Question / Help Flickering Capture and Resize Window Problem.
I have the latest build of OBS, and am trying to stream some gameplay using MAME. But i have noticed that im getting a flickering display on OBS and the stream itself every now and again when streaming, as soon as i stop streaming the display on OSD doesnt flicker anymore, any ideas what might be the cause of this occasional flickering. Here is the capture of the stream and you can see the said flicker in the first 10 seconds....
http://www.twitch.tv/blockaboots/b/381429386
My 2nd problem is with window scaling. Im using the software emulation option and have MAME windowed and have selected the MAME window in OSD, but have noticed if i change the size of the mame window it messes up the screen capture window and the active game display doesnt fill the capture area anymore. Is this normal behavior for OBS, to scale the capture window area if you change the size of the window you are trying to screen capture??
Heres my log for the session.....
Open Broadcaster Software v0.472b - 32bit (´・ω・`)
CPU Name: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz
CPU Speed: 3820MHz
Physical Memory: 4095MB Total, 4048MB Free
stepping id: 5, model 10, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1920, 1200}
Aero is Disabled
Adapter 1
Video Adapter: AMD Radeon HD 6900 Series
Video Adapter Dedicated Video Memory: 2135642112
Video Adapter Shared System Memory: 2159259648
Base resolution: 1920x1200
Output resolution: 1280x800
Loading up D3D10...
Playback device Default
Using desktop audio input: Speakers (Creative SB X-Fi)
Audio Encoding: AAC
bitrate: 160
Using Window Capture
x264: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
x264: profile High, level 4.0
Video Encoding: x264
fps: 60
width: 1280, height: 800
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Total frames rendered: 20327, number of frames that lagged: 3248 (15.98%) (it's okay for some frames to lag)
x264: frame I:92 Avg QP:16.31 size: 10582
x264: frame P:5614 Avg QP:18.95 size: 676
x264: frame B:14543 Avg QP:20.89 size: 96
x264: consecutive B-frames: 3.7% 1.5% 0.4% 94.4%
x264: mb I I16..4: 89.1% 5.8% 5.1%
x264: mb P I16..4: 0.9% 0.2% 0.1% P16..4: 1.5% 0.2% 0.1% 0.0% 0.0% skip:96.9%
x264: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 0.3% 0.0% 0.0% direct: 0.1% skip:99.4% L0:51.3% L1:45.9% BI: 2.8%
x264: 8x8 transform intra:11.1% inter:79.4%
x264: coded y,uvDC,uvAC intra: 9.4% 18.4% 11.3% inter: 0.2% 0.3% 0.1%
x264: i16 v,h,dc,p: 75% 22% 2% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 24% 45% 2% 2% 2% 2% 2% 3%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 51% 12% 1% 2% 2% 2% 2% 2%
x264: i8c dc,h,v,p: 76% 14% 9% 1%
x264: Weighted P-Frames: Y:0.2% UV:0.1%
x264: ref P L0: 67.8% 32.2%
x264: ref B L0: 58.9% 41.1%
x264: ref B L1: 85.1% 14.9%
x264: kb/s:136.93
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Server selection: rtmp://live-fra.justin.tv/app
bufferTime: 1931, outputRateWindowTime: 1000, dropThreshold: 2431
