Is that a form of False Detection? (Version 4.3.0)
https://www.virustotal.com/#/file/7...64a835bac46260c58e7e78293cc909dcd7a/detection
hi, thanks for the plugin. I have a capture card and its painful and impossible for me to get it duplicate to 60hz. when I test out the plugin yesterday, it was good and no frames drop on obs. however, my stream looks kinda choppy, I have a 500mb down and 20 up. I am just wondering whether my upload speed is enough for this plugin. I am in canada and currently with rogers. The max upload speed that i can get is 30 mb up with rogers. Morever, I have both pcs plugged into ethernet cable. Is there any other work around without buying another 144hz monitor?
Thanks in advance. Everything appears to be simple and easy, but more and more problems keep showing up. Feelsbad
thank you for the reply. Unfortunately, I cant do any tests. I am on my way to mexico attending a wedding. I should be back in 7 days. Is there an upload speed requirement for it to work? Is 20mb upload enough (I stream at 720p 30fps gaming at 1080p 144hz)Do you have a link to your stream? Perhaps if I could watch it, I might be able to diagnose the problem a bit more accurately. Glad you like the plugin! Palakis has been working really hard to keep it updated!
Hello! I love using this plugin. I had a thought the other day about using a 2nd nic dedicated for the NDI traffic. Has anyone set up their NDI traffic in this way? Thanks!
