Hey, I'm using OBS to stream on twitch.tv
I had a very laggy stream, here is my Log from my 5/10 minute test stream.
https://gist.github.com/2221d0b02950f5211602
I also got this notification from OBS afterwards.
Aero is disabled
Aero seems to be disabled, consider enabling it unless using monitor capture.
Multiple video cards detected
If you are having problems and are using a laptop, see this thread for advice.
If you are using SLI or Crossfire, you may need to disable it for compatibility with OBS.
Window capture with Aero disabled
You are using window capture with Aero disabled. This causes other windows placed on top of the capture window to show on the stream instead of only the selected window. It is recommended to enable Aero when using window capture to prevent this.
Slow sources detected
Some of your sources are taking a very long time to start or stop when changing scenes. If you use video devices such as a webcam, capture card, etc, add them as global sources to prevent this.
4 issues found (1 major, 3 minor).
As for Aero I'm not using Monitor Capture but I am using windows capture. So turning that on would be okay, right?
Multiple video cards detected. I have my GTX 670 and my stock Graphics card. How would I set this to just my GTX?
As for my slow sources, I have all the ones listed as Global Sources. So how would I fix that.
Thanks for your help. I'be been learning all this from youtube.
Aero is disabled
