Question / Help Elgato HD60 Pro Audio Crackle on 1080p
Just to add to the ever-growing list of varying, possible solutions...
I had this issue but only starting last week (without having changed any settings). Having done some digging today (and upgrading to Windows 11 in the meantime - not sure if that's relevant to why this solution works at all) I found the way I could get rid of the crackle was in three changes.
First two are in the Elgato capture's properties (see image below):
1. I changed 'Resolution/FPS Type' from "Device Default" to "Custom" and set 'Resolution' to 1920x1080 manually
2. Disabled the 'Buffering' option
Not sure if it's relevant that my 'Audio Output Mode' is "Capture aduio only" here as well.
Third and final change was to go into the Advanced audio properties. My Elgato device in there has its 'Audio Monitoring' set to "Monitor and Output", so the change I made here was to change it to "Monitor Off" and back again to "Monitor and Output".
Not sure why the last thing made a difference, maybe it refreshes the audio input stream, but it definitely had an effect. To verify this I then went back into the device properties, reverted the resolution type setting then put it back to custom again and sure enough, the crackling didn't go away until I once again effectively off/on'd the audio monitoring for the Elgato device.
Hope this helps someone else!
EDIT: In case it's relevant, I was on v27.2.3 at the time the issue started occurring, I have since updated to v27.2.4 - the issue still persisted on 27.2.4 but I don't know if the fix for me would also work on earlier versions
Changing the "audiodg.exe" process settings in the Task Manager may help.
1. Open the Task Manager as an administrator (right-click in Start Menu then Run as Administrator)
2. Select the "Details" tab along the top
3. Find the "audiodg.exe" process and right-click it (note: if you can't see this process, you haven't opened the Task Manager as an administrator, go back to step 1).
4. Set the priority of "audiodg.exe" to "High"
5. Set the affinity of "audiodg.exe" to a single core e.g. CPU 2
This tip came from youTube. https://www.youtube.com/watch?v=71HrZfR_Fro
