Extracted images from Affinity Designer Wont load in obs.
CoHutt
I am trying to make some images in Affinity Designer. I exported the image and opened them in windows image viewer, they showed fine.
When bringing into obs, the file doesnt load, and the logs show:
22:38:10.967: Failed to decode frame for 'E:/Streaming/Ideas/untitled.jpg': Invalid data found when processing input
22:38:10.968: gs_image_file_init_internal: Failed to load file 'E:/Streaming/Ideas/untitled.jpg'
22:38:10.968: [image_source: 'Image'] failed to load texture 'E:/Streaming/Ideas/untitled.jpg'
Any help?
its a png file not a JPG file ;) have you set the false ending ? so he read it as JPG but its an PNG ?
"Upload the file or an **example file with the same issue.**"
I cant upload the original jpg, as its barely too big, but its the same image, just exported as a png instead of a jpg
Heres the log with the png
*Time where the error appears 18:10:02.816*
**NOTE** While getting a log for the png file, i found out if i close obs while the file that isnt working is imported, then open obs back up, it will appear...Its a fix for now, but not a solution.. Thought maybe this could help figure the problem out
Sorry for the late response, currently have a messed up schedule
Don't use images larger than your Preview. PNG is a better format for this style of image and about 1/12 the file size in this case.
