Dropped frames due to network help
Dwhitt1981
Ok so I have been pc gaming for about a year now and have been trying to get into streaming. I upgraded my internet to 1gb and picked up the asus ax82u as my motherboard has wifi6 . I can game fine but when I stream it skips and lags. I have done twitch test and my top 3 servers are ping - 13,22,&27 ms. Bit rate is 10000+ on all. Quality is 100 on all on I think it was 2min tests. I ran twitch inspector and did 30min test on every one and had stable the whole time with a average bitrate of 4400 min max was 300+/- . I stream at 720p 60 and quality looks good but every time I start skipping due the network dropped frames. I have capped my games to 60fps and always use cbr. So is there something in my router that could be holding me back or am I just missing something. This has been a problem for the past month. I just hit affiliate and it seems like I can’t get a stream to stay stable. Sorry for the long post but I’m at a lose. Thanks in advance.
NEVER stream over wifi.
Run a network cable. Yes, you absolutely can.
Wifi is NOT a replacement for cables, and is extremely susceptible to interference, as well as being a shared bandwidth space (meaning if your neighbor is on the same channel as you and starts a large file transfer, your throughput will tank on your own network). It's meant for lightweight content consumption on phones, tablets, and mobile laptops, not continuous minimum-throughput-critical tasks like streaming, especially from a fixed location.
Thanks for the reply. Sorry I forgot to put it in the post but I am hardwire with a cat6 cable to reduce any issues. I did use WiFi when I was only gaming as it did what I needed. Also as I said I’m on fiber and my speeds normally stay around 650down and 650 up but no less than 400 up hardwired and when I’m on WiFi I stay at 400 down and 275 up
Hey I have the same issue over here, with very decent internet. I made a thread too so if you can't find an answer come over to mine. I'll be monitoring yours as well, but fortunately, so far it looks like I am not alone, so it is more likely to be solved!
Thanks for the heads up i'll jump over and check your out also. I'll try to keep this post updated so if i find some a fix maybe it will fix both lol