Total frames rendered: 1306, number of frames that lagged: 104 (7.96%) (it's okay for some frames to lag)
x264: frame I:5 Avg QP:20.93 size: 42451
x264: frame P:316 Avg QP:27.42 size: 1150
x264: frame B:907 Avg QP:34.49 size: 280
x264: consecutive B-frames: 1.1% 0.7% 1.2% 97.0%
x264: mb I I16..4: 75.7% 6.3% 18.0%
x264: mb P I16..4: 0.9% 0.2% 0.2% P16..4: 2.4% 0.5% 0.4% 0.0% 0.0% skip:95.4%
x264: mb B I16..4: 0.2% 0.0% 0.1% B16..8: 1.2% 0.2% 0.0% direct: 0.1% skip:98.2% L0:49.9% L1:47.4% BI: 2.6%
x264: 8x8 transform intra:8.1% inter:45.0%
x264: coded y,uvDC,uvAC intra: 22.1% 20.0% 15.1% inter: 0.3% 0.2% 0.1%
x264: i16 v,h,dc,p: 66% 31% 2% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 15% 21% 40% 3% 4% 3% 4% 3% 7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 32% 31% 15% 3% 4% 3% 3% 3% 4%
x264: i8c dc,h,v,p: 55% 27% 16% 1%
x264: Weighted P-Frames: Y:0.0% UV:0.0%
x264: ref P L0: 51.5% 48.5%
x264: ref B L0: 67.4% 32.6%
x264: ref B L1: 76.6% 23.4%
x264: kb/s:318.02
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Total frames rendered: 2932, number of frames that lagged: 126 (4.30%) (it's okay for some frames to lag)
x264: frame I:12 Avg QP:24.54 size: 52041
x264: frame P:874 Avg QP:29.72 size: 3694
x264: frame B:1967 Avg QP:32.68 size: 590
x264: consecutive B-frames: 5.4% 4.8% 9.4% 80.4%
x264: mb I I16..4: 56.4% 22.6% 21.0%
x264: mb P I16..4: 1.2% 0.9% 0.6% P16..4: 5.5% 1.8% 1.3% 0.0% 0.0% skip:88.6%
x264: mb B I16..4: 0.2% 0.1% 0.1% B16..8: 2.1% 0.7% 0.1% direct: 0.3% skip:96.5% L0:46.4% L1:49.6% BI: 4.0%
x264: 8x8 transform intra:28.5% inter:44.8%
x264: coded y,uvDC,uvAC intra: 40.8% 38.3% 27.6% inter: 1.1% 0.9% 0.3%
x264: i16 v,h,dc,p: 84% 11% 4% 1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 20% 19% 21% 5% 7% 6% 7% 7% 8%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 25% 16% 5% 6% 5% 4% 4% 4%
x264: i8c dc,h,v,p: 67% 14% 17% 2%
x264: Weighted P-Frames: Y:1.9% UV:1.8%
x264: ref P L0: 58.6% 41.4%
x264: ref B L0: 71.1% 28.9%
x264: ref B L1: 85.2% 14.8%
x264: kb/s:828.95
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Total frames rendered: 1193, number of frames that lagged: 1 (0.08%) (it's okay for some frames to lag)
x264: frame I:5 Avg QP:22.10 size: 36843
x264: frame P:449 Avg QP:25.07 size: 1962
x264: frame B:660 Avg QP:28.56 size: 182
x264: consecutive B-frames: 19.9% 2.9% 0.5% 76.7%
x264: mb I I16..4: 75.3% 12.7% 12.1%
x264: mb P I16..4: 1.6% 0.2% 0.3% P16..4: 3.4% 1.2% 0.6% 0.0% 0.0% skip:92.6%
x264: mb B I16..4: 0.2% 0.0% 0.0% B16..8: 1.6% 0.1% 0.0% direct: 0.1% skip:97.9% L0:70.8% L1:26.8% BI: 2.4%
x264: 8x8 transform intra:11.0% inter:76.6%
x264: coded y,uvDC,uvAC intra: 18.2% 13.7% 8.4% inter: 1.1% 0.5% 0.1%
x264: i16 v,h,dc,p: 61% 38% 1% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 28% 25% 3% 4% 3% 4% 3% 7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 53% 12% 2% 2% 2% 2% 2% 2%
x264: i8c dc,h,v,p: 64% 21% 14% 1%
x264: ref P L0: 76.3% 23.7%
x264: ref B L0: 59.9% 40.1%
