Elgato HD 60 S with no Sound...
Shadow2k1
Just like the Title says...
I'm using an Elgato, HD 60 S and i've tried 3 different 3.0 blue UBS Slots, and i have no sound... no matter what i do... restart, reinstall, what... OBS gives me Video just no sound...
I even tried putting the sound setting to Monitor and Output only.... Still no sound...
Is my Elgato bad, or is my USB drives bad..... i'm just not sure why i got no sound....
I use and external Elgato Capture Card, and i plug 1 into my console, and the other into the PC,
A couple months back it use to work really good.... but now it doesn't do anything.. i got video just no sound... it's really weird..
As you wrote already, i know. An HD60S.
My question was which plugs you use. So you use the HDMI cable only coming from the console, right?
So the sound should come thru this HDMI cable (and has already a while back, as you stated). Check your sound-settings on the console! If you plug in headphones into console, it can't work properly. Most consoles can have only one active sound output.
I'll mess around with my audio settings, and see what happens.....
I do have the HDMI cables plugged in correctly, but i'll check those again too....
As for the USB going to the Computer, i'm using the 3.0 usb ports... it wont' work on anything under that... last i heard...
It's weird because i have another Capture Device called the Elgato HD Capture.... and it picks up my sound instantly..... but for some odd reason... OBS flat lines, there's no sound... so i dunno what is going on.... So i could be wrong, but i think it's a setting in OBS i'm missing... or not using..
When i run the Elgato Capture Device i get sound... i hear it... my Stream hears it...
But when i use OBS, i get no sound.... so i dunno i really use to like OBS... but for some reason.. i get no sound.. Even if i go the PC route, and stream PC, i got no sound... so i dunno what's causing it not to register...
that's why i'm wondering if either my Windows 10, or OBS is somehow glitching and not letting the source work.... But if it was my System.. why does my Elgato HD Stream program work and not OBS that's what i'm confused.... OBS i must be missing something...
Everything i use, whether it's Elgato Software, Xsplit, or any thing i get sound.... but for some reason OBS wont' give me sound... Like i said this started 2 months ago.... i dunno what's up... I even uninstalled, and re installed OBS, and still nothing.... so i dunno what's up with OBS
