms)] [avg calls per frame: 0]
14:51:54: | Convert444Threads - [1.12e+003%] [avg time: 64.686 ms (cpu time: avg 3.06 ms, total 1762.81 ms)] [avg calls per frame: 1]
14:51:54:
14:51:54: =====Stream End: 2013-09-09, 14:51:54=================================================
14:54:18: =====Stream Start: 2013-09-09, 14:54:18===============================================
14:54:18: Multithreaded optimizations: On
14:54:18: Base resolution: 1920x1080
14:54:18: Output resolution: 1920x1080
14:54:18: ------------------------------------------
14:54:18: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
14:54:18: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
14:54:18: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
14:54:18: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
14:54:18: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
14:54:18: Using desktop audio input: Speakers (Realtek High Definition Audio)
14:54:19: ------------------------------------------
14:54:19: Audio Encoding: AAC
14:54:19: bitrate: 192
14:54:19: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
14:54:19: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
14:54:19: Using Monitor Capture
14:54:19: Video Encoding: x264
14:54:19: fps: 30
14:54:19: width: 1920, height: 1080
14:54:19: preset: faster
14:54:19: CBR: yes
14:54:19: CFR: yes
14:54:19: max bitrate: 4000
14:54:19: buffer size: 4000
14:54:19: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
14:54:19: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
14:54:38: Total frames rendered: 556, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
14:54:38: Total duplicated frames to ensure constant framerate: 0 (0.00%)
14:54:38:
14:54:38: Profiler results:
14:54:38:
14:54:38: ==============================================================
14:54:38: frame - [100%] [avg time: 5.816 ms (cpu time: avg 5.078 ms, total 2823.62 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0516%]
14:54:38: | frame preprocessing and rendering - [58.3%] [avg time: 3.392 ms (cpu time: avg 2.805 ms, total 1560.01 ms)] [avg calls per frame: 1] [children: 47.7%] [unaccounted: 10.6%]
14:54:38: | | scene->Preprocess - [47.7%] [avg time: 2.773 ms (cpu time: avg 2.216 ms, total 1232.41 ms)] [avg calls per frame: 1]
14:54:38: | video encoding and uploading - [41.6%] [avg time: 2.421 ms (cpu time: avg 2.272 ms, total 1263.61 ms)] [avg calls per frame: 1] [children: 41.4%] [unaccounted: 0.189%]
14:54:38: | | flush - [1.27%] [avg time: 0.074 ms (cpu time: avg 0.028 ms, total 15.6 ms)] [avg calls per frame: 1]
14:54:38: | | CopyResource - [0.224%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:54:38: | | conversion to 4:2:0 - [0.241%] [avg time: 0.014 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:54:38: | | call to encoder - [39.5%] [avg time: 2.296 ms (cpu time: avg 2.216 ms, total 1232.41 ms)] [avg calls per frame: 0]
14:54:38: | | sending stuff out - [0.224%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:54:38: | Convert444Threads - [1.11e+003%] [avg time: 64.603 ms (cpu time: avg 2.693 ms, total 1497.61 ms)] [avg calls per frame: 1]
14:54:38:
14:54:38: =====Stream End: 2013-09-09, 14:54:38=================================================
14:59:17: =====Stream Start: 2013-09-09, 14:59:17===============================================
14:59:17: Multithreaded optimizations: On
14:59:17: Base resolution: 1920x1080
14:59:17: Output resolution: 1920x1080
14:59:17: ------------------------------------------
14:59:17: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
14:59:17: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
14:59:17: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
14:59:17: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
14:59:17: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
14:59:17: Using desktop audio input: Speakers (Realtek High Definition Audio)
14:59:17: Audio Encoding: AAC
14:59:17: bitrate: 192
14:59:17: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
14:59:17: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
14:59:17: Using Monitor Capture
14:59:17: Video Encoding: x264
14:59:17: fps: 30
14:59:17: width: 1920, height: 1080
14:59:17: preset: medium
14:59:17: CBR: yes
14:59:17: CFR: yes
14:59:17: max bitrate: 4000
14:59:17: buffer size: 4000
14:59:17: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
