If you set the OBS to 60fps capture and then don't set the game frame to the integer of 60, OBS capture frame get judder
so record smoothly without a capture card, you have to limit the game frame to an integer of 60.
This method is useless if the frame is not kept constant.
Look at this video if you don't know this problem
https://youtu.be/pmw1zX81iAg
