Hello to the OBS forum.
I have been trying to figure out the best OBS settings for recording that goes well with my PC's capabilities, but I have not found a suitable one that gave me no frame problems or overloaded encoder warnings. Therefore, I found myself here looking for assistance.
You will see below in order my Video settings, Advanced settings, and Recording Output settings. I would like to note here that these settings have been the only settings that went well enough. Although it does not overload with these settings, I still have problems with frames with them as the frames appear lower than 60 in the recording (which is bad) when I play any game at 165 (it overloads when I switch to 165).
Here is the link for the latest log file where I tried using 165 frames with 2K output and 50000-70000 VBR: https://obsproject.com/logs/mfVydaM3aKq0rS8Y
I have tried CQP, VBR, and CBR with the given settings in the screenshots, but all of them gave same results with bad frame performance. It overloaded every time that I increased the frame number (120 and up).
No overloading occurs with any frame setting when Output resolution is set to 1080p, but that is not something that I want.
My PC specifications:
- MSI MAG Z790 TOMAHAWK WIFI 7200 MHz (OC)
- Intel i7-14700K
- NVIDIA RTX 4070 Ti Super
- 32 GB DDR5 6000 MHz CL36 RAM
- Windows 10 22H2
- 1 TB SSD
- AOC 24 inch 2K Monitor
Thanks in advance.
- Intel i7-14700K
- Windows 10 22H2
- 1 TB SSD
Thanks in advance.