14:59:17: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
14:59:43: Total frames rendered: 753, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
14:59:43: Total duplicated frames to ensure constant framerate: 0 (0.00%)
14:59:43:
14:59:43: Profiler results:
14:59:43:
14:59:43: ==============================================================
14:59:43: frame - [100%] [avg time: 5.52 ms (cpu time: avg 5.179 ms, total 3900.03 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0725%]
14:59:43: | frame preprocessing and rendering - [56.7%] [avg time: 3.131 ms (cpu time: avg 2.9 ms, total 2184.01 ms)] [avg calls per frame: 1] [children: 46.6%] [unaccounted: 10.1%]
14:59:43: | | scene->Preprocess - [46.6%] [avg time: 2.572 ms (cpu time: avg 2.423 ms, total 1825.21 ms)] [avg calls per frame: 1]
14:59:43: | video encoding and uploading - [43.2%] [avg time: 2.385 ms (cpu time: avg 2.278 ms, total 1716.01 ms)] [avg calls per frame: 1] [children: 43%] [unaccounted: 0.199%]
14:59:43: | | flush - [1.36%] [avg time: 0.075 ms (cpu time: avg 0.041 ms, total 31.2 ms)] [avg calls per frame: 1]
14:59:43: | | CopyResource - [0.217%] [avg time: 0.012 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:59:43: | | conversion to 4:2:0 - [0.707%] [avg time: 0.039 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:59:43: | | call to encoder - [40.5%] [avg time: 2.236 ms (cpu time: avg 2.237 ms, total 1684.81 ms)] [avg calls per frame: 0]
14:59:43: | | sending stuff out - [0.217%] [avg time: 0.012 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
14:59:43: | Convert444Threads - [1.18e+003%] [avg time: 65.15 ms (cpu time: avg 2.796 ms, total 2106.01 ms)] [avg calls per frame: 1]
14:59:43:
14:59:43: =====Stream End: 2013-09-09, 14:59:43=================================================
15:01:19: Settings::Video: Disabling Aero
15:01:20: =====Stream Start: 2013-09-09, 15:01:20===============================================
15:01:20: Multithreaded optimizations: On
15:01:20: Base resolution: 1920x1080
15:01:20: Output resolution: 1920x1080
15:01:20: ------------------------------------------
15:01:20: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:01:20: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
15:01:20: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
15:01:20: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
15:01:20: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
15:01:20: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:01:21: ------------------------------------------
15:01:21: Audio Encoding: AAC
15:01:21: bitrate: 192
15:01:21: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
15:01:21: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
15:01:21: Using Monitor Capture
15:01:21: Video Encoding: x264
15:01:21: fps: 60
15:01:21: width: 1920, height: 1080
15:01:21: preset: medium
15:01:21: CBR: yes
15:01:21: CFR: yes
15:01:21: max bitrate: 4000
15:01:21: buffer size: 4000
15:01:21: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:01:21: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
15:01:42: Total frames rendered: 1242, number of late frames: 5 (0.40%) (it's okay for some frames to be late)
15:01:42: Total duplicated frames to ensure constant framerate: 97 (7.81%)
15:01:43:
15:01:43: Profiler results:
15:01:43:
15:01:43: ==============================================================
15:01:43: frame - [100%] [avg time: 5.839 ms (cpu time: avg 5.426 ms, total 6739.24 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0685%]
15:01:43: | frame preprocessing and rendering - [49.1%] [avg time: 2.867 ms (cpu time: avg 2.675 ms, total 3322.82 ms)] [avg calls per frame: 1] [children: 42.3%] [unaccounted: 6.83%]
15:01:43: | | scene->Preprocess - [42.3%] [avg time: 2.468 ms (cpu time: avg 2.286 ms, total 2839.22 ms)] [avg calls per frame: 1]
15:01:43: | video encoding and uploading - [50.8%] [avg time: 2.968 ms (cpu time: avg 2.75 ms, total 3416.42 ms)] [avg calls per frame: 1] [children: 50.6%] [unaccounted: 0.24%]
15:01:43: | | flush - [1.35%] [avg time: 0.079 ms (cpu time: avg 0.037 ms, total 46.801 ms)] [avg calls per frame: 1]
15:01:43: | | CopyResource - [0.206%] [avg time: 0.012 ms (cpu time: avg 0.012 ms, total 15.6 ms)] [avg calls per frame: 0]
15:01:43: | | conversion to 4:2:0 - [0.736%] [avg time: 0.043 ms (cpu time: avg 0.012 ms, total 15.6 ms)] [avg calls per frame: 0]
