Question / Help Double sound using Astro A40's
slimdawg
My audio setup on OBS looks like this:
My default audio and communications device on my computer are the Astro w/ the mixamp. I do have a 1200 millisecond delay on both the webcam and audio, however, it does not delay the audio at all.
Post a logfile. And a VOD if possible, demonstrating the issue.
The most common cause of audio looping/doubling is having your livestream open and un-muted in a browser tab.
The second-most common is leaving an audio device enabled for your webcam (picking up your voice from both your headset mic AND the webcam mic, leading to the doubled audio); should disable the webcam audio entirely if you'll be using a headset mic.
Here is my log file: Shows no errors when tested with the website.
20:47:27: Open Broadcaster Software v0.60b - 32bit (´・ω・`)
20:47:27: -------------------------------
20:47:27: CPU Name: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
20:47:27: CPU Speed: 3200MHz
20:47:27: Physical Memory:  4095MB Total, 4095MB Free
20:47:27: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
20:47:27: monitor 1: pos={0, 0}, size={1920, 1080}
20:47:27: Windows Version: 6.1 Build 7601 S
20:47:27: Aero is Enabled
20:47:27: OBS Modules:
20:47:27: Base Address     Module
20:47:27: 00E30000         OBS.exe
20:47:27: 64690000         OBSApi.dll
20:47:27: 65F70000         DShowPlugin.dll
20:47:27: 64460000         GraphicsCapture.dll
20:47:27: 64440000         NoiseGate.dll
20:47:27: 64420000         PSVPlugin.dll
20:47:27: ------------------------------------------
20:47:27: Adapter 1
20:47:27:   Video Adapter: NVIDIA GeForce GTX 650
20:47:27:   Video Adapter Dedicated Video Memory: 1020985344
20:47:27:   Video Adapter Shared System Memory: 3221549056
20:47:27:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
20:47:27: =====Stream Start: 2014-02-06, 20:47:27===============================================
20:47:27:   Multithreaded optimizations: On
20:47:27:   Base resolution: 1920x1080
20:47:27:   Output resolution: 1280x720
20:47:27: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
20:47:27: Audio Format: 44100hz
20:47:27: Playback device Default
20:47:27: Using desktop audio input: Microphone (ASTRO Gaming USB MixAmp)
20:47:27: Using auxilary audio input: Microphone (ASTRO Gaming USB MixAmp)
20:47:27: Audio Encoding: AAC
20:47:27:     bitrate: 128
20:47:27: Using bitmap image
20:47:28: ------------------------------------------
20:47:28:     device: \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:47:28:     device id \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:47:28:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666
20:47:28:     use buffering: true - 12000000, fourCC: 'I420'
20:47:28:     audio device: Disable,
20:47:28:     audio device id Disabled,
20:47:28:
20:47:28: Using directshow input
20:47:28:     device: Elgato Game Capture HD,
20:47:28:     device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
20:47:28:     chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
20:47:28:     use buffering: false - 0, fourCC: 'UYVY'
20:47:28:
20:47:28:     device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
20:47:28: Scene buffering time set to 400
20:47:28: Video Encoding: x264
20:47:28:     fps: 60
20:47:28:     width: 1280, height: 720
20:47:28:     preset: veryfast
20:47:28:     profile: high
20:47:28:     keyint: 120
20:47:28:     CBR: yes
