ranmyaku262
I recently upgraded my PC and finally got around to re-installing and reconfiguring my Virtual Audio Cables again for streaming.
I have 3 audio cables i use:
Line 1: Default Audio
Line 2: What the Stream Hears
Line 3: Skype
Repeaters basically go this way 3->2 and 1->2 and 2->My Headset.
This way i basically can monitor what the stream hears and i can just include or exclude certain audio when I want and just redirect 3 or 1 to my headset exclusively at any moment with a different repeater.
The issue is that for some reason when using either Kernal or MMS audio repeaters I'm able to hear all audio just fine from all lines, OBS on the other hand only hears line 2 and line 2 only.
If anyone can shed some light on this issue what might be a good place to start looking for how to fix this because I used this before on a different PC and this setup worked fine and I've mirrored the configuration the best i could so I'm somewhat lost on the issue and i'm unsure if its some new quirk of OBS or a configuration issue in the Audio Cables.
Line 3: Skype