15:01:43: | | call to encoder - [48.1%] [avg time: 2.811 ms (cpu time: avg 2.687 ms, total 3338.42 ms)] [avg calls per frame: 0]
15:01:43: | | sending stuff out - [0.154%] [avg time: 0.009 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
15:01:43: | Convert444Threads - [558%] [avg time: 32.564 ms (cpu time: avg 3.328 ms, total 4134.03 ms)] [avg calls per frame: 1]
15:01:43:
15:01:43: =====Stream End: 2013-09-09, 15:01:43=================================================
15:05:17: =====Stream Start: 2013-09-09, 15:05:17===============================================
15:05:17: Multithreaded optimizations: On
15:05:17: Base resolution: 1920x1080
15:05:17: Output resolution: 1920x1080
15:05:17: ------------------------------------------
15:05:17: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:05:17: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
15:05:17: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
15:05:17: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
15:05:17: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
15:05:17: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:05:18: ------------------------------------------
15:05:18: Audio Encoding: AAC
15:05:18: bitrate: 160
15:05:18: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
15:05:18: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
15:05:18: Using Monitor Capture
15:05:18: Video Encoding: x264
15:05:18: fps: 60
15:05:18: width: 1920, height: 1080
15:05:18: preset: medium
15:05:18: CBR: yes
15:05:18: CFR: yes
15:05:18: max bitrate: 4000
15:05:18: buffer size: 4000
15:05:18: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:05:18: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
15:05:47: Total frames rendered: 1467, number of late frames: 159 (10.84%) (it's okay for some frames to be late)
15:05:47: Total duplicated frames to ensure constant framerate: 285 (19.43%)
15:05:47:
15:05:47: Profiler results:
15:05:47:
15:05:47: ==============================================================
15:05:47: frame - [100%] [avg time: 11.08 ms (cpu time: avg 6.284 ms, total 9219.66 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0361%]
15:05:47: | frame preprocessing and rendering - [39.9%] [avg time: 4.418 ms (cpu time: avg 3.062 ms, total 4492.83 ms)] [avg calls per frame: 1] [children: 35.4%] [unaccounted: 4.49%]
15:05:47: | | scene->Preprocess - [35.4%] [avg time: 3.921 ms (cpu time: avg 2.605 ms, total 3822.03 ms)] [avg calls per frame: 1]
15:05:47: | video encoding and uploading - [60.1%] [avg time: 6.658 ms (cpu time: avg 3.222 ms, total 4726.83 ms)] [avg calls per frame: 1] [children: 59.8%] [unaccounted: 0.334%]
15:05:47: | | flush - [0.704%] [avg time: 0.078 ms (cpu time: avg 0.031 ms, total 46.8 ms)] [avg calls per frame: 1]
15:05:47: | | CopyResource - [0.542%] [avg time: 0.06 ms (cpu time: avg 0.01 ms, total 15.6 ms)] [avg calls per frame: 0]
15:05:47: | | conversion to 4:2:0 - [0.217%] [avg time: 0.024 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
15:05:47: | | call to encoder - [58.2%] [avg time: 6.447 ms (cpu time: avg 3.179 ms, total 4664.43 ms)] [avg calls per frame: 1]
15:05:47: | | sending stuff out - [0.108%] [avg time: 0.012 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
15:05:47: | Convert444Threads - [349%] [avg time: 38.686 ms (cpu time: avg 3.158 ms, total 4633.23 ms)] [avg calls per frame: 1]
15:05:47:
15:05:47: =====Stream End: 2013-09-09, 15:05:47=================================================
15:06:43: =====Stream Start: 2013-09-09, 15:06:43===============================================
15:06:43: Multithreaded optimizations: On
15:06:43: Base resolution: 1920x1080
15:06:43: Output resolution: 1920x1080
15:06:43: ------------------------------------------
15:06:43: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:06:43: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
15:06:43: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
15:06:43: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
15:06:43: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
15:06:43: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:06:44: ------------------------------------------
15:06:44: Audio Encoding: AAC
15:06:44: bitrate: 160
15:06:44: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