20:47:28:     CFR: yes
20:47:28:     max bitrate: 3000
20:47:28:     buffer size: 3000
20:47:32: GetQPCTimeNS: WTF, clock went backwards! 67123704514 < 67123704515
20:47:37: GetQPCTime100NS: WTF, clock went backwards! 67142039726 < 67142039727
20:47:40: GetQPCTimeNS: WTF, clock went backwards! 67151074672 < 67151074673
20:47:44: Total frames encoded: 915, total frames duplicated: 7 (0.77%)
20:47:44: Total frames rendered: 923, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
20:47:48:
20:47:48: Profiler time results:
20:47:48:
20:47:48: ==============================================================
20:47:48: video thread frame - [100%] [avg time: 1.277 ms] [children: 44.5%] [unaccounted: 55.5%]
20:47:48: | scene->Preprocess - [33.1%] [avg time: 0.423 ms]
20:47:48: | GPU download and conversion - [11.4%] [avg time: 0.145 ms] [children: 9.4%] [unaccounted: 1.96%]
20:47:48: | | flush - [7.52%] [avg time: 0.096 ms]
20:47:48: | | CopyResource - [1.72%] [avg time: 0.022 ms]
20:47:48: | | conversion to 4:2:0 - [0.157%] [avg time: 0.002 ms]
20:47:48: Convert444Threads - [100%] [avg time: 0.531 ms] [children: 99.2%] [unaccounted: 0.753%]
20:47:48: | Convert444toNV12 - [99.2%] [avg time: 0.527 ms]
20:47:48: encoder thread frame - [100%] [avg time: 0.958 ms]
20:47:48:
20:47:48:
20:47:48: Profiler CPU results:
20:47:48:
20:47:48: video thread frame - [cpu time: avg 0.878 ms, total 811.205 ms] [avg calls per frame: 1]
20:47:48: | scene->Preprocess - [cpu time: avg 0.253 ms, total 234.002 ms] [avg calls per frame: 1]
20:47:48: | GPU download and conversion - [cpu time: avg 0.067 ms, total 62.401 ms] [avg calls per frame: 1]
20:47:48: | | flush - [cpu time: avg 0.016 ms, total 15.6 ms] [avg calls per frame: 1]
20:47:48: | | CopyResource - [cpu time: avg 0.017 ms, total 15.6 ms] [avg calls per frame: 1]
20:47:48: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:47:48: Convert444Threads - [cpu time: avg 0.297 ms, total 530.402 ms] [avg calls per frame: 2]
20:47:48: | Convert444toNV12 - [cpu time: avg 0.288 ms, total 514.802 ms] [avg calls per frame: 2]
20:47:48: encoder thread frame - [cpu time: avg 0.28 ms, total 249.601 ms] [avg calls per frame: 1]
20:47:48:
20:47:48: =====Stream End: 2014-02-06, 20:47:48=================================================
20:48:34: =====Stream Start: 2014-02-06, 20:48:34===============================================
20:48:34:   Multithreaded optimizations: On
20:48:34:   Base resolution: 1920x1080
20:48:34:   Output resolution: 1280x720
20:48:34: ------------------------------------------
20:48:34: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
20:48:34: Audio Format: 44100hz
20:48:34: Playback device Default
20:48:34: Using desktop audio input: Microphone (ASTRO Gaming USB MixAmp)
20:48:34: Using auxilary audio input: Microphone (ASTRO Gaming USB MixAmp)
20:48:34: Audio Encoding: AAC
20:48:34:     bitrate: 128
20:48:34: Using bitmap image
20:48:34:     device: \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:48:34:     device id \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:48:34:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666
20:48:34:     use buffering: true - 12000000, fourCC: 'I420'
20:48:34:     audio device: Disable,
20:48:34:     audio device id Disabled,
20:48:34:
20:48:34: Using directshow input
20:48:34:     device: Elgato Game Capture HD,
20:48:34:     device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
