Emergency help about audio equalizer processing
congyt
My work needs a random dynamic audio equalizer, or random sound effect.
For example, change the sound effect every few seconds, but automatically adjust the audio sound effect within a certain range.
However, I only found some fixed, manually adjusted audio equalizers or plug-ins in the forum. Would you please tell me which plug-ins can realize this function? Thank you very much.
To be able to automatically adjust the sound effect, adjust it randomly and fluctuate within a certain range