15:06:44: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
15:06:44: Using Monitor Capture
15:06:44: Video Encoding: x264
15:06:44: fps: 60
15:06:44: width: 1920, height: 1080
15:06:44: preset: medium
15:06:44: CBR: yes
15:06:44: CFR: yes
15:06:44: max bitrate: 4000
15:06:44: buffer size: 4000
15:06:44: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:06:44: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
15:07:07: Total frames rendered: 1376, number of late frames: 4 (0.29%) (it's okay for some frames to be late)
15:07:07: Total duplicated frames to ensure constant framerate: 2 (0.15%)
15:07:08:
15:07:08: Profiler results:
15:07:08:
15:07:08: ==============================================================
15:07:08: frame - [100%] [avg time: 6.142 ms (cpu time: avg 5.577 ms, total 7675.25 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0651%]
15:07:08: | frame preprocessing and rendering - [53%] [avg time: 3.254 ms (cpu time: avg 2.788 ms, total 3837.62 ms)] [avg calls per frame: 1] [children: 45.9%] [unaccounted: 7.11%]
15:07:08: | | scene->Preprocess - [45.9%] [avg time: 2.817 ms (cpu time: avg 2.324 ms, total 3198.02 ms)] [avg calls per frame: 1]
15:07:08: | video encoding and uploading - [47%] [avg time: 2.884 ms (cpu time: avg 2.788 ms, total 3837.63 ms)] [avg calls per frame: 1] [children: 46.5%] [unaccounted: 0.488%]
15:07:08: | | flush - [1.22%] [avg time: 0.075 ms (cpu time: avg 0.045 ms, total 62.4 ms)] [avg calls per frame: 1]
15:07:08: | | CopyResource - [0.195%] [avg time: 0.012 ms (cpu time: avg 0.011 ms, total 15.6 ms)] [avg calls per frame: 0]
15:07:08: | | conversion to 4:2:0 - [0.277%] [avg time: 0.017 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
15:07:08: | | call to encoder - [44.6%] [avg time: 2.741 ms (cpu time: avg 2.709 ms, total 3728.43 ms)] [avg calls per frame: 0]
15:07:08: | | sending stuff out - [0.147%] [avg time: 0.009 ms (cpu time: avg 0.022 ms, total 31.2 ms)] [avg calls per frame: 0]
15:07:08: | Convert444Threads - [531%] [avg time: 32.619 ms (cpu time: avg 3.242 ms, total 4461.63 ms)] [avg calls per frame: 1]
15:07:08:
15:07:08: =====Stream End: 2013-09-09, 15:07:08=================================================
15:07:50: Settings::Video: Disabling Aero
15:08:58: =====Stream Start: 2013-09-09, 15:08:58===============================================
15:08:58: Multithreaded optimizations: On
15:08:58: Base resolution: 1920x1080
15:08:58: Output resolution: 1920x1080
15:08:58: ------------------------------------------
15:08:58: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:08:58: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
15:08:58: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
15:08:58: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
15:08:58: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
15:08:58: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:08:59: ------------------------------------------
15:08:59: Audio Encoding: AAC
15:08:59: bitrate: 192
15:08:59: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
15:08:59: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
15:08:59: Using Monitor Capture
15:08:59: Video Encoding: x264
15:08:59: fps: 40
15:08:59: width: 1920, height: 1080
15:08:59: preset: fast
15:08:59: CBR: yes
15:08:59: CFR: yes
15:08:59: max bitrate: 5000
15:08:59: buffer size: 5000
15:08:59: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:08:59: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
15:09:22: Total frames rendered: 863, number of late frames: 8 (0.93%) (it's okay for some frames to be late)
15:09:22: Total duplicated frames to ensure constant framerate: 37 (4.29%)
15:09:22:
15:09:22: Profiler results:
15:09:22:
15:09:22: ==============================================================
15:09:22: frame - [100%] [avg time: 6.926 ms (cpu time: avg 5.314 ms, total 4586.43 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0578%]
15:09:22: | frame preprocessing and rendering - [55.4%] [avg time: 3.84 ms (cpu time: avg 2.675 ms, total 2308.81 ms)] [avg calls per frame: 1] [children: 48.6%] [unaccounted: 6.86%]
15:09:22: | | scene->Preprocess - [48.6%] [avg time: 3.365 ms (cpu time: avg 2.187 ms, total 1887.61 ms)] [avg calls per frame: 1]