20:48:34:     chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
20:48:34:     use buffering: false - 0, fourCC: 'UYVY'
20:48:34:
20:48:34:     device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
20:48:34: Scene buffering time set to 400
20:48:34: Video Encoding: x264
20:48:34:     fps: 60
20:48:34:     width: 1280, height: 720
20:48:34:     preset: veryfast
20:48:34:     profile: high
20:48:34:     keyint: 120
20:48:34:     CBR: yes
20:48:34:     CFR: yes
20:48:34:     max bitrate: 3000
20:48:34:     buffer size: 3000
20:48:45: GetQPCTime100NS: WTF, clock went backwards! 67352045471 < 67352045472
20:48:46: Total frames encoded: 631, total frames duplicated: 6 (0.95%)
20:48:46: Total frames rendered: 639, number of late frames: 2 (0.31%) (it's okay for some frames to be late)
20:48:49:
20:48:49: Profiler time results:
20:48:49:
20:48:49: ==============================================================
20:48:49: video thread frame - [100%] [avg time: 1.263 ms] [children: 36.2%] [unaccounted: 63.8%]
20:48:49: | scene->Preprocess - [28%] [avg time: 0.354 ms]
20:48:49: | GPU download and conversion - [8.16%] [avg time: 0.103 ms] [children: 6.73%] [unaccounted: 1.43%]
20:48:49: | | flush - [4.59%] [avg time: 0.058 ms]
20:48:49: | | CopyResource - [1.98%] [avg time: 0.025 ms]
20:48:49: | | conversion to 4:2:0 - [0.158%] [avg time: 0.002 ms]
20:48:49: Convert444Threads - [100%] [avg time: 0.433 ms] [children: 99.1%] [unaccounted: 0.924%]
20:48:49: | Convert444toNV12 - [99.1%] [avg time: 0.429 ms]
20:48:49: encoder thread frame - [100%] [avg time: 0.838 ms]
20:48:49:
20:48:49:
20:48:49: Profiler CPU results:
20:48:49:
20:48:49: video thread frame - [cpu time: avg 0.83 ms, total 530.403 ms] [avg calls per frame: 1]
20:48:49: | scene->Preprocess - [cpu time: avg 0.146 ms, total 93.6 ms] [avg calls per frame: 1]
20:48:49: | GPU download and conversion - [cpu time: avg 0.048 ms, total 31.201 ms] [avg calls per frame: 1]
20:48:49: | | flush - [cpu time: avg 0.024 ms, total 15.6 ms] [avg calls per frame: 1]
20:48:49: | | CopyResource - [cpu time: avg 0.025 ms, total 15.601 ms] [avg calls per frame: 1]
20:48:49: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:48:49: Convert444Threads - [cpu time: avg 0.102 ms, total 124.8 ms] [avg calls per frame: 2]
20:48:49: | Convert444toNV12 - [cpu time: avg 0.102 ms, total 124.8 ms] [avg calls per frame: 2]
20:48:49: encoder thread frame - [cpu time: avg 0.102 ms, total 62.4 ms] [avg calls per frame: 1]
20:48:49:
20:48:49: =====Stream End: 2014-02-06, 20:48:49=================================================
20:49:22: =====Stream Start: 2014-02-06, 20:49:22===============================================
20:49:22:   Multithreaded optimizations: On
20:49:22:   Base resolution: 1920x1080
20:49:22:   Output resolution: 1280x720
20:49:22: ------------------------------------------
20:49:22: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
20:49:22: Audio Format: 44100hz
20:49:22: Playback device Default
20:49:22: Using desktop audio input: Microphone (ASTRO Gaming USB MixAmp)
20:49:22: Using auxilary audio input: Microphone (ASTRO Gaming USB MixAmp)
20:49:22: Audio Encoding: AAC
20:49:22:     bitrate: 128
20:49:22: Using bitmap image
20:49:22:     device: \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:49:22:     device id \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:49:22:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666
