Hey there, lets get straight to the problem
Here we have my video - http://ru.twitch.tv/mordrien/b/354820544 , software capture, osu! is running fullscreen in 1920x1080 resolution. So, the problem is starting at 0:40, when my FPS seems to drop dramatically, also there is some sound lag every 30-40 sec. For me the game runs perfectly fine
You can see my settings and hardware in the log file
Well, i can see high amount of lagging frames. The problem is no matter what settings i choose, be it resize to 720p, capturing osu! with game capture, using 32bit OBS, chaning preset, its all the same: drop of fps on my stream and this sound lag. I think my hardware can afford 60fps stream, so i'd appreciate your opinion on the subject
Open Broadcaster Software v0.466a - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i5-3570 CPU @ 3.40GHz
CPU Speed: 3400MHz
Physical Memory: 8087MB Total, 5951MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
Aero is Disabled
Adapter 1
Video Adapter: NVIDIA GeForce GTX 550 Ti
Video Adapter Dedicated Video Memory: 1025179648
Video Adapter Shared System Memory: 3221385216
Base resolution: 1920x1080
Output resolution: 1920x1080
Loading up D3D10...
Using 7.1 surround speaker setup (experimental)
Using auxilary audio input: Microphone (2- SB Audigy)
Audio Encoding: AAC
bitrate: 160
Using Monitor Capture
device: Logitech HD Webcam C310,
device id (null),
chosen type: RGB24, usingFourCC: false, res: 1280x960 - 1280x960, fps: 5-30, fourCC: 00000000
Using directshow input
Video Encoding: x264
fps: 60
width: 1920, height: 1080
preset: veryfast
CBR: no
max bitrate: 2500
buffer size: 2500
quality: 9
Server selection: ﱀ)
bufferTime: 2519, outputRateWindowTime: 1000, dropThreshold: 3019
Total frames rendered: 7018, number of frames that lagged: 1423 (20.28%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 13.724 ms] [avg calls per frame: 1] [children: 99%] [unaccounted: 0.991%]
| scene->Preprocess - [47.9%] [avg time: 6.577 ms] [avg calls per frame: 1]
| video encoding and uploading - [51.1%] [avg time: 7.011 ms] [avg calls per frame: 1] [children: 20%] [unaccounted: 31%]
| | CopyResource - [0.16%] [avg time: 0.022 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [1.04%] [avg time: 0.143 ms] [avg calls per frame: 0]
| | call to encoder - [18.7%] [avg time: 2.567 ms] [avg calls per frame: 0]
| | sending stuff out - [0.131%] [avg time: 0.018 ms] [avg calls per frame: 0]
