Question / Help Elgato 60 won't work with OBS 64bit, and 32bit is glitched
ZeroTransPat
So, basically, when I try and run my new capture card with OBS 64bit, it doesn't detect the driver.
So, I switch to 32bit, and the picture is VERY pixelated, and there is no sound.
I can't even use XSplit because it lags, and the sound is delayed about 3 seconds.
The only broadcaster that seems to work fine @ 1080p and 60fps is the software that it came with.
That's fine and all, but I cannot put splits up if I want to speed run a game, or anything like that.
Is there a fix for this at all?
Thanks.
19:32:31: CLR host plugin strings not found, dynamically loading 4 strings
19:32:31: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
19:32:31: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
19:32:31: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
19:32:31: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
19:32:31: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
19:32:31: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
19:32:32: CLRHost:: Could not find/load browser settings at location C:\Users\Pat\AppData\Roaming\OBS\pluginData\browser.json
19:32:32: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\Pat\AppData\Roaming\OBS\pluginData\browser.json'.
19:32:32: File name: 'C:\Users\Pat\AppData\Roaming\OBS\pluginData\browser.json'
19:32:32: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
19:32:32: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
19:32:32: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
19:32:32: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
19:32:32: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
19:32:32: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
19:33:13: Open Broadcaster Software v0.635b - 64bit ( ^ω^)
19:33:13: -------------------------------
19:33:13: CPU Name: Intel(R) Core(TM) i3-4130 CPU @ 3.40GHz
19:33:13: CPU Speed: 3399MHz
19:33:13: Physical Memory: 8061MB Total, 5825MB Free
19:33:13: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 2
19:33:13: monitor 1: pos={0, 0}, size={1280, 1024}
19:33:13: monitor 2: pos={-1280, 0}, size={1280, 1024}
19:33:13: Windows Version: 6.1 Build 7601 S
19:33:13: Aero is Enabled
19:33:13: OBS Modules:
19:33:13: Base Address Module
19:33:13: 000000003F900000 OBS.exe
19:33:13: 00000000E0630000 OBSApi.dll
19:33:13: 00000000F3D40000 CLRHostPlugin.dll
19:33:13: 00000000E2330000 DShowPlugin.dll
19:33:13: 00000000E1E10000 GraphicsCapture.dll
19:33:13: 00000000E2300000 NoiseGate.dll
19:33:13: 00000000E1DE0000 PSVPlugin.dll
19:33:13: ------------------------------------------
19:33:13: Adapter 1
19:33:13: Video Adapter: ASUS R9 270 Series
19:33:13: Video Adapter Dedicated Video Memory: 2128814080
19:33:13: Video Adapter Shared System Memory: 3957942272
19:33:13: Video Adapter Output 1: pos={0, 0}, size={1280, 1024}, attached=true
19:33:13: Video Adapter Output 2: pos={-1280, 0}, size={1280, 1024}, attached=true
19:33:13: =====Stream Start: 2014-09-18, 19:33:13===============================================
19:33:13: Multithreaded optimizations: On
19:33:13: Base resolution: 240x128
19:33:13: Output resolution: 80x42
19:33:13: Loading up D3D10 on ASUS R9 270 Series (Adapter 1)...
19:33:13: Audio Format: 48000 Hz
19:33:13: Audio Channels: 2 Ch
19:33:13: Playback device {0.0.0.00000000}.{7f97edec-39ae-4667-b6b4-a8d23d33dc63}
19:33:13: Using desktop audio input: Speakers (Realtek High Definition Audio)
19:33:13: Global Audio time adjust: 0
19:33:13: Using auxilary audio input: Microphone (Webcam 905)
19:33:13: Mic time offset: 0
19:33:13: Audio Encoding: AAC
19:33:13: bitrate: 128
Warning -- DShowPlugin: Could not create device filter
19:33:13: Using directshow input
19:33:13: Using Window Capture
19:33:14: ------------------------------------------
19:33:14: device: Logitech Webcam 905,
19:33:14: device id \\?\usb#vid_046d&pid_080a&mi_00#6&1ea34d51&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
19:33:14: chosen type: I420, usingFourCC: false, res: 160x120 - 160x120, frameIntervals: 333333-2000000
19:33:14: use buffering: false - 0, fourCC: 'I420'
19:33:14: audio device: Disable,
19:33:14: audio device id Disabled,
19:33:14: audio time offset 0,
19:33:14:
19:33:14: Using directshow input
19:33:14: Scene buffering time set to 700
19:33:14: Video Encoding: x264
19:33:14: fps: 30
19:33:14: width: 80, height: 42
19:33:14: preset: veryfast