x264: ref B L1: 82.8% 17.2%
x264: kb/s:510.75
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Using graphics capture
Total frames rendered: 2270, number of frames that lagged: 4 (0.18%) (it's okay for some frames to lag)
x264: frame I:9 Avg QP:17.62 size: 27292
x264: frame P:552 Avg QP:24.78 size: 274
x264: frame B:1629 Avg QP:34.79 size: 85
x264: consecutive B-frames: 0.8% 0.0% 0.0% 99.2%
x264: mb I I16..4: 85.6% 6.9% 7.5%
x264: mb P I16..4: 0.3% 0.0% 0.0% P16..4: 0.4% 0.1% 0.0% 0.0% 0.0% skip:99.1%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.2% 0.0% 0.0% direct: 0.0% skip:99.7% L0:61.5% L1:35.9% BI: 2.6%
x264: 8x8 transform intra:7.3% inter:51.4%
x264: coded y,uvDC,uvAC intra: 8.2% 6.8% 5.4% inter: 0.1% 0.0% 0.0%
x264: i16 v,h,dc,p: 93% 6% 1% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 27% 10% 54% 1% 1% 1% 1% 1% 3%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 31% 17% 3% 3% 4% 4% 4% 5%
x264: i8c dc,h,v,p: 85% 5% 9% 0%
x264: Weighted P-Frames: Y:0.2% UV:0.0%
x264: ref P L0: 69.7% 30.3%
x264: ref B L0: 57.9% 42.1%
x264: ref B L1: 79.9% 20.1%
x264: kb/s:115.50
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
using memory capture
Total frames rendered: 1940, number of frames that lagged: 4 (0.21%) (it's okay for some frames to lag)
x264: frame I:9 Avg QP:17.00 size: 11545
x264: frame P:541 Avg QP:20.57 size: 1839
x264: frame B:1310 Avg QP:22.13 size: 404
x264: consecutive B-frames: 5.3% 1.9% 1.1% 91.6%
x264: mb I I16..4: 91.6% 4.7% 3.7%
x264: mb P I16..4: 0.5% 0.3% 0.1% P16..4: 2.2% 0.8% 0.5% 0.0% 0.0% skip:95.5%
x264: mb B I16..4: 0.1% 0.0% 0.0% B16..8: 1.9% 0.4% 0.0% direct: 0.2% skip:97.3% L0:52.9% L1:41.3% BI: 5.7%
x264: 8x8 transform intra:16.3% inter:66.3%
x264: coded y,uvDC,uvAC intra: 20.6% 18.9% 14.4% inter: 0.9% 0.5% 0.1%
x264: i16 v,h,dc,p: 83% 14% 2% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 26% 22% 4% 5% 5% 6% 6% 7%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 13% 48% 14% 3% 4% 4% 5% 4% 5%
x264: i8c dc,h,v,p: 78% 12% 8% 2%
x264: Weighted P-Frames: Y:5.7% UV:5.2%
x264: ref P L0: 65.6% 34.4%
x264: ref B L0: 58.3% 41.7%
x264: ref B L1: 92.9% 7.1%
x264: kb/s:410.72
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Total frames rendered: 3647, number of frames that lagged: 1 (0.03%) (it's okay for some frames to lag)
x264: frame I:18 Avg QP:31.56 size: 17915
x264: frame P:2562 Avg QP:36.42 size: 2720
x264: frame B:987 Avg QP:36.12 size: 1055
x264: consecutive B-frames: 54.9% 24.1% 1.9% 19.2%
x264: mb I I16..4: 38.6% 53.6% 7.8%
x264: mb P I16..4: 1.8% 1.0% 0.1% P16..4: 13.3% 1.6% 0.9% 0.0% 0.0% skip:81.3%
x264: mb B I16..4: 0.6% 1.6% 0.0% B16..8: 9.4% 0.4% 0.0% direct: 1.7% skip:86.3% L0:45.8% L1:52.4% BI: 1.8%
x264: 8x8 transform intra:44.2% inter:87.1%
x264: coded y,uvDC,uvAC intra: 25.6% 32.6% 14.6% inter: 3.8% 2.6% 0.2%
x264: i16 v,h,dc,p: 42% 54% 3% 1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 19% 31% 26% 3% 5% 4% 4% 4% 5%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 11% 67% 8% 2% 3% 2% 2% 2% 3%