15:09:22: | video encoding and uploading - [44.5%] [avg time: 3.082 ms (cpu time: avg 2.639 ms, total 2277.62 ms)] [avg calls per frame: 1] [children: 44.3%] [unaccounted: 0.173%]
15:09:22: | | flush - [1.08%] [avg time: 0.075 ms (cpu time: avg 0.072 ms, total 62.4 ms)] [avg calls per frame: 1]
15:09:22: | | CopyResource - [0.173%] [avg time: 0.012 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
15:09:22: | | conversion to 4:2:0 - [0.722%] [avg time: 0.05 ms (cpu time: avg 0.018 ms, total 15.6 ms)] [avg calls per frame: 0]
15:09:22: | | call to encoder - [42.1%] [avg time: 2.919 ms (cpu time: avg 2.53 ms, total 2184.02 ms)] [avg calls per frame: 1]
15:09:22: | | sending stuff out - [0.202%] [avg time: 0.014 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
15:09:22: | Convert444Threads - [734%] [avg time: 50.838 ms (cpu time: avg 3 ms, total 2589.62 ms)] [avg calls per frame: 1]
15:09:22:
15:09:22: =====Stream End: 2013-09-09, 15:09:22=================================================
15:10:25: =====Stream Start: 2013-09-09, 15:10:25===============================================
15:10:25: Multithreaded optimizations: On
15:10:25: Base resolution: 1920x1080
15:10:25: Output resolution: 1920x1080
15:10:25: ------------------------------------------
15:10:25: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:10:25: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
15:10:25: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
15:10:25: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
15:10:25: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
15:10:25: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:10:26: ------------------------------------------
15:10:26: Audio Encoding: AAC
15:10:26: bitrate: 192
15:10:26: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
15:10:26: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
15:10:26: Using Monitor Capture
15:10:26: Video Encoding: x264
15:10:26: fps: 40
15:10:26: width: 1920, height: 1080
15:10:26: preset: fast
15:10:26: CBR: yes
15:10:26: CFR: yes
15:10:26: max bitrate: 5000
15:10:26: buffer size: 5000
15:10:26: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:10:26: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
Warning -- Capture BitBlt failed (6).. just so you know
15:13:13: Total frames rendered: 6588, number of late frames: 18 (0.27%) (it's okay for some frames to be late)
15:13:13: Total duplicated frames to ensure constant framerate: 80 (1.21%)
15:13:13:
15:13:13: Profiler results:
15:13:13:
15:13:13: ==============================================================
15:13:13: frame - [100%] [avg time: 5.999 ms (cpu time: avg 4.698 ms, total 30950.6 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.05%]
15:13:13: | frame preprocessing and rendering - [56.3%] [avg time: 3.379 ms (cpu time: avg 2.256 ms, total 14866.9 ms)] [avg calls per frame: 1] [children: 53.1%] [unaccounted: 3.2%]
15:13:13: | | scene->Preprocess - [53.1%] [avg time: 3.187 ms (cpu time: avg 2.079 ms, total 13696.9 ms)] [avg calls per frame: 1]
15:13:13: | video encoding and uploading - [43.6%] [avg time: 2.617 ms (cpu time: avg 2.436 ms, total 16052.5 ms)] [avg calls per frame: 1] [children: 43.4%] [unaccounted: 0.25%]
15:13:13: | | flush - [1.42%] [avg time: 0.085 ms (cpu time: avg 0.078 ms, total 514.807 ms)] [avg calls per frame: 1]
15:13:13: | | CopyResource - [0.217%] [avg time: 0.013 ms (cpu time: avg 0.004 ms, total 31.2 ms)] [avg calls per frame: 0]
15:13:13: | | conversion to 4:2:0 - [0.483%] [avg time: 0.029 ms (cpu time: avg 0.002 ms, total 15.6 ms)] [avg calls per frame: 0]
15:13:13: | | call to encoder - [41%] [avg time: 2.462 ms (cpu time: avg 2.32 ms, total 15288.1 ms)] [avg calls per frame: 1]
15:13:13: | | sending stuff out - [0.217%] [avg time: 0.013 ms (cpu time: avg 0.018 ms, total 124.8 ms)] [avg calls per frame: 1]
15:13:13: | Convert444Threads - [840%] [avg time: 50.393 ms (cpu time: avg 2.675 ms, total 17628.1 ms)] [avg calls per frame: 1]
15:13:13:
15:13:13: =====Stream End: 2013-09-09, 15:13:13=================================================
15:13:30: =====Stream Start: 2013-09-09, 15:13:30===============================================
15:13:30: Multithreaded optimizations: On
15:13:30: Base resolution: 1920x1080
15:13:30: Output resolution: 1920x1080
15:13:30: ------------------------------------------
15:13:30: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti...