20:49:22:     use buffering: true - 12000000, fourCC: 'I420'
20:49:22:     audio device: Disable,
20:49:22:     audio device id Disabled,
20:49:22:
20:49:22: Using directshow input
20:49:22:     device: Elgato Game Capture HD,
20:49:22:     device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
20:49:22:     chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
20:49:22:     use buffering: false - 0, fourCC: 'UYVY'
20:49:22:
20:49:22:     device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
20:49:22: Scene buffering time set to 400
20:49:22: Video Encoding: x264
20:49:22:     fps: 60
20:49:22:     width: 1280, height: 720
20:49:22:     preset: veryfast
20:49:22:     profile: high
20:49:22:     keyint: 120
20:49:22:     CBR: yes
20:49:22:     CFR: yes
20:49:22:     max bitrate: 3000
20:49:22:     buffer size: 3000
20:49:31: Total frames encoded: 540, total frames duplicated: 7 (1.30%)
20:49:31: Total frames rendered: 549, number of late frames: 1 (0.18%) (it's okay for some frames to be late)
20:49:35:
20:49:35: Profiler time results:
20:49:35:
20:49:35: ==============================================================
20:49:35: video thread frame - [100%] [avg time: 1.381 ms] [children: 37.3%] [unaccounted: 62.7%]
20:49:35: | scene->Preprocess - [29.1%] [avg time: 0.402 ms]
20:49:35: | GPU download and conversion - [8.18%] [avg time: 0.113 ms] [children: 6.88%] [unaccounted: 1.3%]
20:49:35: | | flush - [5.21%] [avg time: 0.072 ms]
20:49:35: | | CopyResource - [1.52%] [avg time: 0.021 ms]
20:49:35: | | conversion to 4:2:0 - [0.145%] [avg time: 0.002 ms]
20:49:35: Convert444Threads - [100%] [avg time: 0.45 ms] [children: 99.1%] [unaccounted: 0.889%]
20:49:35: | Convert444toNV12 - [99.1%] [avg time: 0.446 ms]
20:49:35: encoder thread frame - [100%] [avg time: 0.839 ms]
20:49:35:
20:49:35:
20:49:35: Profiler CPU results:
20:49:35:
20:49:35: video thread frame - [cpu time: avg 0.937 ms, total 514.803 ms] [avg calls per frame: 1]
20:49:35: | scene->Preprocess - [cpu time: avg 0.17 ms, total 93.6 ms] [avg calls per frame: 1]
20:49:35: | GPU download and conversion - [cpu time: avg 0.056 ms, total 31.2 ms] [avg calls per frame: 1]
20:49:35: | | flush - [cpu time: avg 0.028 ms, total 15.6 ms] [avg calls per frame: 1]
20:49:35: | | CopyResource - [cpu time: avg 0.03 ms, total 15.6 ms] [avg calls per frame: 1]
20:49:35: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:49:35: Convert444Threads - [cpu time: avg 0.271 ms, total 280.8 ms] [avg calls per frame: 2]
20:49:35: | Convert444toNV12 - [cpu time: avg 0.271 ms, total 280.8 ms] [avg calls per frame: 2]
20:49:35: encoder thread frame - [cpu time: avg 0.09 ms, total 46.8 ms] [avg calls per frame: 1]
20:49:35:
20:49:35: =====Stream End: 2014-02-06, 20:49:35=================================================
20:52:10: =====Stream Start: 2014-02-06, 20:52:10===============================================
20:52:10:   Multithreaded optimizations: On
20:52:10:   Base resolution: 1920x1080
20:52:10:   Output resolution: 1280x720
20:52:10: ------------------------------------------
20:52:10: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
20:52:10: Audio Format: 44100hz
20:52:10: Playback device Default
20:52:10: Using desktop audio input: Microphone (ASTRO Gaming USB MixAmp)
20:52:10: Using auxilary audio input: Microphone (ASTRO Gaming USB MixAmp)
20:52:10: Audio Encoding: AAC
