Hello!
So a couple of weeks ago i bought the Avermedia Extremecap U3. I had aloooooot of trouble setting up everything but at the moment everything is working, but not as good as i want it.
FIRST PROBLEM: The audio input from the gaming pc is very low but in my headphones its high. When i listen to music at a low volume in my headphones the stream cant hear the music at all. I really need to crank the music up for the stream to hear. I have noticed when i have no sound at all at the gaming pc the volume bar on obs(on the streaming pc) is halfway up.
http://i.imgur.com/XNiOsHK.png?1
SECOND PROBLEM: A hissing/high-pitched noise when you turn up the volume on the stream (very annoying).
Alright now i'll try to explain how everything is set up (Paint skills)
http://imgur.com/ZW72WjS
Past broadcasts to see/hear the problem:
http://www.twitch.tv/vaajkan/profile/past_broadcasts
Will this solve both problems? And will it work if i put this in with the Y-splitter? http://www.amazon.com/PAC-SNI-1-3-5-3-5-mm-Isolator/dp/B001EAQTRI
Or will i still need to really crank up the volume to be able to stream out music to the stream?
Thanks in advance!
Thanks in advance!