x264: i8c dc,h,v,p: 70% 19% 9% 2%
x264: Weighted P-Frames: Y:2.7% UV:2.1%
x264: ref P L0: 69.2% 30.8%
x264: ref B L0: 75.5% 24.5%
x264: ref B L1: 98.8% 1.2%
x264: kb/s:1121.04
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Total frames rendered: 3217, number of frames that lagged: 10 (0.31%) (it's okay for some frames to lag)
x264: frame I:20 Avg QP:25.69 size: 23023
x264: frame P:1425 Avg QP:26.66 size: 2093
x264: frame B:1692 Avg QP:18.97 size: 183
x264: consecutive B-frames: 26.8% 3.4% 0.6% 69.2%
x264: mb I I16..4: 66.9% 21.2% 11.9%
x264: mb P I16..4: 2.2% 0.6% 0.2% P16..4: 6.9% 1.2% 0.8% 0.0% 0.0% skip:88.1%
x264: mb B I16..4: 0.4% 0.2% 0.0% B16..8: 0.9% 0.0% 0.0% direct: 0.3% skip:98.1% L0:50.3% L1:45.8% BI: 3.8%
x264: 8x8 transform intra:21.3% inter:86.4%
x264: coded y,uvDC,uvAC intra: 16.2% 28.3% 14.9% inter: 1.6% 1.2% 0.2%
x264: i16 v,h,dc,p: 52% 45% 2% 1%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 29% 39% 2% 2% 2% 3% 2% 3%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 7% 82% 6% 1% 1% 1% 1% 1% 1%
x264: i8c dc,h,v,p: 73% 18% 8% 1%
x264: Weighted P-Frames: Y:1.3% UV:1.3%
x264: ref P L0: 72.7% 27.3%
x264: ref B L0: 72.4% 27.6%
x264: ref B L1: 96.6% 3.4%
x264: kb/s:571.06
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Total frames rendered: 952, number of frames that lagged: 1 (0.11%) (it's okay for some frames to lag)
x264: frame I:4 Avg QP:10.75 size: 458
x264: frame P:220 Avg QP:13.05 size: 43
x264: frame B:648 Avg QP:16.88 size: 40
x264: mb I I16..4: 100.0% 0.0% 0.0%
x264: mb P I16..4: 0.0% 0.0% 0.0% P16..4: 0.0% 0.0% 0.0% 0.0% 0.0% skip:100.0%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.0% 0.0% 0.0% direct: 0.0% skip:100.0%
x264: 8x8 transform intra:0.0%
x264: coded y,uvDC,uvAC intra: 0.0% 0.0% 0.0% inter: 0.0% 0.0% 0.0%
x264: i16 v,h,dc,p: 98% 0% 2% 0%
x264: i8c dc,h,v,p: 100% 0% 0% 0%
x264: kb/s:20.35
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
Total frames rendered: 7736, number of frames that lagged: 51 (0.66%) (it's okay for some frames to lag)
x264: frame I:39 Avg QP:19.61 size: 43568
x264: frame P:1973 Avg QP:17.70 size: 358
x264: frame B:5644 Avg QP:21.23 size: 73
x264: consecutive B-frames: 1.6% 0.2% 0.4% 97.9%
x264: mb I I16..4: 76.4% 10.8% 12.8%
x264: mb P I16..4: 0.3% 0.0% 0.0% P16..4: 0.5% 0.2% 0.1% 0.0% 0.0% skip:98.9%
x264: mb B I16..4: 0.0% 0.0% 0.0% B16..8: 0.3% 0.0% 0.0% direct: 0.0% skip:99.6% L0:56.0% L1:42.5% BI: 1.5%
x264: 8x8 transform intra:10.4% inter:63.9%
x264: coded y,uvDC,uvAC intra: 18.4% 13.4% 11.9% inter: 0.1% 0.1% 0.0%
x264: i16 v,h,dc,p: 87% 9% 4% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 34% 15% 32% 8% 2% 2% 2% 2% 4%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 23% 44% 13% 3% 3% 3% 4% 2% 5%
x264: i8c dc,h,v,p: 86% 10% 4% 1%
x264: Weighted P-Frames: Y:0.2% UV:0.2%
x264: ref P L0: 64.1% 35.9%
x264: ref B L0: 59.4% 40.6%
x264: ref B L1: 88.9% 11.1%
x264: kb/s:175.60
Loading up D3D10...
