Question / Help Elgato HD60 Pro : Can I Stream 1080p 60 FPS With my upload speed???
Harold
Maybe, but if you're going to stream to twitch, you NEED partnership with them.
And if you're planning on having the elgato capture the same computer you're going to install it in, don't waste your money or time.
Big Mike
why? i am going to install it in my computer, is that good? i am only gonna use it for consoles for my ps4 and xbox one?
Harold
I guess you didn't actually read what I wrote about it.
Also, there are FAR better cards out there than the elgatos.
Harold
Cards that are better than elgato by brand:
Startech
Avermedia
Blackmagic
Magewell
And you seem to only read half or a quarter of my posts at a time.
Big Mike
Startech
Avermedia
Blackmagic
Magewell
alright, ill take a look. but what did you mean, by saying : if i plan having ti install the elgato in the same computer, don't waste our time, what did you mean bye that?
Harold
Some people try to use a capture card to capture the same computer they install the card in.
That's provably stupid, especially with lower-grade cards.
At best, there is no performance gain, and most of the time there's actually a performance loss.
Big Mike
oh, ok, but if i use it for consoles only, i won't loose performance or nothing, right, so am i all good to go?
i don't plan to record my games on my pc, only thru consoles
alpinlol
Startech
Avermedia
Blackmagic
Magewell
I actually think at this Pricepoint the Avermedia is worse though if you go in the higher-end category theres probably quite a difference.