20:52:10:     bitrate: 128
20:52:10: Using bitmap image
20:52:10:     device: \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:52:10:     device id \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:52:10:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666
20:52:10:     use buffering: true - 12000000, fourCC: 'I420'
20:52:10:     audio device: Disable,
20:52:10:     audio device id Disabled,
20:52:10:
20:52:10: Using directshow input
20:52:10:     device: Elgato Game Capture HD,
20:52:10:     device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
20:52:10:     chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
20:52:10:     use buffering: false - 0, fourCC: 'UYVY'
20:52:10:
20:52:10:     device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
20:52:10: Scene buffering time set to 400
20:52:10: Video Encoding: x264
20:52:10:     fps: 60
20:52:10:     width: 1280, height: 720
20:52:10:     preset: veryfast
20:52:10:     profile: high
20:52:10:     keyint: 120
20:52:10:     CBR: yes
20:52:10:     CFR: yes
20:52:10:     max bitrate: 3000
20:52:10:     buffer size: 3000
20:52:20: Total frames encoded: 554, total frames duplicated: 4 (0.72%)
20:52:20: Total frames rendered: 563, number of late frames: 1 (0.18%) (it's okay for some frames to be late)
20:52:23:
20:52:23: Profiler time results:
20:52:23:
20:52:23: ==============================================================
20:52:23: video thread frame - [100%] [avg time: 1.285 ms] [children: 38.8%] [unaccounted: 61.2%]
20:52:23: | scene->Preprocess - [30.3%] [avg time: 0.389 ms]
20:52:23: | GPU download and conversion - [8.48%] [avg time: 0.109 ms] [children: 7.16%] [unaccounted: 1.32%]
20:52:23: | | flush - [5.06%] [avg time: 0.065 ms]
20:52:23: | | CopyResource - [1.95%] [avg time: 0.025 ms]
20:52:23: | | conversion to 4:2:0 - [0.156%] [avg time: 0.002 ms]
20:52:23: Convert444Threads - [100%] [avg time: 0.468 ms] [children: 99.1%] [unaccounted: 0.855%]
20:52:23: | Convert444toNV12 - [99.1%] [avg time: 0.464 ms]
20:52:23: encoder thread frame - [100%] [avg time: 0.843 ms]
20:52:23:
20:52:23:
20:52:23: Profiler CPU results:
20:52:23:
20:52:23: video thread frame - [cpu time: avg 0.914 ms, total 514.803 ms] [avg calls per frame: 1]
20:52:23: | scene->Preprocess - [cpu time: avg 0.193 ms, total 109.201 ms] [avg calls per frame: 1]
20:52:23: | GPU download and conversion - [cpu time: avg 0.138 ms, total 78 ms] [avg calls per frame: 1]
20:52:23: | | flush - [cpu time: avg 0.027 ms, total 15.6 ms] [avg calls per frame: 1]
20:52:23: | | CopyResource - [cpu time: avg 0.058 ms, total 31.2 ms] [avg calls per frame: 1]
20:52:23: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:52:23: Convert444Threads - [cpu time: avg 0.22 ms, total 234 ms] [avg calls per frame: 2]
20:52:23: | Convert444toNV12 - [cpu time: avg 0.22 ms, total 234 ms] [avg calls per frame: 2]
20:52:23: encoder thread frame - [cpu time: avg 0.206 ms, total 109.2 ms] [avg calls per frame: 1]
20:52:23:
20:52:23: =====Stream End: 2014-02-06, 20:52:23=================================================
20:53:02: =====Stream Start: 2014-02-06, 20:53:02===============================================
20:53:02:   Multithreaded optimizations: On
20:53:02:   Base resolution: 1920x1080
20:53:02:   Output resolution: 1280x720
20:53:02: ------------------------------------------
20:53:02: Loading up D3D10 on NVIDIA GeForce GTX 650 (Adapter 1)...