19:33:14: profile: main
19:33:14: keyint: 60
19:33:14: CBR: yes
19:33:14: CFR: yes
19:33:14: max bitrate: 1000
19:33:14: buffer size: 1000
19:33:15: CLRHost:: Browser 1: Status message:
19:33:27: Using Window Capture
19:34:05: Using Monitor Capture
19:35:14: Using graphics capture
19:35:14: Trying to hook process: GameCapture.exe
19:35:32: FlushBufferedVideo: Flushing 4 packets over 100 ms
19:35:32: Total frames encoded: 4120, total frames duplicated: 623 (15.12%)
19:35:32: Total frames rendered: 3658, number of late frames: 464 (12.68%) (it's okay for some frames to be late)
19:35:32:
19:35:32: Profiler time results:
19:35:32:
19:35:32: ==============================================================
19:35:32: video thread frame - [100%] [avg time: 16.625 ms] [children: 87.3%] [unaccounted: 12.7%]
19:35:32: | scene->Preprocess - [82.6%] [avg time: 13.734 ms]
19:35:32: | GPU download and conversion - [4.69%] [avg time: 0.78 ms] [children: 4.54%] [unaccounted: 0.15%]
19:35:32: | | flush - [4.31%] [avg time: 0.716 ms]
19:35:32: | | CopyResource - [0.205%] [avg time: 0.034 ms]
19:35:32: | | conversion to 4:2:0 - [0.0301%] [avg time: 0.005 ms]
19:35:32: Convert444Thread - [100%] [avg time: 0.008 ms] [children: 75%] [unaccounted: 25%]
19:35:32: | Convert444toNV12 - [75%] [avg time: 0.006 ms]
19:35:32: encoder thread frame - [100%] [avg time: 0.154 ms] [children: 1.95%] [unaccounted: 98.1%]
19:35:32: | sending stuff out - [1.95%] [avg time: 0.003 ms]
19:35:32:
19:35:32:
19:35:32: Profiler CPU results:
19:35:32:
19:35:32: video thread frame - [cpu time: avg 2.183 ms, total 7987.25 ms] [avg calls per frame: 1]
19:35:32: | scene->Preprocess - [cpu time: avg 1.731 ms, total 6333.64 ms] [avg calls per frame: 1]
19:35:32: | GPU download and conversion - [cpu time: avg 0.068 ms, total 249.601 ms] [avg calls per frame: 1]
19:35:32: | | flush - [cpu time: avg 0.025 ms, total 93.6 ms] [avg calls per frame: 1]
19:35:32: | | CopyResource - [cpu time: avg 0.03 ms, total 109.201 ms] [avg calls per frame: 1]
19:35:32: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:35:32: Convert444Thread - [cpu time: avg 0.012 ms, total 46.8 ms] [avg calls per frame: 1]
19:35:32: | Convert444toNV12 - [cpu time: avg 0.004 ms, total 15.6 ms] [avg calls per frame: 1]
19:35:32: encoder thread frame - [cpu time: avg 0.041 ms, total 171.601 ms] [avg calls per frame: 1]
19:35:32: | sending stuff out - [cpu time: avg 0.007 ms, total 31.201 ms] [avg calls per frame: 1]
19:35:32:
19:35:32: =====Stream End: 2014-09-18, 19:35:32=================================================
19:35:33: CLR host plugin instance deleted; removing dynamically loaded localization strings
Last game capture log:
2014-09-18, 19:35:14: we're booting up:
19:35:14: CaptureThread: attached to process GameCapture.exe
19:35:14: D3D9 Present
19:35:14: DXGI Present
19:35:14: (half life scientist) everything.. seems to be in order
OBS Log Analyzer
Monitor capture detected
One of your scenes appears to be using monitor capture. Monitor capture is the slowest and least efficient method of capturing, and can cause FPS lag on both your stream and your game and will also cause problems capturing full-screen games. Consider using game capture or window capture instead (this does not apply to Windows 8).
Monitor capture with Aero enabled
You are using monitor capture with Aero enabled. This will cause severe performance degradation. If you absolutely must use monitor capture, disable Aero from video settings (this does not apply to Windows 8).
Late frames detected
12.68% of your frames are late. This means the frames are being generated later than they were needed, causing your stream FPS to drop. Late frames are often caused by slow sources such as monitor capture, slow video capture devices or by trying to run your stream at too high of a resolution / FPS.
If you are using a webcam, try to lower the resolution of it. If you are using monitor capture, try switching to game source or window capture. If you must use monitor capture, ensure Aero is disabled.
You can also try lowering the resolution or FPS of your stream if you have an older CPU.
See https://obsproject.com/forum/viewtopic.php?f=5&t=11641 for more information on how to resolve this issue.
3 issues found (3 major, 0 minor).
This happens.
It starts out too big for the screen, so I shrink it, and then boom.
Is there a way to get it working with 64bit?
