Hi,
I'm trying to capture in RGB (XRGB) with an Elgato 4K Pro, but XRGB never gives a live picture. YUY2 and NV12 works with the exact same setup.
Log: https://obsproject.com/logs/hQkqqp4BGJ7wamNB
System
- OBS 32.2.2 (64-bit), Windows 11 Home build 26300
- HP Pavilion Gaming Desktop 790-00xx, Intel i5-9400F, NVIDIA RTX 2060
- Elgato 4K Pro (PCIe, links at Gen2 x4), driver 1.1.0.203.7, firmware 24.06.11 / MCU 25.04.16
Source settings
Video Capture Device, 1920x1080, 59.94 fps, Video Format XRGB, buffering disabled.
What happens
Every time the format is XRGB, the log shows:
format: XRGB
DShow: Elgato GC4K60ProMK2 tonemapper enable=1
DShow: HDevice::ConnectPins: failed to connect pins (0x80040207)
0x80040207 = VFW_E_NO_ACCEPTABLE_TYPES. The preview is then black or frozen on the last frame (not live). With YUY2 or NV12 the error never appears and capture works fine.
Other findings
- ffmpeg (-list_options, dshow) lists the 4K Pro's RGB formats as "unknown compression type 0xE436EB7D" and "0xE436EB7E", while YUY2/NV12/UYVY are listed normally. Those values are the first part of the MEDIASUBTYPE_RGB24/RGB32 GUIDs, so the driver seems to put them in biCompression instead of BI_RGB (0).
Questions
1. Is the ConnectPins failure caused by the driver's non-standard RGB format description (biCompression), or something on the OBS side?
2. Could the hardware tonemapper (enabled by OBS for all non-P010 formats) make RGB unavailable on the 4K Pro? Is there a way to capture XRGB without enabling the tonemapper?
3. Is there any known workaround to get true RGB 4:4:4 from this card in OBS?
Thanks!
System
Source settings
What happens
format: XRGB
Other findings
Questions
Thanks!