20:53:02: Audio Format: 44100hz
20:53:02: Playback device Default
20:53:02: Using desktop audio input: Microphone (ASTRO Gaming USB MixAmp)
20:53:02: Using auxilary audio input: Microphone (ASTRO Gaming USB MixAmp)
20:53:02: Audio Encoding: AAC
20:53:02:     bitrate: 128
20:53:02: Using bitmap image
20:53:02:     device: \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:53:02:     device id \\?\usb#vid_045e&pid_0728&mi_00#7&3b82ecd8&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
20:53:02:     chosen type: I420, usingFourCC: false, res: 640x480 - 640x480, frameIntervals: 333333-666666
20:53:02:     use buffering: true - 12000000, fourCC: 'I420'
20:53:02:     audio device: Disable,
20:53:02:     audio device id Disabled,
20:53:02:
20:53:02: Using directshow input
20:53:02:     device: Elgato Game Capture HD,
20:53:02:     device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
20:53:02:     chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333
20:53:02:     use buffering: false - 0, fourCC: 'UYVY'
20:53:02:
20:53:02:     device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
20:53:02: Scene buffering time set to 400
20:53:02: Video Encoding: x264
20:53:02:     fps: 60
20:53:02:     width: 1280, height: 720
20:53:02:     preset: veryfast
20:53:02:     profile: high
20:53:02:     keyint: 120
20:53:02:     CBR: yes
20:53:02:     CFR: yes
20:53:02:     max bitrate: 3000
20:53:02:     buffer size: 3000
20:53:13: Total frames encoded: 640, total frames duplicated: 2 (0.31%)
20:53:13: Total frames rendered: 648, number of late frames: 2 (0.31%) (it's okay for some frames to be late)
20:53:17:
20:53:17: Profiler time results:
20:53:17:
20:53:17: ==============================================================
20:53:17: video thread frame - [100%] [avg time: 1.255 ms] [children: 37.9%] [unaccounted: 62.1%]
20:53:17: | scene->Preprocess - [29.2%] [avg time: 0.367 ms]
20:53:17: | GPU download and conversion - [8.69%] [avg time: 0.109 ms] [children: 7.33%] [unaccounted: 1.35%]
20:53:17: | | flush - [5.5%] [avg time: 0.069 ms]
20:53:17: | | CopyResource - [1.67%] [avg time: 0.021 ms]
20:53:17: | | conversion to 4:2:0 - [0.159%] [avg time: 0.002 ms]
20:53:17: Convert444Threads - [100%] [avg time: 0.447 ms] [children: 99.1%] [unaccounted: 0.895%]
20:53:17: | Convert444toNV12 - [99.1%] [avg time: 0.443 ms]
20:53:17: encoder thread frame - [100%] [avg time: 0.817 ms]
20:53:17:
20:53:17:
20:53:17: Profiler CPU results:
20:53:17:
20:53:17: video thread frame - [cpu time: avg 0.866 ms, total 561.603 ms] [avg calls per frame: 1]
20:53:17: | scene->Preprocess - [cpu time: avg 0.096 ms, total 62.4 ms] [avg calls per frame: 1]
20:53:17: | GPU download and conversion - [cpu time: avg 0.072 ms, total 46.8 ms] [avg calls per frame: 1]
20:53:17: | | flush - [cpu time: avg 0.048 ms, total 31.2 ms] [avg calls per frame: 1]
20:53:17: | | CopyResource - [cpu time: avg 0.025 ms, total 15.6 ms] [avg calls per frame: 1]
20:53:17: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
20:53:17: Convert444Threads - [cpu time: avg 0.164 ms, total 202.8 ms] [avg calls per frame: 2]
20:53:17: | Convert444toNV12 - [cpu time: avg 0.164 ms, total 202.8 ms] [avg calls per frame: 2]
20:53:17: encoder thread frame - [cpu time: avg 0.101 ms, total 62.4 ms] [avg calls per frame: 1]
20:53:17:
20:53:17: =====Stream End: 2014-02-06, 20:53:17=================================================
20:58:29: Memory Leaks Were Detected.
20:58:29:
Here is an example from my stream:
http://www.twitch.tv/vaxinne/b/501353377
Here is my current audio setup in OBS, and I DO have the microphone disabled from my webcam.
You're using the mixamp for both your desktop and mic audio. Uncheck 'use input device for desktop audio', and select the appropriate speaker-set.
That option is mostly meant for those who are running their desktop audio out, through a mixing/VST stack, then back into the PC via a line-in, or those using a two-system casting rig without audio-over-HDMI, but want to keep their mic levels separate. As-is, you're double-pumping the same signal through both channels, causing the 'echo'.