15:13:30: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
15:13:30: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
15:13:30: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
15:13:30: Playback device {0.0.0.00000000}.{4c582f60-ce2f-46d4-8ed7-d32dac9db749}
15:13:30: Using desktop audio input: Speakers (Realtek High Definition Audio)
15:13:31: ------------------------------------------
15:13:31: Audio Encoding: AAC
15:13:31: bitrate: 192
15:13:31: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/ColorKey_RGB.pShader.blob
15:13:31: C:/Users/REGISTERED USER/AppData/Roaming/OBS/shaderCache/shaders/AlphaIgnore.pShader.blob
15:13:31: Using Monitor Capture
15:13:31: Video Encoding: x264
15:13:31: fps: 40
15:13:31: width: 1920, height: 1080
15:13:31: preset: fast
15:13:31: CBR: yes
15:13:31: CFR: yes
15:13:31: max bitrate: 5000
15:13:31: buffer size: 5000
15:13:31: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
15:13:31: Syncing audio to video time (WARNING: you should not be doing this if you are just having webcam desync, that's a separate issue)
15:14:17: Total frames rendered: 1753, number of late frames: 20 (1.14%) (it's okay for some frames to be late)
15:14:17: Total duplicated frames to ensure constant framerate: 77 (4.39%)
15:14:17:
15:14:17: Profiler results:
15:14:17:
15:14:17: ==============================================================
15:14:17: frame - [100%] [avg time: 7.195 ms (cpu time: avg 4.974 ms, total 8720.46 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0556%]
15:14:17: | frame preprocessing and rendering - [61%] [avg time: 4.389 ms (cpu time: avg 2.287 ms, total 4009.23 ms)] [avg calls per frame: 1] [children: 57.7%] [unaccounted: 3.27%]
15:14:17: | | scene->Preprocess - [57.7%] [avg time: 4.154 ms (cpu time: avg 2.082 ms, total 3650.43 ms)] [avg calls per frame: 1]
15:14:17: | video encoding and uploading - [38.9%] [avg time: 2.802 ms (cpu time: avg 2.687 ms, total 4711.22 ms)] [avg calls per frame: 1] [children: 38.7%] [unaccounted: 0.222%]
15:14:17: | | flush - [1.17%] [avg time: 0.084 ms (cpu time: avg 0.124 ms, total 218.404 ms)] [avg calls per frame: 1]
15:14:17: | | CopyResource - [0.167%] [avg time: 0.012 ms (cpu time: avg 0.008 ms, total 15.6 ms)] [avg calls per frame: 0]
15:14:17: | | conversion to 4:2:0 - [0.431%] [avg time: 0.031 ms (cpu time: avg 0.017 ms, total 31.2 ms)] [avg calls per frame: 0]
15:14:17: | | call to encoder - [36.8%] [avg time: 2.646 ms (cpu time: avg 2.527 ms, total 4430.42 ms)] [avg calls per frame: 1]
15:14:17: | | sending stuff out - [0.181%] [avg time: 0.013 ms (cpu time: avg 0.008 ms, total 15.6 ms)] [avg calls per frame: 1]
15:14:17: | Convert444Threads - [716%] [avg time: 51.532 ms (cpu time: avg 2.821 ms, total 4945.23 ms)] [avg calls per frame: 1]
15:14:17:
15:14:17: =====Stream End: 2013-09-09, 15:14:17=================================================