Audio Encoding: AAC
bitrate: 160
fps: 60
preset: fast
CBR: no
CFR: no
max bitrate: 1200
buffer size: 1800
quality: 8
device: AmaRec Video Capture,
device id (null),
chosen type: RGB32, usingFourCC: false, res: 1280x720 - 1280x720, fps: 9.99001-9.99001, fourCC: 00000000
Using directshow input
Total frames rendered: 6951, number of frames that lagged: 7 (0.10%) (it's okay for some frames to lag)
x264: frame I:43 Avg QP:26.79 size: 29712
x264: frame P:4372 Avg QP:31.76 size: 2638
x264: frame B:2457 Avg QP:24.61 size: 426
x264: consecutive B-frames: 49.4% 7.9% 2.8% 39.9%
x264: mb I I16..4: 49.3% 39.7% 10.9%
x264: mb P I16..4: 1.8% 0.5% 0.1% P16..4: 9.4% 1.8% 1.2% 0.0% 0.0% skip:85.2%
x264: mb B I16..4: 0.6% 0.2% 0.0% B16..8: 3.8% 0.4% 0.0% direct: 0.5% skip:94.6% L0:40.5% L1:56.6% BI: 2.8%
x264: 8x8 transform intra:25.6% inter:83.3%
x264: coded y,uvDC,uvAC intra: 20.1% 22.0% 12.6% inter: 3.3% 1.8% 0.3%
x264: i16 v,h,dc,p: 62% 35% 2% 0%
x264: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 25% 27% 24% 3% 4% 4% 3% 4% 4%
x264: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 68% 9% 2% 2% 2% 2% 1% 2%
x264: i8c dc,h,v,p: 75% 15% 8% 1%
x264: Weighted P-Frames: Y:3.4% UV:2.6%
x264: ref P L0: 75.0% 25.0%
x264: ref B L0: 69.8% 30.2%
x264: kb/s:961.05
Profiler results:
frame - [100%] [avg time: 7.462 ms] [avg calls per frame: 1] [children: 90.2%] [unaccounted: 9.76%]
| scene->Preprocess - [47.9%] [avg time: 3.578 ms] [avg calls per frame: 1]
| video encoding and uploading - [42.3%] [avg time: 3.156 ms] [avg calls per frame: 1] [children: 13.8%] [unaccounted: 28.5%]
| | CopyResource - [0.75%] [avg time: 0.056 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.0536%] [avg time: 0.004 ms] [avg calls per frame: 0]
| | call to encoder - [13%] [avg time: 0.968 ms] [avg calls per frame: 0]
| | sending stuff out - [0%] [avg time: 0 ms] [avg calls per frame: 0]
This is my internet speeds btw...
Lain
Forum Admin
Lain
Forum Moderator
Developer
Window capture has a slight design flaw that will cause it to resize the internal texture when a window resizes. AKA it doesn't respond well at all to a window that resizes.
