Question / Help Dual microphones random out of sync problem
illibodilli
Hi guys! I am using a dual mic setup where one mic is a lavalier for speach connected to 3.5mm Mic in on my laptop, and the other is a pair of Shure SM48 connected as stereo to a Behringer UMC204HD. The SMC204HD is USB.
I am on a HP Elitebook 8770W, 32GB RAM, i7.3720, SSDs and Win7pro.
My problem is this: When streaming or recording, there is a random difference in sync between the two Mic setups. I can adjust one source to match the other by adding a delay in Advanced Audio Properties, but the correction is only valid for X amount of seconds before I have to adjust again. It is floating with a delay between the two of 0 - 95-ish ms.
Change in ms delay can occur in the middle of my recording / streaming, or in between me adusting, then testing with succsess, and then having a different ms delay five minutes later.
I am relatively new to OBS, but understand encoding and general compuer things. I am a complete noob to USB soundcards.
Does anyone know why my two sound sources would behave like this? Randomly varying in delay? I cant say for sure, but I think delay jumps about 40-ish MS from change to change (ex: was perfect in sync at 42ms delay on source 1, then all of a sudden needs to be synced at 84ms).
Help please? I want to set up a mini ASMR lab thingy :)
Whoa... So far, setting both audio sorces (Microphone inputs) to "Use Device Timestamps" (right click source. Its a tick box under where u select source) seems to have fixed this problem for me. Ill come back and correct if it turns out not to be the case, but so far so good :)
