ArticRcade
So For The past 2-3 years I've been having issues with this combination but It more so started getting worse 2017,
My issue consist of the audio not being out put to twitch via the elgato but Obs levels for the elgato are moving and seem fully functional, I normally would fix it buy Deleting the Capture and re-adding, I recently Figure Going into the Capture changing the type is much faster than Deleting it and re-adding it.
Recently you guys released a patch, To Address the issue I have I believe but not when the elgato loses sound it screws up all the sound for the whole stream, My microphone and everything get jumbled up like a bad connection until I fix the elgato,
I would say it is the elgato but when I use it in its native software, I never have these issues the main problem with the native software vs obs is I think its poorly optimized to utilize normal pcs for things like stream command which would be a stream overlay or something.
I like your program , Alot and I'm Just looking for a solution.
Also the audio cutting out , Happens at random, I can have a 9- 12 hour stream fine, and then a 2 hour stream the audio randomly cuts out any time during this period with no rhyme or reason.
